Steering problem GSXR600 SRAD
A couple of things... are the tyres matched? You said you have changed the rear and the front is worn - this will definitely have an effect on handling, as will tyre pressures. The correct sizes for your tyres are: Front 120/70 ZR-17, Rear 180/55 ZR-17
You should ALWAYS use matched tyres - even differences between models in the same brand will be different and you shouldn't mix and match unless you are an expert - and I mean a real expert - pro racer or similar.
Tyre pressures for your bike are : 36psi front and rear. Unless your tyre manufacturer says different, use that figure. Unless all those things are right, you can't begin to diagnose handling issues.
