I have had a problem with AOL wireless broadband connection. Have now got it back on two computers but third, IBM Thinkpad, won't accept the network password key require to initialise. The message coming up reads: The network password needs to be 40 bits or 104 bits depending on your network configuration. This can be entered as 5 or 13 ascii characters or 10 or 26 hexadecimal characters. AOL have advised me to go to IBM for help but I need access NOW!!!
  • susan weymes Nov 25, 2008
    I have entered the password (OK with other 2 pcs). It has 11 characters. Same message appearing. Have also tried entering network name and same messages appears.
  • 4,806 Answers
Use the SSID name (network name) or network key
let me know how you get on
Posted on Nov 25, 2008
  • Lee Hodgson
    Lee Hodgson Nov 25, 2008
    try reinstalling the wireless card on the laptop, if you have no joy reset the router, there should be a small hole or button somewhere, and remeber to jot the key and possibly password from the back of the router, and one last thing, and try this first, make sure your caps lock and the num lock is off
Why does connecting to an ad-hoc network disconnect the shared mobile broadband connection?
You can be connected to two signals at one time, if I understand your statement. My question is, why is your laptop automatically connecting to a Ad-Hoc network? Your wireless adapter Intel Wireless 3945A/B/G,settings should be scrutinized. Perhaps this will help:
Dec 15, 2012 | IBM Lenovo ThinkPad Z61m 9452-J4U PC...
Connecting to my home wireless
Does it find a signal? do you get an error message? if so what is that message. if it does not find a wireless signal do you have the the wireless turned on most of the IBM thinkpad has a switch on the side of the computer to turn the wireless connection on and off. make sure it is on. please answer the 2 question above for more help
Dec 13, 2007 | IBM ThinkPad T42 Notebook
I have an IBM ThinkPad R40e and there is a question mark in the ethernet conection i have already install the driver but still I can´t conect to the broadband ethernet. Is this a bug or daughter...
It may that your wireless card can't handle the encryption on the wireless network you are trying to connect to. Thinkpad R40's are limited to WEP encryption (see Lenovo's/IBM's site If your network is using WPA, for example, you won't be able to connect. Usually it will say something about not being able to find a certificate if this is the problem.
Oct 15, 2009 | IBM ThinkPad R40e 2684 Notebook
Computer says IBM wireless adapters (802.11 or bluetooth) not ins
Hello Kangarootrib,
Since you bought the ThinkPad second hand and the software installation disc did not come with it, you should go to the IBM ThinkPad manufacturer's web site. Once there, look for your specific model and search for the proper drivers and download and install them on your current computer. Drivers are basically small bits of code that tell the operating system how to communicate with hardware devices, which when you purchase products new come with a CD that contains these instructions for your computer to be able to communicate with the device. Hope this helps and please let us know if you need further assistance.
P.S. If you would not mind, could you please rate my help as I would really appreciate it. Thank you
Mar 21, 2009 | IBM ThinkPad R50e Notebook
I need to turn my wirless internetnet option on and cant for my IBM thinkpad thanks
mostly the button is found on the left float side of your laptop 'IBM'. with two icons of a computer. please make sure that the button is on the side of the icon that shows a computer with weaves. so that your able to check the wireless access points you have in your range.
Wireless Connection:
Start > Control Panel > network connection>
Show network connections. If there is an X on wireless connection then connection is disabling and if no X then connection is enable.
make sure its enabled.
Right click on wireless network connection and click view available wireless networks.
You should see a list of available wireless networks
Then select the wireless network that you need to work on and click connect.
An icon in the lower right hand corner of your laptop should eventually appear stating that you are connected.
Then this will show you your wireless connection.
Excellent you connect to your wireless network.
Dec 15, 2008 | IBM ThinkPad T40 2373 Notebook
IBM R40 2722 1802 Error Message
This is due to the fact that IBM laptops have a list of accepted devices, and the pci card is not recognised in the list. On IBM - Amilo, Mini PCI card slot is usually at the back of computer. Locate and remove Mini PCI wireless card, you will not have integrated wireless after this.
Other solution is to find the option to disable mini PCI in bios settings.
Here is how mini pci wireless card looks like:
May 28, 2008 | IBM ThinkPad R40 2722 Notebook
Ethernet Adapter for IBM Thinkpad
Try this link
This is for a wired card(Cat 5e ethernet cable from card to modem)
May 13, 2008 | IBM ThinkPad 760 EL Notebook
Wireless connection
There are a few requirements other than the laptop and the wireless card. You need to also have an Wireless AP/Router that must be connected to the modem that connects to your ISP. All your PCs must then connect to this router either using the wired/Ethernet ports or WiFi.
If such a device (WiFi AP/Router) already exists and is connected to your modem and your other PC(s) are tied up to it and can access the Internet, you need to install the drivers (in a CD that came with the wireless card) to your IBM ThinkPad. Thereafter, you need to configure your laptop's wireless networking to access the AP/router. Your AP/Router must also be configured to accept wireless clients.
Please post back with brand/model of your AP/Router.
Hope this be of initial help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Feb 01, 2008 | IBM ThinkPad T20 2647 Notebook
Ibm think pad t30
To my knowledge, your laptop (IBM ThinkPad X30 2672) does not have any built-in WiFi. It's modes of connection are IrDA, modem, Ethernet, USP, Firewire aside from the regular serial & parallel. This would indicate that if you are wireless you either have a USB dongle or PCMCIA card. Please post back with your WiFi brand/model and your Operating System. Further, please post back likewise your WiFi AP/Router brand/model.
The message "a network cable is unplugged" pertains to the absence of a lan cable connected to your Ethernet port.
Good luck, kind regards and will await your second post.
Nov 16, 2007 | IBM ThinkPad X30 2672 Notebook
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
