Question about Hoover Windtunnel Supreme U5280-900 Upright Vacuum
Hoover u 6401 bought v belt and drive belt the drive belt is to big, the roller will not turn, can someone help?
  • 32 Answers
You will need to get another belt, it's common that the people pulling the parts are so busy, that they sometimes mistakenly pull the wrong part, or the wrong part number was given, even a misprint in the manual. Needless to say, it seems that you don't have the correct belt. There is no adjustment for belt tension, so it has to be the  wrong belt.
Posted on Jan 20, 2009
I have a Upright Hoover Elite. Can't get belt back on right.
The belt loops over the motor shaft and the brush roller. Verify that the arrows on the end caps of the brush roller are facing DOWN or you will be doing the job over again. Start with the motor shaft and stretch the belt to allow the brush roller to seat. A new belt can require a strong pull on the brush roller to get it seated.
Nov 16, 2016 | Hoover Vacuums
Hoover windtunnel t series belt is loose- roller brush doesnt turn. Its brand new belt is slipping. we bough new belts and putthem on same problem. Can not find solutio in manual. Is the belt supposed to...
I also have a loose belt and have bought additional belts but have the same problem. I put the it around the metal rotor and around the brush roller a shown by he Hoover video, and it is loose.
Nov 28, 2010 | Hoover S3765-040 WindTunnel Bagless...
The roller brush will not turn. The belt is not
Sometimes the belt can stretch cause the roller to not turn. Also make sure the roller brush is free of any debris.
Use this link to access your vacuum to change belt or clean the roller brush.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Hope this helps.
Jan 27, 2010 | Hoover U5068-900 Sprint Upright Vacuum
The roll brush will not turn when on floor. Too much pressure stops brush. Changed belts and still not working
Turn the belt inside out. This problem stems from a design flaw in the mechanism that turns the hoover from bare floor to carpet. After taking it apart I realized that the spring that pushes the belt tight (to make roller spin) is not any where near strong enough to keep the brush rolling. My solution was to turn the belt inside out (there by essentially shortening the belt and allowing enough pressure to be applied to the roller to keep it spinning. Horrible design flaw. I am an engineer and find this pathetic. Hope this helps someone.
Jan 22, 2010 | Hoover U5780-900 Windtunnel Cyclonic...
Describe how to replace belt on hoover windtunnel bagless
If you turn the vacuum so the bottom is facing up you will see the base plate that covers the roller brush. There will be four screws (usually phillips head), remove the screws and the base plate will lift off. You now have access to the roller brush and belt. Lift the roller brush up and remove the old belt. Place one end of the new belt over the motor shaft and the other end over the roller brush and put the roller brush back in place. Now simply replace the base plate and you're done! This models requires Hoover belt # 38528033 (single) or Hoover belt #40201160 (2 pack). You can get this belt at www.vacbelts.com.
Here's the pages:
http://www.vacbelts.com/hoover-40201160-belt.htm
http://www.vacbelts.com/hoover-38528033-belt.htm
Oct 15, 2009 | Hoover U5750-900 WindTunnel Bagless...
Brush roller does not rotate around
If the rotating brush doesn't turn, then it's almost a certianty that the belt (which connects the rotating brush to the motor pulley of the vacuum) is either horribly stretched or just plain broken. Either way, it needs to be replaced. The correct Hoover belt part # for your vacuum is 38528040 (changed from the original part number of 38528027). This is a very common Hoover belt, but would recommend your best source as being a local, independently-owned vacuum dealer dealer (as opposed to a deprtment / big box store, both of which carry very limited belts).
May 03, 2009 | Vacuums
Need drive belt
I'm guessing you have a hoover self propel windtunnel. If that is the case then you should bought the V belt suffix 034 and Flat belt suffix 035. The belt numbers should be listed on the serial tag though.
With most hoover two belt systems there is a pulley that is supposed engage when you recline the machine and this will apply tension to the V belt and tighten the system up so that the brush will spin. If you hold it upside down with the bottom plate off, and release the foot pedal, you should be able to see it happen.
Occasionally that pulley gets stuck and on some newer models they are prone to breaking as well.
Make sure the machine isn't set to floors.
Good Luck
Nov 25, 2008 | Hoover Vacuums
Hoover very noisy after new belt installed.
what is the belt # you have installed (generic)? Yes, there are problems with using generic belts on Hoover Vacuums. If you have noise I would suspect the roller, and replace it. the cost is about $25 and is something that you can install. The newer type are mande of wood and are very quiet.
Nov 23, 2008 | Hoover U5753-900 WindTunnel Bagless...
Hoover Vacuum model U4471 making a very strange noise and letting of a smoke smell
The Elite upright may need to have its drive belt checked. Check that the machine roller is still working. Then turn the vacuum off and locate the screws on the floor head by turning the machine over. If you remove a couple of screws the floor head will come off and you can check the belt. Usually old threads and hair can stop the roller bar from moving properly or may have got to the belt. Ensure that it moves freely simply by turning the roller with your hand. If it doesn't then its possible that the roller needs to be cleaned or the belt needs to be replaced. Drive belts are easy to get for most Hoover products; a smoke smell like burning rubber usually indicates the drive belt is about to give up or has simply snapped. Dont forget to rate if this solution has worked for you. Ty.
Jul 29, 2008 | Hoover Vacuums
Belt Stretched on my Hoover Windtunnel Farrington upright model U6431-900
hi, In order to to replace the V belt the one that turns the brush, One must take off the bigger belt " drive belt" that goes over that hugh wheel towards the back. When a belt gets stretched they will not turn the brush very well. If you have bought replacement belts the bigger belt Drive comes 2 in a package. Then you have your little V belt that helps turn your roller brush over. Yes the belts don't last long on my hoover. For kpatr22101 When you rpelace that V belt it goes over the roller brush into a little groove on the brush and then over a plastic round wheel then you must put on that bigger drive belt that must fit over that hugh wheel towards back and smaller on in front. Yes it is hard to get on. the I hope this helps. Cindy G.
Jul 17, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Windtunnel Supreme U5280-900 Upright Vacuum Logo
79 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
