Question about Kenmore Ovens
Problem with Kenmore Oven Model 362.75492000
Displays FFF and oven won't work. Please help. Thanks..
SOURCE: Kenmore Elect Built-IN Oven Model 790
OLD MODEL KENMORE STOVE.....THEOVEN DOOR IS LOCKED AND WILL NOT OPEN....NO F7 OR BEEPING SOLUTION....IT IS TO OLD...WE TRIED UNPLUGGING AND REPLUGGING. NADA!!!
Posted on Jun 23, 2008
SOURCE: oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Posted on Nov 18, 2008
protek480
  • 1723 Answers
SOURCE: Kenmore Model 665 95781000 Stove Displays a EO-F3
F3 - E0 Oven temperature sensor (RTD) opened (upper oven, if double oven) Replace Oven temperature sensor (RTD)
Posted on Sep 26, 2009
jumptrout51
  • 3361 Answers
SOURCE: My Kenmore gas oven does not light.
Remove the oven Racks. Remove the oven base plate. Turn the oven on. You can then see the oven ignitor next to the oven burner. If the oven ignitor does not glow a bright orange,replace it. About a $90 part.
Posted on Oct 05, 2009
SOURCE: Ariston oven error code F8E0
solved by rotate the temperature knob!!!
maybe would be a problem of the potentiometer or knobe of temperature
Posted on Nov 22, 2009
GE jvm140k prchase 1993. Oven timer works and displays time and progaming but oven won't start up. It has been working off and on but now won't work at all.
The model you gave was for a microwave oven. In the backside of the microwave is a air cooling window. If it gets clogged with junk the mag will overheat and the limit on the side of it will shut down the oven. Simply cleaning this area so that air can circulate better can cure the problem. I suspect it finally got so bad that the cavity thermal limit has blown now and you have nothing at all.
I have a service manual and more HERE
May 27, 2011 | Ovens
My kenmore model 970(frigidaire) electric range displays F10 fault when i use the oven shutting down the oven and beeping. Help me please
Hi
Thanks for using FixYa. F10 error indicates that the Electronic Range control (ERC) has gone bad and should be replaced. However, before replacing it you can take the screws out and then blow some air with the help of hair dryer so that if there is any moisture it blows it off. If still the issue is not resolved then replaced the ERC. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Frigidaire Ovens
My Kenmore oven, model 790, displays and beeps the F10 Fault
June 8, 2010
Same thing happened to mine this morning....cut the circuit breaker for a hour....open oven and let it cool....
mine stopped, finally. Dont know if its a long term fix yet.. but at least it stopped the beeping.
May 06, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Model 665 95781000 Stove Displays a EO-F3 code and the oven does not work WHat part work be defective to give me this fault code EO-F3?
Sep 25, 2009 | Ovens
E3 F1 code on key pad kenmore specail edition
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 17, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
I can't find the model no. on my Hotpoint Ovan!
FFF Control Error, Failed EEPROM Replace Control
You can try a hard reset . turn off the power for 1 minute.. also you can check the connections to the control .. other then that you will have to repalce the control
Sep 29, 2008 | Hotpoint DY46 Style Line Stainless Steel...
You don't say what specific F code error. If it is an F7, go to the following link for my solution.
http://www.fixya.com./howto/h155060-dreaded_f7_error
I have shared my fix with over 1570 folks and most report success. I hope that it works for you too. Please let me know at:
hutchipop@yahoo.com
Feb 23, 2008 | Ovens
F code on kenmore oven
Please see the solution I just posted for OVENMAN/April 12, 2007. This gives my fix which may work for your situation.
Nov 19, 2006 | Kenmore 41389 Electric Double Oven
Ovens Logo
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
