I recently brought a Blackberry 8100 from Ebay quite cheaply as it was listed as spare or repair. I have received it and managed to get it to turn on but all it says is "handheld is locked" and it has 3 options "unlock, emergency call, or cancel". I was wondering if this would be a user lock or is the phone blocked? Thanks in advance for any suggestions/solutions.
the problem is that i don't have a password for it and it keeps asking me to type in blackberry but my number 2 button doesn't work so if anyone can help with this too that'd be great. do i give up or can i get a replacement key pad?
You can't post conmments that contain an email address.
Your problem is the charge port on your phone needs replacement. We fix them through our ebay repair listings for $38.95. Just type "blackberry charge port repair" for your ebay search and look for the listings with "PORT REPAIR" around a charge port in big red writing. Our ebay username is "its-a-pheo" We have fixed hundreds of them and complete the fix the day we receive the phone from you. Feel free to email me with any questions at all... [email protected]
Its not possible that you can get correct code free. Its
comes from server & based on your IMEI. Entering wrong code can
missed your tries limit of unlocking This unlock code provider
generate full LEGAL unlock code direct from Blackberry server which wont
void your warranty, & generate code based on your IMEI, means
individual code for every blackberry set. After unlocking from this
provider's code your blackberry not only work with any single network,
you can use your in any part of world with any network including your
browser & MMS picture messaging to work, yes with just one time
entering code from your keypad. They unlock from network who locked
your blackberry like Verizon This site will help you a lot & good
email & 24/7 phone support http://blackberryimeiunlockcodes.com/
Sounds like your charging port has gone bad. Try CPR in New York City. They are faster than the
manufacturer, and cheaper!They
have a usual turnaround of 3-5 business days. And if you become a fan on their
facebook page, mention it and you will get a 10% discount.
Here is the link to their facebook page, it has all the info
you need.
My ball was sticking on my Blackberry curve ..I simply got a pin and gently ran pin under the metal edge of the ball..it worked.whether it removed the dust or what I'm not sure..but I'm pleased it is sorted...
If it is a keypad unlock code kindly enter wrong password for 10 time's you're Handheld will get wiped off. Then it will ask for reset password, Enter the new password and remember that.
NOTE:- No data will be available when your Handheld is wiped off.
look at the 6 pins on the phones charge port and see if one is higher than the others (usually on the end). if the pins is too far up the lower half doesnt connect to the charger. If your usb port will charge on via usb "DOCK" then more than likely the charger itself (which is way more simple to fix)
1.) if one of the pins on the phones charge port is pushed up, grab a sewing needle and GENTLY push the pin back into place,
2.) if the charging dock is working and is a usb charger like your wall charger, buy a new wall charger at your local electronics store.
To get the unlock code, mail or call ur service provider(Rogers) requesting for the unlock code i.e from where u have brought the handset.After receiving the unlock code follow the bellow mentioned steps:
Select manage connection icon and turn all connections off.
Select option icon and then select advanced option
Scroll down and select simcard option
First type MEPD and then type MEP2 (while ur typin MEPD and MEP2 it will not be visible on ur Blackberry)
Then type the unlock code which is given by ur service provider
