Question about Honeywell Programmable Thermostat Heater
My honeywell lcd thermostat is making beeping noises like a fire alarm.  It's something with the wires, because I removed the lid, and when I went back to put it back on, the beep went off when it came into contact.  What do I do
  • 61 Answers
Change the batteries
Posted on Nov 30, 2008
  • Anonymous Jul 24, 2016
    according to Honeywell their thermostats DO NOT have the capabality to make a sound
NOTIFIER SMOKE ALARM PROBLEM WITH CHIRPING ALL NIGHT
Could be time for a battery replacement unless these units are hardwired
Dec 14, 2012 | Honeywell Notifier Sib-2048 Fire Alarm...
Tip
Honeywell RTH7500D Thermostat
This Honeywell thermostat is a good medium priced thermostat that will give you many bells and whistles at a very good price. The programming is very easy to do and of course the thermostat is very reliable also.
The installation of this thermostat is very easy and if you need help with the installation you can go here to see the complete installation guide.
http://customer.honeywell.com/techlit/pdf/PackedLit/69-2221ES.pdf
If you have lost your owners manual and need a copy of it you can go here
http://customer.honeywell.com/techlit/pdf/PackedLit/69-2222ES.pdf
With the help of these .pdf files you can get all the information that you need to install and troubleshoot your RTH7500D thermostat.
If you are replacing a thermostat make sure that you turn off power to your heating or air conditioning system BEFORE you start removing any wires. Failure to do so could cause you to burn out the 24v transformer of your system. Also make sure to mark all wires well before removal so that you know which wire went where and so that you can reinstall the old thermostat as it was if something goes wrong with the new installation.
For heat pump systems you WILL have to make some programming changes to the thermostat to get it to work with a heat pump system. Most all thermostats come programmed for conventional systems. This reprogramming is not difficult but is required for proper operation.
http://www.fixya.com/support/r3623083-thermostat_wiring_terminal_designations
http://www.fixya.com/support/r3892721-programmable_honeywell
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
on Jan 16, 2010 | Heating & Cooling
We just installed a honeywell thermostat, our furnace is an old furnace and now it won't shut off. it is a hot air oil furnace. any suggestions
for a quick test -- remove the wires from the thermostat and see if the heater shuts off then,,, if it does shut off then the problem is the type ( model ) of the thermostat and it may not be compatible with that heater or there is something wrong with the way that the thermostat is wired. ( make sure that the thermostat is reading the correct temperature and is in fact in the off position ). also double check the wire color code at the heater and make sure that the right wires are connected proper.
what model is the thermostat ?
c...
Jan 03, 2011 | Honeywell Heating & Cooling
My honeywell ac panel went blank when i turn the heat on and the heat don"t start , the ac works fine
I would check a couple things lets start with the thermostat itself remove from the wall mount and check to see if the red and white wires are attached. Does this thermostat take batteries? If so replace the batteries. If still no heat make a jumper and jump out the red and white wires this should turn your heat on and now means that it is a thermostat problem. Purchase a new one and pay attention to all of the wires and where they go.Good luck
Dec 13, 2010 | Honeywell Programmable Thermostat Heater
I am replacing an old Lennox thermostat with a new Lux DMH110 digital thermostat. My furnace(oil) has only two wires on the thermostat(heat only). I connected the wires according to directions of new...
Make sure on the furnace that you have the same colored wires connected at the thermostat to R and W. Check for good connections at both locations. You can always test to make sure the unit fires by crossing the two wires together. If the unit fires, you have a bad thermostat.
Feb 17, 2010 | Honeywell Programmable Thermostat Heater
CT3600 display went out. Replaced all 3
My honeywell CT3600 thermostat went blank.
Replaced batteries - no change ?
Dec 25, 2009 | Honeywell CT3600 7 Day Electronic...
Wiring new RTH2310 DIY Honeywell
sounds like you've got bear wires touching at the new tstat
Sep 18, 2009 | Honeywell Focus 6300B 5-2 Days...
Honeywell 8000 Thermostat relay switch clicking noise.
It's an expensive solution but doable. Look for Honeywell's VisionPro IAQ thermostat. It works much differently than a conventional thermostat and shouldn't click at all make sure it's the 3-wire version.
Aug 21, 2009 | Honeywell Programmable Thermostat Heater
PIR Intruder alarm magnetic contact
its a long time since i worked on these but its quite easy you want the 2 terminals that make a circuit when the magnet is placed by the switch and breaks the circuit when the magnet is removed.hope this helps
les from new zealand (ex uk)
Dec 08, 2008 | Honeywell Home Security
Changing Thermostats
This is one where you will need a good control man or woman. The American Standard ASYST system is not intended for the homeowner to change out. It has a room sensor wire that others do not account for.
Jan 15, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
1,948 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
