Question about Kenmore Elite 45986 Front Load Washer
We have a Kenmore Elite HE4t front load washer and we keep getting an error message in the middle of the wash cycle
  • 1 more comment
  • smenimis Nov 30, 2008
    I too have a Kenmore Elite HE4t Washer and every time I start a load it gives me an error code of F5. I have misplaced my manual and do not know what that code means. I need help in trying to fix it myself, avoiding any unnecessary costly repairs.
  • JOHNNY RAMIREZ May 11, 2010
    what does it say f??
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    What error code are you getting? This information would be necessary in determining the fault.
  • 15,935 Answers
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes:
* Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
* Check the Drive Motor
* Check the MCU
* Check the Wire Harness
begin troubleshooting right at the motor. Why start there? Because the motor is one of the prime suspects and it's easy to check. Remove the back panel and unwind the belt from the drum pulley. Now turn the motor pulley (sans belt) by hand. If it doesn't turn smoothly and easily, you have a bad motor.
If the motor pulley turns smoothly and easily by hand, next step is to run the motor with the belt still removed from the motor pulley. If the motor seems to run fine that way, put the belt back on and run it again. If the motor won't run under load (with the belt on), then that's another sign that the motor is bad.
Suppose the motor turns easily and freely by hand but won't run either with or without the belt. This is a more subtle condition because we're probably dealing with a bad MCU or flakey wire harness somewhere between the motor and MCU, or between the MCU and the CCU.
One trick that often works at this point is to remove and reinsert all wire connections at the board and motor. This tends to clean the small amount of corrosion that will build up on the connections. After you do this put the machine into a service cycle (see the instructions in the tech sheet found inside the unit or you can ). Part of the service cycle is running the motor at certain set speeds which checks the tach.
If you've removed/reinserted the wire harnesses and still no joy, then usually the problem is the MCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 26, 2010
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore HE4T won't stop on the Spin Cycle. Stays
Replaced the relays with the 16Amp rated ones from Digitel.
Aug 15, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t stopping in mid cycle with F abd DL errors
See Phoebe 112 latest solution! This is a common problem with these washers. For a quick fix you can usually get it going again by unplugging it for 30 mins. so the computer will reset. You will hear a slight buzzing noise when it resets. If it keeps doing it, go to the comment for Feb. 14, 2009 and try that if you are handy. Unplug the machine before doing any of this as with any machine that is electric or you will probably get the shock of your life.
Feb 14, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t washer won't spin
The motor controller board is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
New Kenmore Elite Front Loader will not get past 'Sud' cycle,
Hello wheeljc; I had the same problem when I purchased my Kenmore Elite in 2006. I have a HE4t front load. It's possible that you're using to much detergent, if you're using HE liquid it only requires a small amount and does a very good job.
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore he4t washer shows f-11 error
F-11 // WILL THEN APPEAR FDL CODE DOOR LOCK LOCK FAILURE, F-11 COMMUNICATION ERROR REPLACE MAIN CONTROL,, JUST REPL 3 TODAY ....
Nov 28, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore elite error code
possible electronics failure. my HE4t has completly gone dead at the control panel after displaying error codes. A class action law suite is in the works on the HE3t HE4t machines.
Aug 20, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4T Front Load Washer
These machines have a filter you should clean depending on your usage. It is usually at the front bottom - a small door. This is a filter before the water gets to your outlet pump to be siphoned out; it is there in order not to clog up your pump.
Jun 12, 2007 | Kenmore 44072 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
74 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
