Frigidaire FRS3R5EMB Side by Side Refrigerator
Problem for Frigidaire FRS3R5EMB Side by Side Refrigerator
Frigidaire side by side
By vagirl on Jan 05, 2007
My frigidaire side by side model no FRS26LF7DS7 has suddenly stopped cooling. The fan still runs and I hear a click and the condensor comes on and stays on for a minute then a loud click and it shuts off again. I had never heard the click before when the refrigerator came on. Up until this morning it was cooling fine. I can tell the click is in the switch connected to the condensor motor.
Comments:
Jan 06, 2007
- Thanks so much. That sounds exactly how my refrigerator is doing. Someone is supposed to come and look at it, but at least I have a place to start. Thanks again.
Same Problem
May 05, 2009
-   my frigidaire FRS6R5ESBL side by side refrigerator stop cooling-   Guest
Aug 10, 2008
-   my fridgefaire rerfig is not coming on at all. getting powed tocircuit board and light comes on but nothing else works, what is causing it tonnot energise the fan or compressor????????????????-   skyflyer1
Jun 30, 2008
-   FREEZER NOT COOLING
REFRIG ONT COOLING -   CRR250
May 22, 2008
-   I have the same problem but it sounds like my compresor is only staying on for 10 seconds.an I have a 2003 Frigidaire modle frs26r2aw4 -   gloriaj34
May 13, 2008
-   our refrigerator is warm on the food side ? can you help me-   armymom-6
Best Solution
posted on Jan 06, 2007
Helpful)
HVACRH20
Rank: Wiz
Rating: 85%, 1420 votes
The compressor sounds like the start device went bad. When that happens there is the "click" during trying to start, but since it can't the compressor overheats in time and then the thermal overload opens to protect it from overheating. Take the back lower panel off the refer and see if the compressor is really hot to the touch. If you have a little white colored box on the left side of the compressor pull it off and shake it... if it rattles and debris falls out you know it's bad. There is a kit that replaces it and it's real easy to install yourself. If you have a compressor that has a little blue indian head symbol on it however... your compressor is toast. Once they overheat they're done. If you have any other brand name you should be OK with a simple start device change out.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on May 18, 2008
Helpful)
Hodji
Rank: Apprentice
Rating: 85%, 1 votes
We hear a buzzing sound (about every 30 seconds) like the icemaker when it calls for water. My ice cubes have been coming out very hollow on the inside suggesting it is not getting enough water. I turned the ice maker off and it still buzzes every 30 seconds. Last night (Saturday) I pulled it out and took the cardboard-like panel off the back to check the water supply. The supply hose from coming from the sink to the refridgerator unit has plenty of water pressure to it. So I figured I better have an expert come look at it Monday. I left the cardboard panel off. Today, the freezer is not cold and food is thawing out. What can I do?
Was this helpful?
Yes
No
Popular Solutions for Frigidaire FRS3R5EMB Side by
Questions and Unsolved Problems for Frigidaire FRS3R5EMB Side by
Do you recommend Frigidaire FRS3R5EMB Side by Side Refrigerator?
Answer
Answer
no water flow from dispenser after vacation...changed filter, but still no water. New filter filled... (More)
Answer
icemaker worked sporadically -- but now, not at all. Approximately once a day, it makes some... (More)
Answer
where would I get an inline pressure regulator for my refrigerator. My refrigerator model... (More)
7 Other Users Have The Same Problem - Continued
Comment by JoJoFix, posted on May 13, 2008
My 1997 Frigidaire, Model # VFX262ZRF, Side by Side, stopped cooling and a wall of ice developed in the freezer even though the freezer is not freezing. I removed the accumlated dust from the air vents -- to no avail. Is it time to buy a new refrigerator?
Joanne
Comment by brainyone27, posted on Nov 30, 2007
fridge just not cooling, we had to tip the fridge back slightly to get it in the door when we moved & I saw a couple of drops of oil on the floor. Now fridge sounds ok, but when I put a temp gage inside that currently measured room temp (72 degrees), the next morning it reads 76 degrees inside fridge all night! Not good so I unplugged it until I can get help fixing it. It is a Fridgidaire side by side stainless, ice & water in the freezer door.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerators Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(816) 471-5334
* Please Contact us for More Information
At Your Service Appliance Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
