Question about Bose LifeStyle 5 Series-III CD Shelf System
Bose lifestyle 5 music system
Dave i have a bose lifestyle 5 music system. no sound but sound from head phones dave u told me it was the r428 resister. but can u tell me is it on the cd music system or on the bass bin. also can u tell me were to find it you said, If you go to the bottom jack socket and trace the wiring back it should take you to R428, one end is connected to the tip of the jack socket the other to the + 10 volt line, but am having no look at finding it at all is it possible to send me a photo to were it is.or can u expliane to me in a bit more to me in detial,thanks alan
  • Zak Apr 23, 2009
    Can some help me fixing my bose lifeStyle 5 music system cd player? I bought it used. First it worked intermittently as whenevr I tried to use volume up/dn on remote the sound is gone. Then after on /off CD player few times this issue did occur again and whole system (CD/Radio) work flawless even via remote. I listen for about an hour and turn off via remote but CD/bass module still connected to AC outlet for whole night. Next evening I tried to connect SPDIF coax output from my DVD palyer to Acoustimass bass module DIN cable, turn or CD player and no sound from cube spk/bass module... CD player still working and I can hear audio via headphone. 3rd issue I noticed that CD player display is alos not working. Any help will be much appreciated. Thanks
    Zak
  • 12 Answers
Alan, The resistor is on the underside of the CD 5 main pcb near the jack socket it is a small chip resistor, but this can be replaced with a small 1/4 watt or smaller resistor. If you provide me with your e mail address I will send you a copy of the PCB layout drawing, the image size is to large to attach
Regards
Dave
Posted on Nov 26, 2008
Problem with Airport express to BOSE Lifestyle
When i play the radio on my bose lifestyle , my radio sounds good. but when i send music with from my apple computer to . airport, and then to my bose lifestyle, the sound just come out from on 1 speaker. not the toher ones, but when i play radio all 5 works....
anybody got a solution??
Alex, Sthlm
Jan 20, 2010 | Apple AirPort Express with Air Tunes
Bose Lifestyle
I have a service manual with complete pcb layouts and circuit diagrams, contact me in case someone is interested.
Jan 06, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
I have a bose Lifestyle 5 music center. I previoously asked what may cause no out put to the sub and was told to replace R428 on the back side of the control module (not the sub) The person stated it was...
If the circuit board has a charred area, you have another problem besides the resistor. A short or overload likely caused the resistor to burn. Probably a blown output transistor(s) or chip(s), which generally short when they fail. This creates an overload in the circuit which burns up the load resistor - probably.
Dec 11, 2008 | Bose Acoustimass 15 System
Looking for the r428 on the Bose lifestile 5
Hi R428 is on the under side of the main pcb near the control jack sockets. It is a small chip resistor but this can be replaced with a 1/4 watt or smaller resistor.If you send me your e mail address I will send you a copy of the pcb layout, the file is to large to attach to this reply
Dave
Nov 25, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
Fix to issue where no output from fixed outputs but headphone output works
07e570b.jpgI took a picture of the board on my Lifestyle 5. Could someone point out which is R428? Thanks.
Nov 18, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
Bose lifestyle 5
I cannot exactly solve this issue but I can make a comment based on investigation. Lots of people have this issue but there are very few comments to help solve the issue unfortunately.
I have the same issue and have been able eliminate various things because I have a second complete Bose Lifestyle 5 system.
It is clear the issue does not lie in the Sub and is related to the Music centre unit. I can use a second identical music centre to power my sub just fine and my broken Music centre cannot drive my second sub.
Now the issue is knowing where to track down R428 in the music centre which is the suggested fix to this issue. I have opened my unit and there are resistors various Resistors in the 400 range but no R428.
If anyone can help with the location of R428 in the Music Centre I would be very grateful.
Thanks,
Jeff
Nov 06, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
No sound
Hi the problem is R428 open circuit, replace with 330 ohm resistor
Dave
Oct 12, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
Bose Lifestyle 5
Hi it could be R428 open circuit replace with a 330 ohm resistor
Dave
Lifestyle 5
Hi, it could be R428 open circuit replace with 330 ohm resistor
Dave
Sep 01, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
No sound Lifestyle 5
Hi the problem could be a burnt out R428 resistor replace with a 330 ohm
Dave
May 12, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
Bose LifeStyle 5 Series-III CD Shelf System Logo
637 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
