Question about Kenmore 96532 / 96534 / 96539 Electric Kitchen Range
Not a 965 problem but a 956 problem...
The oven light, clock and indicator lights work but my oven and burners do not. i checked the breaker and it was on. i tripped it once and a burner came on, until i turned on another burner. now, i am back where i was... burners and oven not working. model # is 790.95662102, radiant range, free standing. any help would be appreciated. thanks scott
I have a kenmore gas range and whenever I turn on the broil or the oven and set it to 350 or above or below, after 2 seconds the F1 signal starts flashing, followed by a steady beep. What may be wrong?
Posted on Feb 12, 2009
    Scholar:
  • 76 Answers
Shogan, Most likely, the problem is with the circuit breaker. It became too weak for regular load. Replace the circuit breaker and I believe it will solve the problem. Gendos....post back
Posted on Jan 07, 2007
My stove is a GE and everything works but the burners and oven.
check your breakers everything you said means not enough voltage
Apr 05, 2014 | GE Stove/Oven/RanSurface Burner Knob -...
No heat from burners or oven after relocating stove
Hi Ron - From what you have described if neither the burners nor oven turns on make sure the electrical connecting is 240V. The oven light and clock portions only required 115V. The clock and oven light working may indicate an electrical circuit breaker supplying the range is tripped or a fuse is blown. Confirm household circuit is correct and the range cord is properly wired to the terminal block.
Sep 16, 2012 | Frigidaire Gallery GLEFM397DS Electric...
Oven element blew.no top burners working.replaced oven element.nothing works except clock and oven light
Check your main fuses, it sounds like you are only operating on 120 volts.One of them is blown.Or if on breakers, switch stove breaker off then on again.
Mar 06, 2011 | Kenmore Kitchen Ranges
We recently moved, when we got to our new house we plugged in our stove. We turned on the burner and it didnt work, we tried the other three and they didnt work either.. Finally we tried the oven but there...
i would first try the breaker it sounds like you only have half the power coming to unit and the light and clock will work but the heating componets will not as they require the full 220-245 volts
it sounds very odd that everything as far as burners and elements are out but you have a clock display and light... you have lost one of the legs of power somehow...either the double breaker is not fully on and may require turning off oven breaker and resetting or half the breaker has failed... a sure way of testing would be to pull out and with a volt meter test to see that you have 220-245 volts coming to oven,,, hope this helps out repost if anymore questions...
Feb 07, 2011 | Amana Kitchen Ranges
Hotpoint electic stove, the burners and the oven not working
Is there any sign of life? Does the oven light come on or does the clock work? Just for kicks, go and reset the breaker - it should be a double breaker for a 220V appliance - sometimes half will throw and still leave 110v that will run the light / clock.
Jul 26, 2009 | Hotpoint RB757 Electric Kitchen Range
Frigidaire Oven - lights are on but no heat from oven or burners
You must check your incoming power for 220 volts. You have lost one leg of your power. Either a bad breaker or bad wall outlet or bad range cord.
Jun 26, 2009 | Frigidaire Ovens
The indicator lights for the burners and the clock work but the burners and the oven do not work. This is a whirlpool range.
Check the recepticle it is pluged into for 230-240 volts on the outer inlets. You may also have to connect your nuetral wire to the ground wire in your breaker panel and to the unit. The problem is from the power supply. Let me know if you have any questions.
Phil
Apr 11, 2009 | Kitchen Ranges
The indicator lights and clock on our glass top slide in stove work, but the burners and oven do not heat
From what you are describing, the power to your stove is incorrect. The diagram indicates the voltages that should be present at the receptacle, I suspect one of the 110 volt legs is bad at the receptacle or circuit breaker. The clock operates on the good 110 volt leg. The burners need both 120 volt legs to be good because the burners and oven need 220 volts to work.
Jul 11, 2008 | Frigidaire Kitchen Ranges
Kenmore 96532 / 96534 / 96539 Electric Kitchen Range Logo
207 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
