Question about Dryers
Whirlpool duet dryer smells like smoke from back vent in dryer
I have been using the dryer for many cycles back to back and it started to smell like smoke when I kept restarting it when it would stop with the clothes still not dry.
    Genius:
  • 3,422 Answers
HI,
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
It overheats Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat (read about cycling thermostats in "Drying is too slow," above).
Posted on Nov 25, 2008
  • Dryers Master
  • 13,433 Answers
If you don't clean out the lint trap frequently, your dryer may have small lint fires inside the cabinet. The smell from these fires can leave a strong odor in the clothes drum.
Also, if there are any solvents, paints, lacquers, etc. in use in the house, your dryer may alter and/or amplify the fumes to an odor unlike the natural fumes given by the solvent, paint, etc.
Here's what to do:
  • First, clean all of the lint from the inside cabinet and ductwork of your dryer.
  • Have a qualified appliance repair technician inspect the dryer for damage caused by any lint fire.
  • Move all containers of flammable liquids at least 50 feet away from the dryer. Gas dryers have a large flame when operating properly and can ignite the fumes of any flammable liquid or gas.
  • Then, try to clear the odor, by running a couple of loads of old rags or towels.
  • 541 Answers
I would say the heater for dryer has gone you may need to buy a replacement
  • 10,515 Answers
First check the dryer vent to the outside, it if is blocked the dryer will overheat. Then check to see if the heating element is grounded to the canister or the bracket, if it is, the element would never shut off when the timer is on even with the motor not running. Turn the dryer to timed dry but do not start the dryer. Open the door and watch the rear left side to see if the element comes on, glowing orange/red/ If it does with the motor not running you know this element is grounded. If both of these check out, you might have a bad cycling thermostat.
Thnx.
New dryer smells hot
It is not unusual for new appliances, espicially high heat ones like a dryer to smell hot. Also if this is your first gas appliance it might smell different than your old dryer if it was electric. Keep an eye on it when using it to see if you see any smoke. Also check your venting to make sure it is all clear with no blockage.
Jan 10, 2015 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Ge duet dryer smells and is rattling
what is your model number is then we can get started then
Sep 09, 2012 | Whirlpool 8579123A DUET DRYER DR REVERSAL...
It is taking over 2 hours to dry a load of clothes. I stopped the cycle and opened the door to check the clothes. The dryer smelled like something was burning but no visible smoke. This is a fairly new...
Sounds like the vent is clogged with lint. You should have the vent cleaned once a year to keep the appliance operating properly. Also, make sure there are no kinks in the vent line.
liberty
Jan 20, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Error code pf
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 01, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Vent was cloged with a birds nest now it wont heat
IF POSSIBLE REMOVE THE DRYER VENT FROM THE REAR OF THE DRYER AND VACUME OUT AS MUCH LINT FROM THE DRYER ITSELF SOME LINT MAY HAVE GOTTEN BACK INTO THE BLOWER
Sep 02, 2009 | Whirlpool GEW9200L Electric Dryer
Duet Gas Dryer- burning smell
first is first ,,, disconnect dryer from plug,, now open bottom panel 2 screws ,, now go and get youre vaccum,shop vac, anything ,, reason for burning smell ,, usually catching on fire ,, we recommend do this 1 as year,,, after cleaning , put about 2-3 fabric sheets inside dryer and let it runn for about 30 minutes to remive smoke from drum,,, thank you
Dec 29, 2008 | Dryers
I run the gas dryer,i smell gas...turn off dryer,no smell.....
mostly that after burn,,check vent and vent exhaust reall good,,exhaust coming back in home..
Dec 08, 2008 | Whirlpool LER5636P Electric Dryer
Burning smell
We had the same problem. After we used it a few times, the smell went away.
Jul 06, 2008 | Whirlpool GGW9250PL Gas Dryer
My Duet Whirlpool Dryer (had this #8519498) has burning smell
I am not the Dryer fixin' trade...but I have this dryer. To me, it sounds like it overheating or the heater unit has become lose from its hold rack. I would MOST definitely have a pro look at it and do NOT leave the dryer unattended...It may be a possible fire hazzard
Take Care
Wayne
Jan 03, 2008 | Whirlpool GEW9200L Electric Dryer
Dryers Logo
1,591 people viewed this question
Top Dryers Experts
Marvin
Marvin
