Question about Indesit 24 in. D61 Free-standing Dishwasher
Indesit dishwasher sump keeps filling up with water when turned on
When I turn my dishwasher on it just fills the sump up with water instead. can anyone advise me to is wrong. many thanks
I had a similar problem every time i bailed the sump out by hand and turned the machine back on it would fill the sump or just shut off.
Having spent ages checking various site it boiled down to one of three things there is a thermostat switch underneath they are know to go on the indesits and cost next to nothing to replace
second cause and most probable is to take machine outside before you do this front cover below front door removes to give access to pump you ll know it the pump because it has a pipe rinning into it and one out on my indesit i turned it upside down and got really easy access to it comes of easily take it to pices bit by bit really easy probably need small allun key depends on model check put for foreign objects , spinx blackpool rock etec etc only kidding it might be a bit of plastic or something that stop the spindle turning freely inside the pump if you find anything clean put back and off you go if pump is knackered you can get them off the web for 4.95
last but not least is the problem that mine actually had in the end and the easiest to fix `water pressure` if there is insufficient water pressure the machine regognised this and activate a shut off valve the machine lights flash you can reset the programme but it still does nt work. take the water pipe off the back put it into a bucket and open the valve you ll now what good pressure looks like mine was poor when i took the adjacent kitchen unit out it transpired a shut off vavle had been placed on the pipework the vavle had never been opened fully by the plumber and was restricting the water supply . take your time dont rush and be methodical take advantage of a local parts supplier ash them what most repairers will do first. it can be very rewarding to find that a/ you can do it and b/youve saved 60 or 70 quid in the process.
ps never mess with the machine whilst connected to the mains or spiky hair might come free with the repair and do take the machine outside or you ll have water evrywhere trust me
Posted on Jan 17, 2008
Kitchenaid dishwasher fills with hot water but doesn't wash
remove sump cover clean sump and change the chopper
Feb 21, 2014 | KitchenAid Dishwashers
Indesit IWC6105 Keeps filling with water and lights flashing
Almost certain to be a power pcb failure due to the fact it fills and drains at the same time this is a regular fault symptom on indesit laundry appliances. Word of caution tho inde pcb's are generic to a range and the software must be programmed via a lap top to your specific appliance so you can't just order a pcb and pop it in sorry
Dec 08, 2013 | Indesit Washing Machines
Indesit iwb5113 keeps filling up
The water level in your, and most other, washing and dishwashing machines is controlled by an air pressure switch that senses water level by the rising air pressure compressed in the pressure, (level), switch body itself. This air pressure is usually transmitted by a thin rubber tube on the bottom of the washing machine drum, or sump hose. As the water gets higher in the drum, air is compressed in the level switch until it operates, and turns the fill valves off. The pressure switch is always mounted at the top of the washing machine cabinet - look for a circular switch with the thin rubber or plastic tube fitted into the bottom. What can happen is if the rubber tube rubs against moving parts in the washer, it can get a hole worn in it - so the air does not compress and the water doesn't turn off.. You will have to examine the tube very carefully to find holes like this. Alternatively, the tube could have come off, or blocked with limescale at the bottom end - try removing the tube at the pressure switch end and blowing through it - any blockage must be removed. A last, rare, possibility is the rubber diaphragm in the pressure switch is leaking - but very very rare. Most modern machines have an electronic backup that measures fill time in case the pressure switch fails. If your machine floods, it doesn't have this.
Jan 19, 2018 | Washing Machines
HiTo all iv been having problems with my dishwasher its a indesit aaa class idf 125 it keeps turning its self off then there is no power at all iv now had it off fr 3jd mounths and now its working again...
Could be anything but check your water heater element first - prime cause of power tripping. Also check for leaks from the sump into the wash motor / electrics etc Usually manifests as fills, runs for a bit then cuts out as leak starts. Be very careful with electrical safety on this one - water and electricity are a deadly combination. ensure the power if off, and machine unplugged before examining. test for safety after the repair.
Feb 01, 2018 | Indesit W 123 Front Load Washer
My dishwasher seems to start ok then the first light starts flashing and it do'es nothing just stays there any ideads what my problem is
Can you tell if it's filling with water. The first thing it does is fill with water (usually on a timed cycle) before the pump starts. If there's no water in the tub, it obviously won't wash dishes, since a dishwasher is nothing more than an enclosed pressure washer. If it does not fill with water, you may have a bad fill valve or the timer that turns the fill valve on may be defective. You DO have the water turned on, RIGHT?
Jun 11, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit DV620
check your manual it should tell you what this code means and wether you can deal with it yourself
Nov 22, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Indesit D61D tripping RCD
the heater is faulty(shorted) and check that the hot water is getting to the appliance as the buzzing is the soliniod being powered but the water is not passing through
Aug 15, 2006 | Maytag 24 in. MDB8600AW Jetclean II...
Indesit 24 in. D61 Free-standing Dishwasher Logo
547 people viewed this question
Top Indesit Dishwashers Experts
Marvin
Marvin
NOEL
NOEL
Ngoro
Ngoro
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
