Question about Honeywell Heating & Cooling
We installed a programable thermostat and it worked fine with the cooling system but now the heat won't work. could it be hooked up wrong?
  • acehigh3710 Nov 25, 2008
    we checked the wiring and it is ok, then we shut of the power for ten minutes with no luck
    Sergeant:
    Champion:
  • 291 Answers
Yes ,,, be sure you have a jumper from red to heat / larry
Posted on Nov 25, 2008
  • 4,806 Answers
Try reprogramming the thermoatat, if thats no good then have a look at how you installed the thermostat and if you have done it correctly, rectify it if you have not and try again.
if that fails the thermostat itself may be faulty
kind regards
    Novelist:
  • 193 Answers
It is possible. Several system checks that you can make before deciding that would first be sure that your thermostat is switched to heat instead of cool. To the right for heat, to the left for cool.
Second test, using your up button, run the temperature up to at least 80 degrees, this would eliminate any wrong temperature settings that may be presently in the unit.
This way, if the heater doesn't come on with a manual setting, the wiring connections to the heat side could have been switched.
Bill
  • 10,515 Answers
Sorry, but there is nothing wrong with the thermostat.
The problem is in the furnace. In heat mode all the thermostat does is close one switch; heat on or heat off. The furnace does the rest. So if the furnace fires up the thermostat is working.
Your cool and "fan on" both work on a high fan speed through a relay.
Heat is at a lower fan speed, usually medium or medium high. You have something wrong in that part of the circuit. It could be several things depending on the model, age and type of furnace. It could be a bad speed relay, a bad fan switch, a bad furnace board, (speed relays are often built on to the board), or even a loose wire to the blower motor (heat) or bad winding in the blower motor (medium) so it only works on high.
You should keep the fan switch on any time you heat as the unit heating with the fan not running will cause it to overheat which is very ******* the furnace, could damage it, and is a little dangerous.
Call for service right away please.
Good Luck.
  • taran_2005
    taran_2005 Dec 14, 2008
    any development?
  • 19,396 Answers
Check all wiring to the thermostat, try aso cutting power to main system for ten minutes to reset the system.
Replacing a Honeywell T822l1000 thermostat.
The W terminal is used for heating and goes to a small electric valve in the water line to your baseboard. The Y terminal is for a cooling system. The T822 is wired wrong and is not working. The wiring between R and W is corect for a heating only application. The R terminal is the power source.
Nov 10, 2013 | Heating & Cooling
Heat pump will not turn on
I would call an expert, testing needs to be done, but based on what I have seen it may be the control board of the heat pump is defective.
Mar 24, 2017 | Heating & Cooling
Why won't my lg ductless heat pump regulate the room temperature?
After I have been reading up on your unit it appears that the thermostat is not operating correctly. I found this real basic information on installation for your unit. This link I am giving is pretty basic instal schematics. But seems to be something about your thermostat needs to be dialed in or is not working properly.
http://www.premsales.net/docs/GE/GE%20Minisplits.pdf
I hope this helps some. Mike
Oct 21, 2011 | GE Quiet-Aire Ductless Mini Split System...
I installed a Honeywell RTH230B model thermostat. The heat works fine, but the AC is blowing warm air. Wires from old system are as follows: Y=yellow; G=green; R=red; O=brown; C=blue; E=white (it looked...
the colors of old system are for heat pump.if you have a heat pump you need heat pump thurmostat and colrs will make more sense.if not,then you need to go into furnace to see what colors go where.yellow is cool, goes to compressor contactor,usually another wire going from furnace to outside unit.green is fan relay rh is heat call rc is cool call
Jan 01, 2011 | Honeywell Programmable Thermostat Heater
I paid $20 last night to talk to someone. He told me how to hook up the Lux DMH110 but when i hooked it up this morning the heater came on when i put it on COOL and the fan just come on when i put it on...
If you have this type of system your thermostat will not work;
  • Multi-Stage Heat Pumps
  • 3 Wire Hydronic Systems
  • Line Voltage Systems (120/240 VAC)
  • This thermostat is only for this type of HVAC systems;
  • Most 24V Heating and A/C Systems
  • 1 Stage Heat/1 Stage Cool: Gas, Oil, Electric, or Single Stage Heat Pump Systems
  • 2 Wire Heat Only Hydronic Systems (Hot Water Baseboard & Radiator)
  • Millivolt Systems (Wall Heaters / Furnaces & Gas Fireplaces)
    1. Never connect a low voltage thermostat to line voltage.
    Two wires control a heat only system.
    1. Connect one wire to W and the other to RH.
    Two wires control a cool only system.
    1. Connect one wire to RC and the other to Y.
    Three wires for forced air heat only system, where the previous thermostat
    did not have a clock or timer.
    1. The previous RH or RC wire is the 24-volt transformer wire. Connect it to RH. Leave jumper connecting RH to RC. Connect the forced air heat system to W, and the fan wire to G.
    Three wires for a heat only, forced
    water system that did NOT have a
    clock or timer.
    1. This system employ 3 wire zone valves. Currently no Lux controls are compatible with this system.
    Three wires control a heat only, forced water system that DID have a clock or timer.
    1. Tape off and do NOT install any clock or timer wire. Often they are labeled C or TC. Install the remaining two wires, one to RH and the other to W.
    Four wires control a heat only system,
    and two of the wires operate clock or timer. The other two wires operate the heater.
    1. Tape off and do NOT install any clock or timer wire. Often they are labeled C or TC. Install the remaining two wires, one to RH and the other to W. The jumper connecting RH to RC may remain or be removed.
    Two wires control heating AND cooling.
    1. Currently no Lux controls are compatible with this system.
    Three wires control heating and cooling. One wire operates heat, one operates cooling and the third provides 24 VAC.
    1. Connect the 24-volt power wire to RH. Install a jumper connecting RH to RC. This jumper is usually pre-wired. connect the heat wire to W, and the cooling wire to Y.
    Three wires control a cooling only system. One wire operates the compressor, one operates the fan and the third provides
    24 VAC.
    1. Connect the 24-volt power wire to RC. Connect the cooling wire to Y and the fan wire to G.
    Four wires control a heating and cooling, electric, gas or oil, forced air system that
    is NOT a heat pump.
    1. Connect the 24 VAC transformer wire to RH or RC. Install a jumper connecting RH to RC This jumper is often prewired. Connect the heat wire to W, the cooling wire to Y. and the fan wire to G.
    Four wires control a Single Stage Heat Pump. They were labeled: G, Y, R or
    RH or RC, With either B or was used.
    1. Do not connect wires to both B and O. Connect the reversing valve wire to B or O, just as the previous thermostat. Install a jumper wire from RH to RC. Connect 24 VAC wire to RH too. Install a second jumper wire from W to Y. Connect compressor wire to Y and the fan wire to G.
    More than 4 wires are connected to the
    old thermostat
    Jun 27, 2010 | Heating & Cooling
    I install new RTH7500D thermostat Honeywell, when I set for Cool it blowes heat when I set for a Heat nothing works I wire per instruction have two stage system
    It sounds like the t-stat is programmed for a heat pump or you have a heat pump and the t-stat is programmed for a regular furnace....
    Check out the manuals in the tip and go into the installer setup to change the t-stat to the proper programming for your system..
    http://www.fixya.com/support/r3902153-honeywell_rth7500d_thermostat
    heatman101
    Apr 24, 2010 | Honeywell Programmable Thermostat Heater
    Honeywell RTH230B works on AC not on Heat
    check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
    Oct 16, 2009 | Honeywell Electronic Programmable...
    Six wire hook up and new thermostat has only 5
    Some thermostats have an extra terminal for an outdoor sensor which tries to anticipate the need for heating or cooling. If this option is not present, you will have an unused terminal which may have a shorting link to a neighboring terminal. Your installation instructions should mention this if the option is or is not included with your model. Also, heat pump systems vary in the system control voltage and not all thermostats and systems are compatible with the more common split system thermostat.
    Oct 01, 2009 | Honeywell Electronic Programmable...
    Programmable T stat
    your trane heat pump energizes the reversing valve with O - orange y - is to turn on the unit make sure you have your orange wire hooked up and the tstat programming set to heatpump otherwise your reversing valve might be bad
    Jun 30, 2009 | Honeywell Electronic Programmable...
    Heating & Cooling Logo
    Top Honeywell Heating & Cooling Experts
    Bill Long
    Paul Carew
    vance jones
    Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
