Question about Avaya 5400 Series 5410 Phone
Busy When Trying to access mailbox.
When I try to access my mailbox on my 5410 system I get a busy signal and it says disconnect. How do I fix this?
  • jedgington Nov 25, 2008
    It was saying cannot retrieve due to multiple logins and to please disconnect.
Fixed
Posted on Nov 26, 2008
How do you reset the voicemail on a landline panasonic kx-t7633?
Jill,
It looks like your extension's voicemail mailbox is not set up. So without the mailbox not being set up, you do not have access to the mailbox. Once the mailbox is created, you should be able to add/change your password. If you are not sure how to create a mailbox, I would check and see if you are able to contact a Panasonic phone tech in the area to take care of your issue.
Mar 09, 2015 | Panasonic Lands Phones
Why made phone early now cant just get busy signals?
Sounds like your phone or line is now short circuit and is holding the line so it appears busy to incoming callers. Try disconnecting the pnone and line right up to the incoming point of your house to find the problem.
Jul 30, 2014 | AT&T CRL82312 3 Handset Answering System...
Nortel startalk one of my extensions keeps getting calls and when answered there is just a busy signal on the other end. What is causing this?
If answering live call and is busy signal on the other end then could be a recording from far end....call a tech in.
If voice mail message is busy signal it could be same as above or Disconnect Supervsision is not programmed on the lines and with the carrier.....this detects when caller hangs up then system knows to hang up, if does not hangup then you get busy signal.
Oct 24, 2012 | NorStar Startalk Flash 2 Phone
How to leave a voicemial message
There are three elements to voice mail; having a Panasonic brand voice mail system, recording the greetings, and setting call forward conditions. Which ones have you done?
The default access to voice mail is extension 500 on the intercom, but we used to use 165. When you dial it, the lady says "welcome to the Panasonic voice processing system". If she doesn't or you're asked for a password, or you have not done the tutorial, then you need to do that and it guides you to the setup of the greetings, name, and password change. After that, you dial *710x 500 (or your VM access) # on the inercom to set call forward to voice mail, with 4 being no answer (my preference since it gives me the option of answering the 2nd call or letting it fall to voice mail), or 5 for Busy/No Answer.
The message manager (mailbox 998) and the system owner (mailbox 999) has the ability to access and change how the voice mail system performs. The owner can change your name for the directory or reset your password and/or
setup or delete your mailbox.
Carl
Aug 09, 2012 | Panasonic KX-T7630 Corded Phone
Can't page to central speaker system. gives a busy signal.Merlin Plus system with Page Pac 20 paging system. All other features work. I think it is the Page Pac but don't know how to troubleshoot.
If you are getting busy signal, something is shorted out.
Disconnect the wiring from the phone systems page port, and try to page. did the busy go away?
if not the port is bad in the phone system. If it did, the page pac is bad...
Apr 30, 2010 | AT&T Merlin BIS 10 Phone
Toshiba DKT3220
sounds like your voicemail is down, try and reboot the entire system and see if it comes back up, if it is a inskin voicemail like a ivp8 tell me what lights are on after it boots and there colors.
Aug 13, 2008 | Toshiba DKT 3010 Corded Phone
MAILBOX BUSY!
unplug the phone and it will reset
Apr 11, 2008 | AT&T E2562 Cordless Phone
Panasonic KX-T7633. Phone message box is busy
This, my friends, is a very popular problem. It is caused by someone else in your company pressing the Message button on their phone while you are calling them or they are calling you. We strongly recommend to our customers that no one presses the Message button under any circumstances. To access your voice mailbox, always dial the Automated Attendant access code assigned by your installer - usually 165 (although on our systems it is "62" or the letters "MB" for MailBox).
You need to dial the Message Waiting Lamp feature code and dial "0" for the extension number. The code itself varies from system installation to system installation, but the most likely numbers are *70 and 70.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Jan 14, 2008 | Panasonic KX-T7633 Corded Phone
Avaya 5400 Series 5410 Phone Logo
167 people viewed this question
Top Avaya Lands Phones Experts
george  peters
george peters
Oloyede Monsuru
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
