Question about HP Computers & Internet
Where do i plug in a second hard drive on the motherdoard on a hp pavilion a1220n
    Problem Solver:
  • 13 Answers
It will be either a SATA port which is small approx 1/2cm by 2cm or a PATA port which is a whole lot larger approx 1cm by 7cm and has little pins. If you choose PATA you will have to configure it as a SLAVE to your first hard drive. This is achieved by setting jumpers located by the PATA connector port on the hard drive. There usually is a little diagram on the hard drive itself. Your first drive needs to be master. Cable select usually sets the farthest drive on the cable to master and the closest as slave. Just set as master and slave to be safe. This is not needed on SATA drives.
Posted on Nov 25, 2008
    Sergeant:
  • 237 Answers
When you open up the casing (make sure you ground yourself), there should be a ribbon cable marked master and slave. The master is your primary drive, so you would connect the slave to your secondary hard drive. Have any other questions, let me know
INSTALL A NEW HARDDRIVE TO MY HP PAVILION A1220N ERROR MESSAGE COMES UP BOOT MGR IS MISSING
You need to install an operating system like windows XP, Vista, Windows 7 or Linux OS. Your hard drive is blank now and needs programming. If you have a friend that can clone your old drive then they will be able to copy everything from your old drive as it was to your new one. Might need to contact a local computer technician to re-install windows for you if not sure. Also you need to consider the price of windows XP, Vista or 7 if you don't have a copy!! Good luck!!
Sep 28, 2012 | HP Pavilion a1220n (A1220NED904AA) PC...
I want to upgrade CPU
Upgrading CPU is usually more complex than just upgrading memory or hard drive on the computer! If you really need to upgrade CPU which is located on mother board!
Sep 02, 2011 | HP Pavilion a1220n (A1220NED904AA) PC...
Hp pavilion a1220n comptur will not start unplugged unit and when i plugged to back in it would not start
Do you see anything on the monitor screen? Does the tower make any beeping noise or clicking noise, or does the fan tries to start up when you power the computer on? Are the cables connected properly?
If you see anything on the monitor screen, or if you hear a beeping sound, let us know so we can diagnose further.
Aug 07, 2011 | HP Pavilion a1220n (A1220NED904AA) PC...
When I power on my HP Pavilion a1220n, the HP symbol comes up on the monitor, then it goes to a black screen with a smll blinking cursor for a few seconds, then...NOTHING. The power stays on but the screen...
You could check to see if the memory chips inside have dirty contacts. Happens often, basically you unplug it, remove the side cover, find the memory chips, try to remove them but basically just work them in and out a couple times to clean the contact points, reinstall and it might work. This happened to mine this am, worth a try.
May 12, 2010 | HP Pavilion a1220n (A1220NED904AA) PC...
Computer will not boot
Hello.
If your computer will not boot try to first boot your hard drive in the BIOS. Make sure that the hard drive are inserted correctly replace the power cable in your hard drive also the SATA or IDE cable.
Regards
ICmanServer
Jul 31, 2009 | HP Pavilion a1220n (A1220NED904AA) PC...
Fatal Error on HP Pavilion a1220n PC??
Probably your system crash you should perform a reformat in your computer, sorry bout that, probably you should have some backups by having partitions in your hard disk ^^
Apr 24, 2009 | HP Pavilion a1220n (A1220NED904AA) PC...
Hard Reset for HP Pavilion a1220n
Press F10 when you start the computer and follow the prompts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 23, 2009 | HP Pavilion a1220n (A1220NED904AA) PC...
Computers & Internet Logo
79 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
