Question about Cameras
Sony cybershot dsw50 error flashing e;91;01 flash not working at all
  • 1 more comment
  • sharyn1 Nov 27, 2008
    this would obviously need to be done by a technician, which is costly .. any other way round about it?
    its a sony cybershot DSC-W50. The flash doesn't work. error code E91:01 flashing on screen
  • sharyn1 Nov 30, 2008
    error flashing E91:01 on dsw-50 sony cybershot flash not working, tried tapping the top, changing the battery, initialise back to clock, reset etc still nothing.
  • 586 Answers
    According to the service manual your camera flash unit get malfunctioning.Therefore you have to replace the complete flash unit assymbly,Here the part number is given below:
A-1166-208-A ST-133 BOARD, COMPLETE
For this you have to contact any SONY SERVICE CENTER nearby to get the said part. Get it from there and replace it by yourself if you can.Otherwise get the assistence of SONY technicians.
Thanks for using fixya.
Posted on Nov 30, 2008
  • 535 Answers
This earror come when flesh curkit has been not workig u need to replace a flash
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
If reset, menu, battery power on/off will not work, let's try hardware tricks. Get hold of a can of compressed air. Use the the narrow tube/nozzle. On every cranny, battery compartment, openings, space, blow compressed air. This is of course as earlier stated, nothing else works.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 27, 2008
  • Louie  Role
    Louie Role Nov 30, 2008
    Hi again,
    You initially posted this problem here on Oct 11. On Oct 17, another member of the site responded with a proposed solution and was rated with a "Helpful". Have you tried the same solution?
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
  • 10,594 Answers
E:91:01 is Flash error code and this error code comes when Flash Circuit doesn't work.
Camera needs Flash Circuit replacement and part number is as follows...
Above said Flash Circuit is available in Part Store.
Good Luck.
  • Shahid Electronics
    Shahid Electronics Nov 30, 2008
    I sent you complete solution of DSC-W50 Cybershot. Please check it
  • 659 Answers
Try these steps ans see if it works.
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
  • Cameras Master
  • 19,396 Answers
Ttry removing the memory card, and resetting the camera to factory settings first, this sometimes can sort out the problem.
  • Ginko
    Ginko Nov 27, 2008
    To reset to factory settings, go to the toolbox icon and select the "initialize" command, click ok and perform a master reset.
    This will reset the camera to factory settings and should clear the message.
  • Ginko
    Ginko Nov 27, 2008
    Here is an alternate solution to flash error.
    Try first going to toolbox and selecting the "initialize" command, then click ok and perform a master reset.
    If the reset does not work, then the flash is really faulty.
    Try first performing the reset procedures, usually they sort out the flash error problem.
    Sergeant:
  • 291 Answers
Check out if battery is fully charged or also try replacing the battery.or it could be also because of faulty lens.just tap the device for few minutes on the top side. and check .or taking irt to the repair center is advisable. thanks,.
  • 837 Answers
1. Turn OFF cam
    Sergeant:
  • 306 Answers
1. Turn OFF cam
  • 790 Answers
Hello!!
Try hard reset once- Switch off ur camera , remove the batteries and press the power button for few seconds. then put the batteries back and try powering on!!
I have a camera sony cybershot DSC-W350 and flash is not working. And I receive an error message E:91 01. What do I do?
Hi. Thanks for your question.
To get your camera back in working order you need to reset it to factory settings. Please click on the link below for a video from Sony website on how to perform reset.
http://esupport.sony.com/perl/tutorial-display.pl?tut_id=374&mdl=DSCW50
Thank You for using FixYa.
Jan 14, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cybershot DSC-W55 flash not working Code
GO TO SETUP MENU, SELECT THE TOOLBOX ICON 1 AND SELECT INITIALIZE CLICK OK.
Aug 10, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Flash error on sony cybershot
Try to resetting (initializing) it. But if the problem repeats soon, look for service.
Aug 30, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Flash is not coming and error code is E:91:01
Hi!
E:91 is flash error. Could be a dead flash fuse on the main board or bad flash board. Contact your local Sony service center or if they ask too much, feel free to contact me at toms.safranovs@gmail.com
I work in Sony service center.
Tom
Jul 17, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
I use w210 Sony Cybershot! Error E:91:01.
I use w210 Sony Cybershot! I was taking pictures out in the sun, when I saw smoke coming out the camera and the camera become very hot. I also saw that I was using the camera bymistakely in the twilight mode out in the sun. And since then I tried intitializing it but the Error E:91:01 and flash symbol wont stop blinking. And flash Seems to have stopped working. Please help me to solve this problem
Jul 14, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
Flash of sony cybershot dsc-w200 is not working
i think i had the same problem, if u press the home button and then press shooting then hit the flash button on the right hand side it should change the mode.
Jun 22, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
Flash won't work on Sony Cybershot T-70
multi shot mode would not have flash.
change back to single shot mode.
Nov 06, 2008 | Sony DSC-T70 Digital Camera
Flash doesnot work how does one charge the flash on a Sony cybershot DSC-H3
Some of the popup flashes seem to be defective on this product. Mine is. I am returning mine under warranty.
May 03, 2008 | Sony Cybershot DSC-H3 Digital Camera
Cameras Logo
700 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
