Question about Brother MFC3240 Multifunction InkJet Printer
Brother mfc3240c - paper doesn't load due to ink spill
Hello!
I was told that, due to ink spilling when I moved the machine to take it to a repair center, the paper won't load because it's sticky inside. The person who repairs them said that it's very difficult to clean, he's tried and may have to try some more but isn't sure he can repair it.
Any suggestions?
Thanks
Hana
    Scholar:
  • 162 Answers
There is no option for that but you can try this: Tell the person who repairs your printer to clean your machine with cami cal or any liquid after deassembling it. after that reassemble it.
I think this will help you.
Posted on Nov 25, 2008
Paper comes in black, now what can i do ?
I suggest that you clean the printhead. It is an ink spill or dirty ink head.
David
Jun 22, 2013 | Canon LASER SHOT LBP-1210
Hello, I got an error message 5C10. What does that
I just had this error message appear on my computer screen and the 6A00 on my MP830 printer at the same time. I heard this error mean a few things (paper jam, ink carriage stuck), though not sure what it does actually mean. I moved the carriage back-and-forth, blasted compressed air and checked for paper jams. When nothing worked, I looked inside and saw a lot of spilled ink, I'm guessing from not using genuine Canon ink. I blotted the inside with paper towels (use gloves!!),especially the far right, and took out the ink cartridges and blotted the carriage. I replaced everything, powered the printer off and on, and it worked fine. I would suggest first to slide the carriage back-and-forth and look for paper jams before cleaning the ink. Hope this works for you.
May 25, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Brother MFC-8220 leaving ink on printed docs. How do you clean that?
That's usually a bad toner cartridge that dumps too much toner per print. Buying a new toner cartridge should fix it. You may need to wipe up a little spilled toner inside. Just use a dry cloth, and be very careful around the little black levers that stick up to detect the paper.
There are other manufacturers who sell toner for these, but some of them have toner inside that's so hard to stir, it breaks the gear in the machine. That makes a very expensive repair for the little money you save on generic toner.
Dec 03, 2010 | Brother MFC-8220 Fax
Can't fax or copy on brother mfc3240c machine
Sounds like you may have a small obstruction in the scanner feed. This would inhibit making copies and sending faxes. Lift this section up slightly to inspect for small pieces of paper or dust. Blowing it out with compressed air would also be a good idea.
Aug 20, 2009 | Office Equipment & Supplies
Black with coloured lines
The machine needs to be disassembled and cleaned. Evidently, some ink or toner spilled onto the drum or the paper loading mechanism. After putting it back together, realign the heads and do a test print. It should be good as new.
Jul 07, 2009 | HP PhotoSmart C4280 Laser Printer
Trouble with printer
your copier cartridge drum unit charger wear is broken so drum are not charge re-weare then solve it
Jun 24, 2009 | Brother MFC-5840CN All-In-One InkJet...
We have a Sharp 1641CS copier will not feed or copy
Well one reason the Cartirdge is spilling is due to the cartridge backing up with toner everytime it tries to print, it misfeeds cause the paper feed tires need to be replaced,
May 29, 2009 | Sharp AL-1641CS Copier
Hi! the number one on the keypad of my brother fax machine keeps sticking. It is pushed in lower than the other keys. Is there a way I can fix this myself without calling a repair guy?
Probably not a self repair. It most likely is the membrame under the actual button. Any liquids spilled on it? If liquid spilled it may dry out, and it may not. Check with the repair people about the cost of the repair and the price of the control panel before agreeing to a visit.
Dan
Dec 29, 2008 | Brother IntelliFAX 4100 Laser Fax
Ink Cartridge
Most likely there is toner that has spilled inside the machine... try to use canned air and blow out the fax machine.
Dec 11, 2007 | Brother MFC 4350 All-In-One Laser Printer
Brother MFC-3220C plane paper fax
unfortanatly error 41 means that the printer head needs to be replaced. Got this from the horses mouth. I called the internnational tele # at 1-800-284-4329 and they told me you would need to take in the machine to have this repaired. You can look in your book for a # to find a servicer or go to http://www.brother.com Good Luck
May 12, 2006 | Brother MFC-3220C Plain Paper Inkjet Fax
66 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
