Question about Hoover Vacuums
Need drive belt
I bought a v belt and drive belt the drive belt is to big so the roller doesn't turn. Can you please tell me why?
    Scholar:
  • 55 Answers
I'm guessing you have a hoover self propel windtunnel. If that is the case then you should bought the V belt suffix 034 and Flat belt suffix 035. The belt numbers should be listed on the serial tag though.
With most hoover two belt systems there is a pulley that is supposed engage when you recline the machine and this will apply tension to the V belt and tighten the system up so that the brush will spin. If you hold it upside down with the bottom plate off, and release the foot pedal, you should be able to see it happen.
Occasionally that pulley gets stuck and on some newer models they are prone to breaking as well.
Make sure the machine isn't set to floors.
Good Luck
Posted on Nov 26, 2008
HV9010P ROLLER BRUSH DOESN'T MOVE
That is probably the belt. Open up the bottom screws and take a look. The cat or dog hair usually gets stuck in the ends of the rollers and stops the belt from effectively pushing the roller. You may find that the belt is still on the drive and the roller. If you do just clean out the roller.
Jan 22, 2013 | Black & Decker AV1200 DustBuster Handheld...
Changing a drive belt
Turn the unit upside down and on each side of the roller brush is a red piece of plastic with screws remove and take off roller then you will see the belt drive stem place around stem and on roller and pop back in, Reassemble. Steve
Jun 06, 2010 | Bissell Powersteamer 1694 Upright Vacuum
My Generation 3 Kirby Vacuum is giving off a burnt rubber smell when I vacuum. I have tried to raise the height of the head but it still happens. Can you tell me what could be causing rubber to burn? ...
The belt driving the brush roller in the power head is slipping. It is really just a big thick rubber band. Where it wears out it slips and burns due to friction.
Look at the bottom of the power head. There is a cover plate held with 2 to 4 screws. Remove the plate and you will see the roller and drive belt. Slip the roller out and remove the belt.
Go to your local vacuum dealer and get a replacement.
Installation is the reverse of removal.
Mar 06, 2010 | Kirby Generation 3 Bagged Upright Vacuum
My Eureka The boss Smartvac Model #4870 roller brush won't turn even on the highest setting and the belt smells hot. we took the belt off. How can you tell if it needs replaced?
Just by what you explained I can tell that it needs to be replaced. The belt doesn't have to be broken to need replacing, if it is stretched and worn then it will slip on the motor shaft and not turn the brush roll and get hot. Here is a link to the belts you need and the manual which has instructions:
Bissell 4870 Belts
Owner's Guide (3,666K download)
Dec 11, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Model 3590 roller not turning
There is a small rubber belt that connects to motor and the roller. It is common that this belt will break or wear and needs replacement. However, you must check the roller to see if it turns (spins ) freely. If it is stiff, then a new belt will be ruined in minutes. You must replace or clean the bearings at the ends of the roller (sometimes easy-sometimes hard). This roller must turn easy so the belt can do its job.
Replacement parts are easily available. I bought a roller with new bearings for a hoover about 4 months back----cost $13. and af course a new belt for $2.20. Goodluck< MAcgivor
Oct 24, 2009 | Bissell Vacuums
Need help on to set up belt for shampoo for
Lift the light bulb housing up and you will find a latch that will rotate to release the front agitator housing and remove it from the machine. On the bottom of that housing, there are two latches that secure the bottom plate that covers the roller. Remove the plate and the roller will come out. Be sure to notice that the roller has a magnet at one end that lines up with the indicator that shows you when the roller is turning - it's the little green light that glows while you are vacuuming. The roller needs to go back in the same way it came out. O.K. Take your new belt and position it around the middle of the roller and drop the roller back into place and replace the bottom plate. On the front of the housing, there is a big square "knob" and you can rotate that piece. If you look inside the hole on the other side of the agitator housing, you will see that there is an arm that moves with the square knob. The end of this arm will catch the belt and with a little effort, the knob will rotate and lift the belt into position for replacing the housing back on to the machine. once you have the housing back on the machine and secure, you rotate the square knob back around and the belt will sit down on the drive shaft. If you look at the top of the agitator housing just above where the knob is, you will see a red and a green arrow which indicate which way the knob turns to do the "remove" belt or "replace" belt. I hope this helps. Once you do it properly, it actually is quite easy.
Mar 07, 2009 | Vacuums
Hoover u 6401 bought v belt and drive belt the drive belt is to big, the roller will not turn, can someone help?
You will need to get another belt, it's common that the people pulling the parts are so busy, that they sometimes mistakenly pull the wrong part, or the wrong part number was given, even a misprint in the manual. Needless to say, it seems that you don't have the correct belt. There is no adjustment for belt tension, so it has to be the  wrong belt.
Nov 25, 2008 | Hoover Windtunnel Supreme U5280-900...
Belt Stretched on my Hoover Windtunnel Farrington upright model U6431-900
hi, In order to to replace the V belt the one that turns the brush, One must take off the bigger belt " drive belt" that goes over that hugh wheel towards the back. When a belt gets stretched they will not turn the brush very well. If you have bought replacement belts the bigger belt Drive comes 2 in a package. Then you have your little V belt that helps turn your roller brush over. Yes the belts don't last long on my hoover. For kpatr22101 When you rpelace that V belt it goes over the roller brush into a little groove on the brush and then over a plastic round wheel then you must put on that bigger drive belt that must fit over that hugh wheel towards back and smaller on in front. Yes it is hard to get on. the I hope this helps. Cindy G.
Jul 17, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Belt replacement
Rating
Jan 25, 2008 | Kirby G4 Bagged Upright Vacuum
I cant get the roller back in place
This guide should help.....
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Please rate it when you are done reading it if it was helpful. :0)
Marci
Oct 02, 2007 | Oreck XLS700A Upright Vacuum
Vacuums Logo
61 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
