Question about Tekram (TM802G) Network Adapter
Poor connection speed
TM-802G unit, new in retail box. Drivers load fine on Win2K, unit powers up & connects to AP. But no matter how strong the connection (B or G freq.) it never transmits above 1mbs. I've tried the unit at several sites & on several wireless APs w/ the same results. Tekram website has no info or updated drivers on their site. Thanks
  • Martin Franusich Jan 06, 2007
    Thanks, not it this time.
    I have a Trendnet USB unit that I tested at the same time on this laptop & it has nice connection speeds.
    Afraid you may be right that it is defective... Prob. why it only had a 7 day return warranty.
  • 624 Answers
Check both the access point AND the wireless card to make sure you havn't limited the connection to 1Mbps. Other than that it may simply be a defective unit.
Posted on Jan 06, 2007
  • tomj23 Jan 06, 2007
    The manufacturer should honor a warranty for 1 year. I would try then and make sure the reseller isn't talking about their exchange policy.
SOURCE:
Epson TM-U220D. Parallel to USB connection. Which drivers should I install?
Hi Ali
The problem by doing this is that not all Parallel to USB cables work right out of the box with your equipment.
What you need to do first is make sure that your computer sees the device through the cable. Then when it prompts you for the drivers for the printer install the driver set (parallel) the connection should not matter at this point. However the step of the computer detecting the device first is very important.
I hope this helped.
Philipp
Apr 16, 2014 | Epson TM-U220 Matrix Printer
Can you help me connect my Zonet Wireless AP Router ZSR2104WE now that I have purchased a new modem (Motorola DSL Modem 3360)?
You must hook these particular items up in a specific sequence. First power down both the modem and the router, only connect the modem to the isp until all appropriate lights on on. Next plug cat 5 to router where it is labeled internet or wan if neither label then to #1. until alights come up on router. Hope this helps.
Sep 06, 2012 | Zonet ZSR2104WE Wireless Router
ORiNOCO® 802.11a/b/g/n USB adapter does not roam
Can you turn down the transmit power, or lock a certain data rate, on the client card? Doing either of those things should initiate a roam more quickly. Do you have any control of the infrastructure configuration? You can lock the datarates on the AP's to achieve the same effet, though it may have adverse effects on other client devices.
Nov 24, 2009 | Computers & Internet
Tekram TM-802G card in win98se laptop only 1mbps Tx rate
For that you have to change channel type in wireless settings of router.
For that connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" or blank or "password"
then click on wireless then change channel type to 4 ,6 or 11.Set 1 b y 1 and set which give best speeed. channel type then save and restart router.
Let me know if you need further assistance.
thanks.
Nov 04, 2009 | Computers & Internet
My brother in law asked me to find out what is the purpose of the eld unit inside the under-hoodfuse/relay box? he has a 1998 honda civic. we cant get the alternater to charge,even after changeing it out...
The ELD unit or Electrical Load Detector functions to monitor and regulate the output of the alternator. The ELD is located in the fuse box under the hood near the battery. It's a (typically) red rectangular box.
If the ELD unit is malfunctioning, it is very possible that it is preventing the alternator from putting out a charge. I do not know of a way to test it, other than to replace it.
Just to make sure, first check all battery connections, including the engine ground, for corrosion. All terminals and wires should be super clean, in order to rule out such a simple matter of a poor connection (this is very common). Also , make sure the power wires going into the fuse box and the ELD socket are free of corrosion.
I hope this helps. Good Luck!
Jul 30, 2009 | 1998 Honda Civic
Sharing internet from dlink 510g to linksys wap54g AP
yes, the manufacturer doesn't really matter as long as they are 802.11g (usually backwards compatible with a and b) so as long as the router and the adapters are installed properly NO problem
May 14, 2009 | D-Link High-Speed 802.11g Wireless PCI...
We have an industrial setting. We're using RF devices, scanners on lift trucks that move through our warehouse. We are losing connection when the device gets out of range of one access point and tries to...
Plz check for 3 things:
1. All of your AP should given access to roaming devices, for this all of your AP are should connected with each other.
2. WiFi chennal for your device should be same for all AP.
3. Configure 802.11b or 11Mbps speed on devices.
Plz revert in case
Thanks for contacting Fixya
Mar 23, 2009 | 3Com Wireless LAN Managed Access Point...
Self-assigned IP address and may not be able to connect to the Internet
if its a wireless network it assigns yyou an ip immediately solong as you are not connecting directly so dont bother about the ip just connect and see what happens.
Oct 27, 2008 | Lucent ORiNOCO AP-500 (8485878380)
Wireless router
I think 2wire routers are good in providing signal strength. Contact the 2wire vendor regarding your requirements.
take care
May 01, 2008 | AT&T High Speed DSL Modem
ATI Radeon HD 2400 PRO - Win2k drivers
You can download a beta version of the driver for Win2k HERE
You could also download the ATI Catalyst Drivers Version 7.2 for Win2K/XP if you want from HERE
Hope that helps..Not sure if the CD in the box contains the software for Win2k though...
Apr 18, 2008 | Computers & Internet
Open Questions:
COMCAST password reset phone number +1800 828 0294 RAJAN RAJAN Get COMCAST 1800 828 0294 password reset phone number easy steps to forgot or change COMCAST password reset via phone number #1-************ just follow some steps to recover COMCAST password while you want. In varoius conditions many people lost their account password and much more secure information or information may be hacked by anyone so in that case people want to configure COMCAST with COMCAST or other microsoft account services. Their are many certified officer to suggest people that how to change or reset COMCAST voicemail password using phone number in easy mode wih simple procedure. Hence search engine suggest many combinations to reset COMCAST password to reset or change it quickly, if you have any of them so contact to get well COMCAST support form us. COMCAST password reset not working COMCAST password reset phone number COMCAST password reset contact number COMCAST password reset help COMCAST password reset support COMCAST password reset wont work COMCAST password reset wont work COMCAST password reset link COMCAST password reset issues COMCAST password reset usa COMCAST password reset customer service. COMCAST email account password reset ' free COMCAST email password recovery ' cannot reset COMCAST email password ' COMCAST email password recovery ' COMCAST email password recovery download ' COMCAST email password recovery software ' free COMCAST email password recovery. COMCAST email password change, COMCAST email hacked password changed, COMCAST email hacked can't change password, change COMCAST email password on iphone, change COMCAST email password on ipad, change COMCAST email password on android, COMCAST email account hacked can't change password, how to change COMCAST email password on droid, COMCAST email password problems, COMCAST email password not working, COMCAST email account password reset. COMCAST password reset phone number.
Apr 26, 2019 | Microsoft Computers & Internet
AIM password reset phone number +1800 828 0294 RAJAN RAJAN Get AIM 1800 828 0294 password reset phone number easy steps to forgot or change AIM password reset via phone number #1-************ just follow some steps to recover AIM password while you want. In varoius conditions many people lost their account password and much more secure information or information may be hacked by anyone so in that case people want to configure AIM with AIM or other microsoft account services. Their are many certified officer to suggest people that how to change or reset AIM voicemail password using phone number in easy mode wih simple procedure. Hence search engine suggest many combinations to reset AIM password to reset or change it quickly, if you have any of them so contact to get well AIM support form us. AIM password reset not working AIM password reset phone number AIM password reset contact number AIM password reset help AIM password reset support AIM password reset wont work AIM password reset wont work AIM password reset link AIM password reset issues AIM password reset usa AIM password reset customer service. AIM email account password reset ' free AIM email password recovery ' cannot reset AIM email password ' AIM email password recovery ' AIM email password recovery download ' AIM email password recovery software ' free AIM email password recovery. AIM email password change, AIM email hacked password changed, AIM email hacked can't change password, change AIM email password on iphone, change AIM email password on ipad, change AIM email password on android, AIM email account hacked can't change password, how to change AIM email password on droid, AIM email password problems, AIM email password not working, AIM email account password reset. AIM password reset phone number.
See all Tekram (TM802G) Network Adapter Questions
Tekram (TM802G) Network Adapter Logo
64 people viewed this question
Top Tekram Computers & Internet Experts
Robert Graf
Robert Stout
Robert Stout
Bill Boyd
Are you a Tekram Computer and Internet Expert? Answer questions, earn points and help others
