Question about Dacor Preference SGM466 Gas Cooktop
Decor / Pinnacle RV 46 Unit
After a power outage, when the power came back on, the unit was humming on and off. The buttons on top of the unit started lighting up randomly as if the computer was doing some sort of internal check. All the buttons were lit at once at one point. Now, only the filter clean and the timed stop buttons are lit. Pushing any botton has no affect. The fan is remotely mounted at the exterior of the house. The entire unit is dead. What do you suggest?
2 Suggested Answers
SOURCE: Pinnacle Raised Vent System #RV36 or RV 46
Ours started doing the same thing. I got it to start working again by gently holding down the up/down button until it started to move. After doing this a few times it started working normally again. Also the keypad can be locked and unlocked by pressing the low and high buttons together for 1 second.
Posted on Mar 01, 2009
Miele Fault Code FE 30
I have the same FE 30 problem on my KM5733 Induction cooktop whenever it's circuit breaker/isolation switch (in my house's fuse box) has been turned off and then on again. I have turned in back on after waiting a day or longer (figuring it needed to reset itself?) and the results have been hit and miss and I have had no idea why it would work sometimes and not others. Needless to say, I've trolled the net looking for answers and Miele online support is useless (unless you're ok with shelling out loads of cash to have a technician come by) and I still haven't heard back from them after lodging an enquiry.
What I have discovered from this and other forums is that these units do not like being attached to a power source which has a voltage significantly above the amount stipulated in its specifications (for my unit it's 230 Volts). After reading this I used a voltage meter to measure the voltage in one of the power outlets in my house (I have a really cheap meter I'd bought a while ago at an electronics retailer). Sure enough it was above 260 Volts which is totally beyond the range it's supposed to be for where I'm living.
The thing is, I know the unit works just fine provided it has been turned on and it doesn't get the initial FE 30 error (it's almost like you have to get past an initial voltage check and then once it's going everything is ok). If the voltage is at an "acceptable" (whatever that may be) level when it's turned on, it will turn on and then stay on even if the voltage goes up afterwards (which it obviously has done during the time from when it was last switched on until recently).
How did I get it to work this time? well I thought of ways to reduce the voltage to the unit and came across all sorts of stuff on the net including powerbox voltage reducers, optimisers, blah, blah... I thought this is total rubbish and I'm going to ring the power company and complain about the voltage being so high when it's not supposed to be. I then thought back to my old high school physics days and remembered that there's a relationship between voltage, current and resistance. I then thought the voltage to the induction cooktop (as well as to all the other power outlets/circuits in the house) is likely to drop if I plug in and turned on a lot of high resistance electrical appliances.
Sure enough, when I turned on the kettle, toaster, clothes dryer, computers, televisions, electric oil heaters, lights and dishwasher, the voltage in the power outlet I'd been measuring went down from 260 to 235 volts.
I then turned on the power to the induction top back on and it turned on and with no FE 30 error!
I boiled some water to make sure everything was working ok (it was) and then I turned off the induction top and all of the other devices I'd switched on.
Still no FE 30 error! Great.
I double checked the unit by turning it back on and boiling water again and it did it with no problems. I then turned the unit off and measured the voltage in the power outlet again and sure enough it was back at 260 Volts. Hurray!
I'm now going to ring the power company and make a complaint...
Mar 22, 2013 | Cooktops
My electrolux iduction cook top sends error across the whole bord when I put anythng on the inductoin burner
You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds. This will clear most false error codes. You can disconnect power by flipping the circuit breaker off and back on. If the error code does not clear, then the unit more than likely can be experiencing an issue with the EOC and user interface board. This is not a typical do it yourself job; please consult a professional or your manufacturer.
Sep 11, 2012 | Electrolux 36" Electric Hybrid Induction...
Our counter top stove top has no lights at all and will not turn on.
I know it sounds silly but make sure that the unit is plugged in or has power running to it. Many times people encounter little problems that cause big headaches. Like I said make sure that you have power to the unit itself and go from there. If the unit ha power, then it may be that you have a bad power distribution board or that you may have blown an internal fuse. Check the obvious and if it still doesn't work, contact a qualified technician for help. I hope this helps. Good luck.
Jul 20, 2010 | Cooktops
Downdraft vent unit is stuck halfway.
You'll have to remove it and manually reverse the drive gear. Hopefully, it didn't get stripped.
May 07, 2009 | Thermador SGS36GS Gas Cooktop
Need to replace 46 inch electric cooktop made by dacor
I'm in the same boat & can't find anything that will fit my existing 46"wide X 20.5" height Decor electric cooktop. Would love to know if anyone else has found something.
Mar 20, 2009 | Cooktops
Viking professional induction cooktop large burners defective
Throw your circuit breaker that leads to this unit for a few seconds, then reset the breaker This unit is very sensitive to power fluctuations.
Mar 07, 2009 | Viking 37 in. VECU165 Electric Cooktop
Stove top in lock mode
Hold your finger or thumb on the red light for a few seconds, and you will hear three beeps. This tells you that the lock is off. If the light is not on, do the same and there will be three beeps, and the light will come on, telling you that the lock is back on.
Feb 18, 2009 | Dacor Millennia ETT304 Electric Cooktop
Dec 08, 2008 | Dacor Preference SGM365SS Gas Cooktop
Dacor 46 inch 6 burner cooktop
The cost of the parts you want t o replace will usually exceed the price of a new cooktop.
Jun 08, 2008 | Dacor Preference SGM466 Gas Cooktop
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Dacor Preference SGM466 Gas Cooktop Logo
166 people viewed this question
Top Dacor Cooktops Experts
Mike
Mike
ray gallant
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
