Question about Samsung ML2251N Laser Printer
Paper jamed or wrinkled
Thanks in advance for your help
I have in service a Samsung laser LM 2251N Laser printer. The printer wrinkle the paper if the paper is new, but if the peper is used (warm) the printer prints ok.
The wrinkle is in the both sides of the top corner of the paper. this little wrinkle is enough to jam the paper in the narrow paper path.
The fusor assy, springs, rubber rollers, and everything seems to be ok,
I thing the temperature in the fusor is too high. To reduce it, I have installed a variable 200K resistor in parallel whit the temp. sensor, and the printer appears work much better. (the paper wrinkle seldom occur). but it occur.
I havent the service manual and i want some help with this issue.
Jorge arrivasplata
Tumbes Peru, South America
    Problem Solver:
  • 13 Answers
this is the problem of hot roller replace it paper jam problem will be resolved.
Posted on Dec 03, 2013
5 Suggested Answers
  • 1362 Answers
SOURCE: Samsung ML 1210 Laser Printer
check here
Posted on Jul 25, 2008
  • 499 Answers
SOURCE: Samsung ML 1510 LAser Printer
check the spring if it push the roller well or it's weak also check ur paper if its high quality to be rolled
Posted on Jun 12, 2009
  • 220 Answers
SOURCE: Wrinkled Paper
Check paper path,especially near fuser.If all ok fuser is faulty.
Posted on Jul 13, 2009
  • 214 Answers
SOURCE: My paper is getting stuck on roller for laser printer scx-4521f
open the front door and take the cartrige out.
if it jams at the black roller. you must clean the pickup roller.
you will see it at the back of the unit in the center.
Posted on Oct 06, 2011
Why does my printer produce wrikled printouts
Your paper feeder is only working on one side causing the paper to try to go sideways. This will wrinkle the paper just like it is fed in crooked.
Jul 19, 2014 | Dell 1160w Mono Laser Printer
Paper is getting wrinkled as it comes through the printer
If the wrinkles are small and appear to be pressed into the paper, then the problem is most likely with the fuser assembly. Check it for roller damage or other problems and replace.
Sep 24, 2012 | Samsung CLP-510 Laser Printer
Wrinkling Laser Paper
Sounds like something is either wrong with the rollers, something is stuck in there or you are using the wrong type of paper.
I suggest you take a peek inside there and see if there is anything noticeably wrong inside. If not then look up what type of paper it needs.
Jul 10, 2009 | Xante Accel-a-Writer 3N Laser Printer
Wrinkled Paper
Jul 10, 2009 | Samsung SCX 4521F All-In-One Laser Printer
My Dell 1100 keeps wrinkling and tearing the paper
Depending on wear the tear is at determines the issue. The wrinkling paper and the look of your printer sounds like some sort of fuser issue. Recycled paper is more likely to wrinkle and the grain can cause paper to wrinkle as well. The Long grain paper is up and down the sheet and short gain is side to side on a sheet of paper. If your printer is on a long grain setting and you have the pages coming out sides ways or vice versa then your print outs can wrinkle.
Jun 22, 2009 | Dell 1100 Laser Printer
Wrinkled jammed paper
paper weight to light change it.
Sep 11, 2008 | Brother HL-2040 Laser Printer
Wrinkled paper
Try checking the fuser unit inside the back of the printer. Open the door and pull the paper path tray down. You should see an orange vinyl looking roller. If is has wrinkles it probably needs replacing. I have replaced two on my printers and that corrected the wrinkling problem. You can get them on ebay.
Oct 24, 2007 | Brother HL-5250dnt Laser Printer
Phaser 7700GX Color Printer prints wrinkled pages!
when this occurs the problem is most of the time with the transport roller, fuser / fixing assembly roller.question is the image still toner only and not fused to the paper.
In these areas there is offen a jammed and not removed piece of paper dislodged in the paper path or jammed in the fuser or the transfer rollers teflon coating has perished inspect the areas carefully and remove any found if the unit still is faulty (fanning of paper the fuser would be the first to be replaced are past there usable life) if so then Post a reply
Sep 10, 2007 | Xerox Phaser 7700 Laser Printer
Samsung ML2251N Laser Printer Logo
390 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
