Question about HP LaserJet color laser printer
Hp color laserjet 4700
I own a color laserjet 4700. I turned it on the other day and it wont boot all the way to show ready. it stops running after showing the memory size. Can anyone help me resolve this. Thanks
  • subimprz Jan 19, 2009
    I own a color laserjet 4700. The display stop after the memory test when I turn it on.
    I tried to remove the memory : The display light up but don't show anything.
    I tried to remove de formatter board : The display does'nt light up.
    I tried to remove the CF card too.
    The fan start, I can print the engine test page and all leds are blank.
    Can anyone help me?
    Thank you very much and sorry for my english, it's not my first language.
  • Anonymous Mar 19, 2014
    it's an intermitent problem
  • 624 Answers
Evening eavotri, -The first thing to do is pull out the EIO card and all of the added memory. -Restart the printer and listen for the fan to come on and see if there are any changes in the boot process. If it boots then starting with the memory reinsert one of the modules and reboot. Repeat the process till you find the culprit. You may find that after reinserting everything its still working. You may have lucked out and just had an EIO card or memory module that had a bad contact or you may have an intermittent fault that will reappear again. If nothing has changed can you give me more details about what you observed or heard during the boot process: - Does the fan come on shortly after you power on? - What displays during the boot process besides the memory check? -You mentioned the last thing you saw; does that mean the LED went blank? Let us know what you find out and don?t forget to rate the posting.
Posted on Jan 06, 2007
Error code 59.90 on color laserjet 470
59.9 is SCANNER MOTOR ERROR.
It is a rather tough part to service.
The entire scanning assembly would have to be replaced.
see
HP Color LaserJet 4700 Series Printer Numerical Control Panel Error...
Nov 01, 2016 | HP LaserJet 4700 Printer
Error code 59.90 on color laserjet 4700
Transfer belt motor error, either a bad motor or a bad transfer belt.
Hp color laserjet 4700 will not print in color
do self test - configuration print, if ok check your print driver settings
Jun 02, 2014 | HP LaserJet 4700 Printer
Need only black to print from HP Color Laserjet 4700 printer
on the print page just before printing , go to properties and make black the default color
Jun 04, 2017 | Office Equipment & Supplies
49.00FF service error hp color laserjet 4700n
This error is most often caused by out of date firmware on the printer.
Power off the printer and it restart and it should come to ready. If the error reoccurs, make sure that you have any print jobs in the queue of your computer cleared. If it still does not start without the error, unplug any network or usb cables and restart again. Once the printer is at at ready, use the control panel to go to the information menu and then print the configuration page. The firmware date code will be on the left hand side. Current firmware is 48.180.9.
If the firmware is out of date, see the link posted below to download the firmware update. Chose the easy firmware update as this is the most straight forward way to update the firmware. Once downloaded just double click the file you downloaded and it will run and ask you to chose the printer you want to update. Pick your 4700 from the drop down menu (should be fires option). Then update click update firmware.
You can find the current firmware here
Aug 09, 2011 | HP LaserJet 4700 Printer
Color Laserjet 5550dn code d'erreur 54.15
54.15 PRINTER ERROR Description There is a problem with the Yellow CPR sensor. Action
  1. Turn the printer off, and turn it on again.
  2. Clean the color registration detection sensor above the black print cartridge if the error does not clear.
  3. If this message persists, contact HP.
Jan 05, 2011 | HP LaserJet 4700 Printer
I have hp printer 4700 color laserjet .i installed new image transfer kit but counter not reset automaticaly .plz help me how i can reset manually . thanks
What I recommend you to do is turn off the printer, disconnect it from main power for a couple of minutes and then connect back and then turn on and counter suppose to reset by itself.
Feb 27, 2010 | HP Color LaserJet 2600n Printer
How to replace image fuser kit for hp laserjet 4700n
turn off the machine. open upper front cover. remove the old fuser and insert the new one. turn on the machine and enjoy your printer with new fuser kit.
Jan 20, 2010 | HP LaserJet 4700 Printer
HP Color LaserJet 4700 Not Booting
Check if fuser and toner cartridge and image transfer belt are properly installed. Also check if covers are properly closed. One more thing, disconnect printer from main power for a couple of minutes and then turn it back on. Hope this helps. Maybe you can tell me what happened before this started(ex. paper jam).
Oct 24, 2007 | HP LaserJet color laser printer
HP LaserJet color laser printer Logo
477 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
