Philips Blackline TV just stopped working. Won't switch on any more - changed fuse, checked on/off switches, but no response. No light on the front, no sign of any power getting into the system. What should I try next? Model: NO25PV808/07, P/N VN04 0038 005981 Thanks
  • Anonymous Apr 05, 2009
    Philips Blackline TV with integrated video just stopped working.
    Won't switch on any more, checked on/off switches, power cord, but no response.
    Any suggestions?
    Model: NO25PV808/39, P/N VN04 0038 011636
  • 5 Answers
SOURCE: philips 60pp920217f Blinking Power Light
Call a technician. If fixed it is worth it for ~$200.
Posted on Jun 29, 2007
Slinteriors
  • 8617 Answers
SOURCE: power loss
Check for 12v on Q5A33 110v on Q5A01 this feeds T5A31 that powers the CRT filaments make sure Diode DA52 isnt open and also check horizontal output Q5A31 for being shorted or open. let me know if you need any more info.
Posted on Feb 02, 2008
SOURCE: Cant get the tv to power up
I'm having the same problem. No power at all, tv was working fine and shut off by itself WS-65517. Please help!
Posted on Mar 27, 2008
  • 197 Answers
SOURCE: NEW BULB INSTALLED FOR PANASONIC PT-50LC13 TV STILL NO LIGHT
close lamp door set will not work with door open. if not that listen for arcing sound in back if  don't hear that bad ballest
Posted on Jun 09, 2009
SOURCE: changed one of the door switches on my microwave now no power
check the green ground ground cable on the control panel
Posted on Aug 18, 2009
Brake lights won't work
Check the voltage or the connection.
__________
Multi-Cardiag M8 CDP for car and truck
Jun 05, 2013 | Cars & Trucks
My remote control for my TV won't work. I changed
See my response to your other identical question.
Mar 14, 2012 | Philips Televison & Video
Rear windows won't go down
You also have Circuit Breakers for your windows, Or your Master Switch ,You can Test the Driver Control Switch or the rear switches by removing the Switches and using the connector Plug and a Jump wire try jumping accross the wires,if they go up or down you could have a Bad Switch,if nothing moves more than likely your Window Motor is bad. BUT first CHECK your Circuit Breakers ,It could be Labeled as accessery Relay or circuit Breaker.
Jan 02, 2012 | 2004 Lexus ES 330
No brake lights but every other light works
Do the turn signals work? If yes check fuses.
All fuses good? If yes, probably stop light switch.
Remove the wires from the stop light switch, jumper across the two wires with small piece of wire, stop lights come on? If yes the switch is to blame. Push wires on and of switch a few times to make sure they are making contact be fore changing switch.
conner334
Sep 28, 2010 | Volkswagen Golf Cars & Trucks
1996 Ford Windstar tail lights and dash lights stopped working
No. All those lights are on the same fuse and are controlled by the headlamp switch.
Make sure that the fuses were all checked on the fuse panel inside the vehicle under the dash. That is where the fuse for those lights is.
Sep 12, 2009 | 1998 Ford Windstar
1999 Camry, no stop light. Fuse & bulbs ok
That switch should be your Problem. Please Rate My Response! Thanks!
Feb 07, 2009 | 1999 Toyota Camry
On switching Philips Tv type:21PT 240B/94R no sound,picture
I have Philips CTV 21 PT 240B/94R. and this time a problem are when set on chenel are not stop to change only forward and bottom right side Display Scan+
Jan 29, 2009 | Televison & Video
Phillips 32" tv stuck in standby mode
thesupply is not responding
take your tv for repair
let them check power supply
semi conductors, transistors, zener diodes, an dfuse resistors, also check the switch contact,
and fuse,
Dec 24, 2008 | Philips TV Tuner Video Capture PCI Card -...
Error message/Switching off
Hi.
What is the model number on the rear of set & chassis number if it has one.
Oct 10, 2007 | Televison & Video
Televison & Video Logo
314 people viewed this question
Top Televison & Video Experts
