Question about Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore Quietguard 3 has mold and is dirty inside
I have had problems with this washer from the start. I have had the motor replaced and Sears repair out twice. On the normal wash cycle it runs for hours and the dishes still aren't clean. After running the dishwasher is dirty inside and now has mold growing inside. I no longer use it, but can't afford a new one at this time.
    Problem Solver:
  • 4 Answers
G'day, I have a Miele Dishwasher and I have only had one small problem with it in the 12 years I have own it. That was due to moving house, a bit of fluff had moved and was blocking an outlet. once cleaned with a brush it now works like new again. Best dishwasher on the market, made to last 20 years.
Posted on Nov 26, 2008
Changed door switch on my kenmore h2 plus cause of error code and it still wont work
Whirlpool & Kenmore Dryer Repair #01 - Won't Start or Run ...
? 8:50
Oct 19, 2011 - Uploaded by canyonman1963
This one deals with testing and replacing the door switch. ...sears wont work wont spin wont wash wont heat wont start fix repair bad noise noisy ... how to change a 4 to a 3 prong cord, to figuring out my door switch problem.
Dryer Door Switch - How To Replace - YouTube
What to do when your washer won't fill, start or run - YouTube
? 2:00
Jun 20, 2012 - Uploaded by searspartsdirect
So if my washer wont start just call Sears. .... Bad sears mykenmore is only 2 years old, fill take 30 mins,,,wash 50 mins rinse never spin never,, ...
Nov 28, 2015 | Kenmore Washing Machines
Kenmore elite E3t F11 error code
The "F11" fault code will display if the Motor Control Unit (MCU) has an internal failure; repeating under or over voltage, or over current conditions. If failure occurs during high speed spin the door unlocks after 3 minutes. The MCU (Motor Control Unit) is located beside the motor. See images below. Key #13 is the CCU and key #1 is the MCU.
The CCU (Central Control Unit) is located under the top along the side panel.
I recommend checking for loose wire connections at the MCU, CCU and motor. If you do not get any motor action at all, the MCU has likely failed.NOTE: Disconnect the power cord from the power source before removing the top and lower access panel. I recommend calling a service technician to diagnose and repair your washer.
Parts can be looked up and ordered at Sears PartsDirect
If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website:Sears Home Services .
Dec 16, 2012 | Kenmore Elite 45986 Front Load Washer
Kenmore Ultrawash Quietguard Deluxe Problem
kenmore washers nothing but problems, my washer says clean and will not do any cycles...... less that 2 years old
Oct 21, 2009 | Kenmore Dishwashers
Kenmore quietguard standard wont start.
is there any function at all? if not, check thermal fuse located inside near control panel, check and enter your model # to show how to take it apart. If it has functional display lights, replace main control board after ohm test on wash motor and fill valve.
Jun 25, 2009 | Dishwashers
Washer won't start flashes F dL
It is most proabley your CCU .............replacing door lock will not solve the problem
May 09, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Noise from spin dial...won't spin
Remove the cabinet.
Remove the motor.
Replace the direct drive coupling.
Check the pump for any blockage.
Mar 10, 2009 | Kenmore 22422 Top Load Washer
Bad mold and smell from washwe
i have repaired appliance most my life i tested soaps and softer,at our own family shop,i can tell you that washers do not make mold or bad smells either does cloths its what and how much product that you are pulling in the washer that is molding and smelling and it stays in cloths building up load after load,i have a kenmore he3t front load washer i use 1/3 cup powdered only.armen hammer only. non he washer inside is spotless smells clean and fresh all the time, you will need to clean yours inside out with bleach then use affresh weekly switch to 1/3c powered soap
Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Flashing F6 Error Code
motor controller board in bottom
Nov 11, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Front load washer #417, basket assembly fell out
hi. thanks for the question. i would go to Sears customer service .and demand a replacement washer
Oct 05, 2008 | Kenmore Elite 45986 Front Load Washer
i have the same onebut fridgeair but mine would only wash and nothing else and it turned out to be the motor was weak
Apr 14, 2008 | Kenmore 44042 Front Load Washer
Kenmore 24 in. 15689 Built-in Dishwasher Logo
161 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
