Question about Motorola Mobility RAZR V3i Cellular Phone
How to Firmware/software upgrade on Razaor V3i?
En error keeps popping up " voice record memery full "( these voice records are keep on generated by virus till box gets full) and does not allow me to do any thing else, as other people on this forum explained this phone does not catch virus. Do I need Firmware/software upgrade ?
  • tigersnuk Apr 02, 2009
    i also have the same problem. email me malaysiakumaju [at] yahoo [dot] com
    Brigadier General:
  • 7,752 Answers
Yes you need to take the phone and have the firmware reflash on the phone to correct this issue...any mobile repair center should be able to get this done for you.
Posted on Dec 28, 2008
Go gear vibe has been frozen for about 25 min. wont shut off or anything
Hi, i stuck a pin in the reset hole, (to the right of the lock switch) and it shut it off, than all you have to do is turn it back on..
The Philips GoGear is a portable MP3 player with additional functionality such as the ability to record your voice or the radio. Some minor problems may develop in the device that keep if from working normally. The most common issues are the GoGear freezing, not powering on and memory-error messages. Troubleshoot your device to return your GoGear to normal operation.
Unresponsive
1. Your GoGear may not respond to button presses from time to time. This is often caused by an error in the operating system and can be fixed by resetting the device. Resetting the GoGear is similar to rebooting your computer. You will not lose any of the data uploaded to the device. To reset the GoGear, press the "Reset" button located on the left of the device. The screen will go blank for a few seconds and then turn back on.
If the GoGear freezes after uploading a file to the device or if one song or sound file freezes the device each time you play it, the file is likely corrupt and needs to be removed from the GoGear. Connect the GoGear to a computer and delete the file from the device.
GoGear Does Not Power On
Problems with powering up the GoGear are often the result of an exhausted battery. If you cannot power on the GoGear, charge the battery with the supplied charger.
In some instances there is an error with the device that is keeping it from powering on. Unlike the errors that freeze the device, errors that keep it from powering on cannot be cleared by pressing the "Reset" button. The errors need to be fixed by using the "Firmware Manager." The Firmware Manager is a computer program that restores your device to their factory conditions. You will be able to use your device again after restoring it to factory conditions, but you will lose all of the data on your GoGear.
To use the Firmware Manager, open the installation CD supplied with your GoGear and follow the onscreen instructions to install the Firmware Manager on your computer. Plug the GoGear into the computer and check that your computer is connected to the Internet. Open "Firmware Manager" on your computer. You will be prompted to "Restore" the firmware or "Update" the firmware. Since you need to restore your device to working order, select the "Restore Firmware" option. Updating the firmware will not delete the files or errors that are causing the GoGear to malfunction.
Once the process is complete and your GoGear can power on again, consider updating the firmware. Updates give your device extra functionality and repair errors in the device.
Memory Full
The GoGear allows you to make voice or FM radio recordings and saves the recordings to the internal memory. The internal memory is limited and the GoGear may show the message "Memory Full" when trying to save recordings. When you receive this message, plug the device into the computer and delete any extraneous files or files you no longer want to keep on your device. This will free up memory so you can save more recordings or place additional music files on the GoGear.
Hope it helped..
Have a nice day.
Feb 22, 2011 | Philips GoGear ViBE Digital Media Player
My zoom stop recording after one hour with plenty of memery on my 16 gig sd card
Which firmware do you have? It should say on the screen when you turn it on. If it 1.10, or 1.0, you need to update the firmware by going to the Zoom support page:
http://www.zoom.co.jp/english/download/software/h4.php
Directions and firmware download is all there.
If you are already on 2.0 or 2.4, then try reformatting the card with the Zoom. This will delete anything on the card, so backup first!! Good luck.
Feb 17, 2010 | Zoom H4 Handy Recorder
MY MP3 PLAYER KEEPS SAYING FILE SYSTEM ERR
you have to generate the system file in your player. you can doing this by recording your own voice or recording a fm station song(if the option is present) and save it to the device. after that reset your device and upgrade it using the firmware manager from the software cd . but this will format your device and all the data will be lost
Jun 08, 2009 | Nextar MA933A MP3 Player
Transferring voice files to PC
That software should work. I found a few firmware upgrades that may help you as well. Check this link out:
http://www.olympusamerica.com/cpg_section/cpg_support_downloads.asp?id=1350&os=w
This link is for windows. There is another link for Apple as well.
Mar 26, 2009 | Olympus LS-10 Digital Voice Recorder
DISK ERROR WHEN I TRY TO USE MP3
Double check p. 17 of the manual for a firmware upgrade, in case this message is caused by a db corruption, but the error may also be caused if your player is in the "lock" or "hold" position.
Link to the only manual on Centon's low-budget website:
http://www.centon.com/documents/mp3guide.pdf
-Tha Mp3 Doctor
May 28, 2008 | Centon Electronics MP4-001 MP3 Player
VOICE RECORDING
razors dont record very well they have to be close up to what u r recording.
May 19, 2008 | Motorola Mobility RAZR V3i Cellular Phone
IRiver ifp-700 record error
upgrade the firmware should fix the problem
Jun 26, 2006 | iRiver iFP-795 MP3 Player
Motorola Mobility RAZR V3i Cellular Phone Logo
521 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
