Question about Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum
Bissell lift off vacuum about 4yrs old. Extremely noisy. OK until before Christmas but getting worse every time it's used. Washable filters washed, HEPA filter replaced. brush bar cleaned of every scrap, hose empty,everything that can be cleared has been. Noise high pitched, screeching and can only bear to use it for a few seconds at a time. Suction OK. Mine is so loud I can't use it very long-high pitch screech. Can this be fixed or does the whole vacuum need to be replaced? It still cleans great, but not worth my hearing. I'd hate to trash it if it can be fixed.
  • 107 Answers
Sounds like a bad motor. Could be either foot motor or main motor either way cost will be more than half of the unit.
Posted on Dec 08, 2008
I have Bissell Powerforce Bagless Upright Vacuum. it doesn't suction well. I checked the belt. It is ok. may be clog in the hose.I don't no how to clean. can you help me please?
- Check the dirt cup to make sure it is empty.
- Your vacuum has 3 filters. Dirty filters will restrict air flow. The filters may be hand washed in cold water with mild detergent. Allow them to completely dry prior to reinstalling them. The white HEPA media post-motor filter is not washable.
- Lift the upholstery hose from the bottom holder. Check for suction at the end of the hose.
If there IS good suction at the end of the hose, please unplug your machine from the outlet and try the following:
- Ensure the hose is firmly pressed into the lower hose outlet on the back of the vacuum.
- Check to ensure the brush is rotating. If it is not, remove the plate on the bottom of the vacuum. Check the belt and clean the roller of dirt and debris.
- Check the lower hose for clogs by removing the screw which attaches it and lifting the hose up to clean it out. Also, remove the larger hose by twisting it off and using a broomstick handle, push any dirt and debris through the hose.
Aug 05, 2010 | Bissell Vacuums
Vacuum extremely noisy
Mine is doing the same thing and my husband told me to purchase a new beater bar. I suggest you do the same.
May 26, 2010 | Bissell 6594 PowerForce Bagless Upright...
Cleaning the filters
There are 3 different filters on this particular model. Two of them are foam, and as washable, the 3rd is a HEPA filter that's located on the back and is not washable, but needs to be replaced once a year.
The most important filter, and the one that most people are not even aware of, is located directly underneath of the dirt cup. Directly under the dirt cup you'll see a black tray that says "pull". Pull this tray out, and you'll find a square shaped washable filter. Simply remove this filter and rinse it under water until it's clean. Make sure to let the filter completely air dry before reinstalling it in the vacuum and using the vacuum again.
The second foam filter is located directly above the dirt cup. Remove the dirt cup, and in the clear plastic housing that's directly above the dirt cup you'll find a circular colored plastic piece. Reach your hand up there, and unscrew this plastic part while pulling downward. You'll find a circular shaped filter that wraps around this plastic piece. This filter may also be washed the same way as the square shaped one, again just make sure that the filter is completely dry before using the vacuum again.
The HEPA filter is actually on the back of the vacuum in a grate that pull down to open it and remove it. This filter needs to be replaced only, and can not get wet.
The foam filters can be washed several times, but will sooner or later need to be replaced, as they will start to deteriorate after a few washings.
If you need to purchase these filters, here are direct links to all of the filters on your vacuum cleaner.
Square Shaped Pre-Motor Filter Bissell Part 203-1073
Circular Shaped Bissell Upper Tank Filter 2031085 Pre-filter Lift Off Series
Bissell Style 8 & 14 HEPA Media Post Motor Filter Part 3091
Here's a link to the parts diagram for your model also, this will help you locate the 3 filters.
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/bissell-lift-off-revolution-parts-schematic.pdf
Also, here's the link to the owners manual for your model as well:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/bissell-lift-off-revolution-owners-manual.pdf
I hope this helps you,
Chris J.
GoVacuum
Apr 09, 2010 | Bissell 37604 Lift-Off Pet Bagless Upright...
I recently cleaned all the washable filters in my Bissell Cleanview 11 vacuum cleaner and now the unit smells when it is in use. Can you tell me why?
They have mildewed while sitting...replace all the filters and place a couple drops of Citronella essential oil on each NEW filter element...clean after EVERY vacuuming using another vacuum and crevice tool. Good Luck
Jan 01, 2010 | Vacuums
Bissell easyvac filters
Replace Filter
As you vacuum, dirt and debris are deposited in the Dirt Cup
while air passes through the filter before being returned to
the room. This process enhances the vacuum path while
dramatically reducing dust, dirt, and potential allergens from
the air you breathe. Replacing the filter periodically enhances
vacuum power and air quality. To replace the filter:
1. Remove the Dirt Cup.
2. Grasp the filter frame and pull it straight from the Cup.
Empty the Cup.
3. Replace the filter. Push new filter into place at the top of the
Cup, place the small tab at the bottom of the Cup into the
slot at the bottom of the Canister cavity, then press the upper
portion of the Cup into place until the lock button snaps
into place. Use only BISSELL Style 6, #32047 Filters
[package of 2] in your BISSELL EASY VAC™ Model 3101-0.
4. EASY VAC™PLUS Model #3102-0 features a high efficiency
3M Filtrete™ Filter. To keep your cleaner operating at peak
efficiency and to remove irritating allergens from your
home, you should change the FILTRETE™ filter every six
months. Use only BISSELL Style 6, #32046 Filters [package
of 2]. The cup-shaped filter lifts out from the top of the
Dirt Cup, and the new one fits into place.
You may purchase these filters
by calling
BISSELL Consumer Services
1-800-237-7691
Monday - Friday 8 a.m. — 7 p.m. EST
Saturday 9 a.m. — 2 p.m. EST
or from the BISSELL website —
http://www.bissell.com
Jun 29, 2009 | Bissell 3102-0 EasyVac Upright Vacuum
Not so quiet anymore
If the filters was very dirty, you might have got some dirt in to the motor, best to have it checked
Dec 17, 2017 | Bissell Upright Vacuum - The Pet Hair...
Motor gets hot and stops running
Make sure all filters are clean, also check the inlet by the brush roll isn't clogged as well as the hose. If this is all ok, then there is a problem with the motor. There is a thermo protector that comes with the motor that could be bad.
Nov 29, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell lift off vacuum about 4yrs old. Extremely noisy. OK until before Christmas but getting worse every time it's used. Washable filters washed, HEPA filter replaced. brush bar cleaned of every scrap,...
Sounds like a bad motor bearing. If it is, then you would have to replace it. Could be the brush roll, did you check the ends to make sure they turn easily?
Apr 30, 2008 | Vacuums
Bissell Lift Off pet revolution vacuum losing suction
You may have a clog in the hose. Unhook the hose and see how the suction is there, if ok, then check the dirt inlet by the brush roll. If suction is low at the hose, then there is a clog in it.
Mar 20, 2008 | Vacuums
Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum Logo
385 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
