Question about Maytag 22.6 cu. ft. Side-By-Side Refrigerator with PuriClean II Ice and Water
Refrigerator won't get cold
I have a maytag side by side, and the refrigerator will not get cold. The refrigerator is about 5 years old. The freezer works fine. Any thoughts on where to start the trouble-shooting process. Thanks in advance
  • bbonsall Aug 15, 2008
    The coils inside my freezer are freezing up solid and the fridge section is not getting cold. This problem began 2 weeks ago when I had a can of soda explode in the freezer. Could be just a coincidence??? I used a heat gun and unthawed the coils, the fridge seemed to chill then. But, a day or 2 later the coils were frozen again.
  • 237 Answers
You likely have a defrost cycle failure. The freezer's cooling coils need to be frosty and cold so the air that the fan pulls over them can cool the fridge section. If the defrost cycle fails, the coils freeze up to a block of ice and air flow suffers (fridge is about 55 degrees F). The freezer stays cold only because there's a block of ice in there now... sometimes that cold "sinks" to the bottom and only the food at the bottom stays frozen (and can even freeze food at the bottom of the fridge compartment while the rest is warm). To be sure, you'll need to take the rear interior panel off the freezer back wall and check the coils to see if they are frozen solid. If they are then there's a defrost cycle failure. If they are showing a nice white frosty pattern evenly all over the coils then that's normal and maybe the evap fan (right above the coils) is not blowing air up properly or is not working at all. That fan should run if the compressor is running, etc. the only time it doesn't run is during an actual defrost cycle. Once you find out what condition the coils are in it should be simple to direct you further on the problem.
Posted on Jan 06, 2007
Maytag side by side refrigerator - refrigerator and freezer both not cooling.
I had same issue , required a new compressor and regas. All cooling for fridge side is blown in from freezer
Jan 25, 2013 | Maytag Refrigerators
Maytag Wide by Side Freezer not working
open the freezer panel at the back of the freezer section and check the evaporator fan, it could have been burnt.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Helloi have a Maytag Plus side by side refrigerator (about 10 years old) and I'm having trouble keeping the refrigerator side cold enough. This unit has dual slide bar controls on the ceiling of the...
remove the rear panel inside the freezer,your evaporator coil is iced over and cant transfer cold anywhere,deice it,then check the defrost heater under this coil,its probably open and cant heat to defrost the unit
Jul 19, 2010 | Refrigerators
Freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
Refrigerator not cold
Very usual issue - defected defrost control unit - replace it and keep warranty paperwork from part supplier. :))
Jul 22, 2008 | Maytag MSD2456G Side by Side Refrigerator
Maytag MZD2766GEW side-by-side - one side is not cold
WE JUST HAD THAT SAME PROBLEM AND IT WAS THE DEFROST BOARD. $50.00 REPAIR...
Jun 15, 2008 | Maytag MSD2436GR Side by Side Refrigerator
Maytag MZD2766GES side-by-side Refrigerator warm
is it frozen up? do you have any air flow thru the air tunnel from the freeze to the fridge? Check your air flow with the door switch pushed in. also check to see if the damper door opens... 1) if it is iced up you have a defrost problem. most likely a defrost timer. Turn off or unplug untill all the ice has melted off the evaporator back of the freezer..plug back in and it will work fine untill the ice builds up again. if this work you do have a defrost problem.. if not let me know and we can go deeper...
Aug 18, 2007 | Maytag MZD2766GES Side by Side...
MAYTAG MZD2766GE SIDE BY SIDE
Mine kept doing the same thing- the flap between the freezer & the frig is getting stuck. I finally just broke mine off & left it that way. Now the frig is really cold, sometimes things partially freeze- but that is better than going rotten. I now have a section under the water/ice dispense tray bubbling/peeling the white paint off. Mine is 6.5 years old & out of warranty, so I'm searching for a way to repair this problem. Any suggestions?
Jul 11, 2007 | Maytag MZD2766GES Side by Side...
Maytag refrigerator Model MZD2766GEW
Check the evaporator fan motor located abocve teh cooling coils in the freezer side.
Jun 05, 2007 | Maytag MZD2766GES Side by Side...
Maytag 22.6 cu. ft. Side-By-Side Refrigerator with PuriClean II Ice and Water Logo
968 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
