Question about Sony VAIO VGN-N130G/W Notebook
DVD RW driver won't work "This device cannot start. (Code 10)" It seems to be related to my iTunes software as I have removed iTunes and was able to fix it once. DVD RW AW G540A ATA
  • Sony Master
  • 4,806 Answers
Go into "device manager" and unistall the CD/DVD from the menu, then restart your computer, if its vista you are using just let vista pick up the device and it will install the drivers for you, then try do use the DVD
hope this helps and regards
Posted on Nov 25, 2008
Can't get my cd/dvd rw drivers to work? Can't read the CD/DVD RW Tray?
Description of Code 10-related errors that Device Manager generates in Windows-based computers
Try this - Control Panel - Device Manager - CD/DVD - double click the device - Driver's Tab - then RIGHT CLICK the drive - UNINSTALL - REBOOT
this will refresh the default driver stack.
if this not work, replace the device with a new one.
Mar 03, 2015 | Acer 15.6 Inch LCD Screen Panel for Aspire...
Problem is with iTunes
hi try this: The intention is to remove all iTunes and Quicktime software references. The following steps remove the software traces and worked on my machine. 1. Using add/remove programs uninstall Quicktime (click on Start ?> Settings ?> Control Panel ?> Add/Remove Programs) 2. Using add/remove programs uninstall iTunes 3. Right click on My Computer, use Search and remove all programs named Quicktime 4. Right click on My Computer, use Search and remove all programs named iTunes (except your iTunes download, so you won?t have to sit through another long download session). 5. Left click on Start, click Run, type ?regedit?, go to HKEY_LOCAL_MACHINE, click on SOFTWARE, and remove the Apple Programs folder (you may want to check in case you have other Apple applications, but all I had were iTunes and Quicktime in my Apple folder). Steps 1 through 5 should remove all traces of the software and now you can install iTunes. make sure you install all the latest updates from apple hope this will work for you :)
Aug 18, 2007 | Sony (DWQ30AB2) DVD RW Dual Layer Burner
My Matshita dvd ram uj 857s says code 10. I have
It's not "regeit" but "regedit".
Drives Disappear After You Install ITunes or Norton Ghost** If after installing ITunes or Norton Ghost, you get Device Manager error code, try locating the Audio File System (AFS) driver from Oak Technologies at C:\Windows\System32\Drivers\afs.sys or doing a search for it. Rename it afs.sys.txt and reboot. This driver is incompatible with the driver found in iTunes and Norton Ghost. The driver from these two companies is the same and made by a third company called Gear Software. After renaming the afs.sys driver file you will lose access to the CD burning feature of of the following: HP Memories Disc Creator, Liquid Audio Portal Player, Oak Technology SimpliCD, or Broderbund's Print Shop version 20. If you still wish to use the burning feature in any of that software, upgrade it to a Vista versions. For more information, see the article here - http://www.gearsoftware.com/wiki/index.php?title=CD/DVD_drives_disappear_after_installing_iTunes.
http://support.microsoft.com/kb/943104/
Please do all the below even if you have done some before as it is often the total process which solves the issue.
Try this - Control Panel - Device Manager - CD/DVD - double click the device - Driver's Tab - click
Update Drivers (this will likely do nothing) - then RIGHT CLICK the drive - UNINSTALL - REBOOT
Then work your way through these - remember the drive could be bad, could have a loose cable or
slight corrosion on the contacts (usually for a laptop) and other issues.
Your CD drive or DVD drive is missing or is not recognized by Windows or other programs
http://support.microsoft.com/kb/314060 - a Mr Fixit
The CD drive or the DVD drive does not work as expected on a computer that you upgraded to Windows Vista
http://support.microsoft.com/kb/929461
When you insert a CD or a DVD, Windows Vista may not recognize the disc
http://support.microsoft.com/kb/939052
Your CD or DVD drive cannot read or write media - A Mr Fixit
http://support.microsoft.com/gp/cd_dvd_drive_problems
CD/DVD drive does not appear in Windows Vista, or you receive this error during Windows Vista setup after booting from the DVD (AHCI)
http://support.microsoft.com/kb/952951
CD-R drive or CD-RW drive is not recognized as a recordable device
http://support.microsoft.com/kb/316529/
Another possibility is that the cables are loose. Remove ALL power, then check cables in both
ends. Remove and replace, do not just snug. For laptops you can often clean the power and
data contacts with a pencil eraser.
Some DVD drives do not use the Windows default drivers so check with the System maker and
device maker to see if there is firmware or drivers for you drive if needed.
Dec 30, 2009 | Dell XPS M1330 Notebook
Code 10 no cd/dvd drive found, unable to burn cd?
To solve this Code 10 error, follow these instructions: NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4)This folder is the DVD/CD-ROM Drive Class Description in the registry.Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the
Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives havereturned. You may also want to open Device Manager and verify that theyellow exclamation and error code on the CD or DVD drive is gone.
Jun 24, 2009 | Apple iTunes
Stop working
Code 10 could mean either the driver has gotten corrupted: repair for this is to reinstall the driver; or it could mean the drive itself has come to the end of it's lifespan; repair for this is to replace with a new drive. Before buying a new drive check all cables going to the drive to see if any came loose, and reinstall the driver. If this does not work you will need a new drive. Hope this helps & please take a moment to rate my solution. Thanks.
Feb 23, 2009 | Pioneer DVR-107D DVD±RW Burner
Pioneer DVDRW DVR-K17B ATA Drive
This is my error in report viewer for my dvdrw in laptop.
dvdrw icon is hide and it can't read any disk dvd/cd.
PLEASE HELP ME! THANKFUL
" Windows was able to successfully install device driver software, but the driver software encountered a problem when it tried to run. The problem code is 39. "
Aug 06, 2008 | Pioneer DVR-107D DVD±RW Burner
Download driver software for PIONEER DVD-RW DVR-K17LF ATA Device
it's look like you have problem with dvd isnot showing in windows explorer / dvd driver.
Try this step from microsoft http://support.microsoft.com/KB/314060
basicly just update (delete some key) the windows registry and restart. ussually this work ok.
Jul 31, 2008 | Toshiba Satellite P105-S9722 Notebook
DVD driver fault - Pioneer DVD-RW DVR-212 ATA.. maybe NERO 8 fault?
Code 10 means the driver cannot load usually due to being incompatible with the OS type.
May 29, 2017 | Computers & Internet
DVD/CD rewritable drive SONY
Hello Mohawk kid
Happy Holidays
You seem to has a hardware detection problem, the resolution for this particular problem may be, change the pin on drive to Cable Select, and remove the driver on Devide manager, then the system restart and redetect the DVD/RW, ( I PRESUME) so you can reinstall the software that came for this device, or download a new version from the programmers for DISC REV 7 -10 to another. good luck
Nov 28, 2007 | Computers & Internet
Sony VAIO VGN-N130G/W Notebook Logo
166 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
