Question about Olympus FE-140 Digital Camera
Card-Cover Open When I turn my camera on I am given a screen saying "Card-Cover Open". My camera worked fine before this, but I'm unaware on how to fix this problem. Any ideas will be greatly noted.
  • 7 more comments
  • syedamer Dec 05, 2007
    I have Olympus FE-140 digital camera. I am getting message "Card-Cover Open" when I switch on the cam. Please help.
  • Anonymous Dec 27, 2007
    I have the same problem. When I turn the camera on it says the card cover is not closed, it is closed but I think I busted the latch inside that tells the camera it is closed. Is there anything I can do?
  • Anonymous Mar 19, 2008
    blurry, noises, lense going in and out
  • issy234 Mar 19, 2008
    When i turn the camera on, it starts making a few short buzzing noises, the lenses also goes in and back out again. Then i look at the screen and its completly blurry. Even if i reset it, it takes blurry pictures. Help!
  • Anonymous Mar 27, 2008
    Help
  • ravinandankk Jun 16, 2008
    after on i get card cover open mine camera is fe240 my name is ravinandan kulkarni mine email-ravikks@rediffmail.com
  • Anonymous Jun 23, 2008
    I have the same problem, I turn on my camera and it says that Card cover is open. I have no idea why it is doing this. Can you please help?
  • d-lano Apr 21, 2009
    i also have a fe140 the screen is saying card cover is open but i realize when i open the cover a white rubber is usually there is not there no more what can i use to replace it
  • Anonymous May 09, 2009
    Same problem, nothing seems to work-FE-140
YOU HAVE A BROKE SWITCH
THERE IS A VERY SMALL SWITCH BEHIDE A BATERY DOOR, JUST ABOVE A SIGN "PUSH TO EJECT" THIS SWITCH IS VERY SMALL AND YOU CAN NOT REPLACE SO WHAT YOU CAN DO IS, TAKE THE VERY SMALL SWITCH OFF (YOU WILL NEED TO USE A NAIL OR A NEEDLE TO REMOVE A SMALL PLASTIC SWITCH ) AND THEN STICK A SMALL PEACE OF METAL INSIDE OF THE HOLE (METAL TAPE WORKS GREAT) IT WILL BY PASS A SWITCH.
I USED TO BUY BAD CAMERAS ON EBAY FIX AND RESELL, ANY PROBLEM CONTACT ME KUNGLAO007@HOTMAIL.COM
TKX
Posted on Jul 12, 2009
Direct yourself to http://www.fixya.com/support/t115253-screen_keep_showing_card_cover_open
Posted on Jan 14, 2007
Card cover open fe 280
You can fix it with a small piece of tape inside the unit where the memory card goes. Just look inside for a sensor or a small button, and try pressing it down yourself. If that works, then maybe a slip of tape over that spot would fool the camera into thinking the cover is closed. If this is not fixing your problem take your camera to Olympus as this problem involves some built in mechanism troubleshooting.
Thank you !!
Jun 18, 2010 | Olympus FE-280 Digital Camera
DROPPED E-410
olympus repair is in Happauge, NY on Long Island
Oct 08, 2008 | Olympus EVOLT E-410 Digital Camera
When i power on my camers the screen says card-cover open
the switch that controls the door may be going bad.. and would need repair.. but you can try to reset the camera or leave battery out of camera for a couple days
Jul 06, 2008 | Olympus Stylus 720 SW Digital Camera
My Nikon Coolpix S5 has a broken lens; it son't fully close/ open. The message displayed on the screen says "Lens cover error". Is it something that can be repaired? How much would it cost to fix...
Hi , The lens cover error is because the stepper motor in the camera is unable to open the lens cover. I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc"  uploaded on site http://www.esnips.com/web/papputatiyasStuff    It will be helpfull for you. You have written that your lense is broken. In that case you can follow the procedure given in my doc to open the camera. You can replace the camera lens if broken.
Happy debugging Mukesh
Jul 01, 2008 | Nikon Coolpix S3 Digital Camera
Lens cover won't open
I have the same problema. Have you fix it? How? I appreciate your answer. Regards, Diego dspeier at yahoo.com
Feb 23, 2008 | Sony Handycam DCR-HC96 Mini DV Digital...
Card cover open
Ok, you do not have to do any desodering or sodering. Take the camera cover off 7 screws. Where the switch is there is a white box where the broken switch was. Gentley lift the top of the little box and wiggle it so it breaks off. There are 2 little connectors on each side of the box. bend them up and work the rest of the box off. bend the connectors back where they were, take a smal piece of electic wire and wrap it around each of those posts. I used tweezers. No more "card door open" error. This by passes it.
Feb 15, 2008 | Olympus FE-130 Digital Camera
Memory Card Locked
:'( i'm in the same situation right now! :(((( I want my pictires back! i don't know what to do!
Jan 04, 2008 | Canon PowerShot SD1000 Digital Camera
"Card-cover open" error message
It's when putting the card in.. typically you put it in and it clicks (so to speak).. if you delay removing your finger-push, it does something to the card and makes a Disconnect, although in looking at it, it looks just fine.. and the cover closes... A lot of people are reporting 'door open' errors. The micro-switch in the door housing is quite sensitive and pressure shifts from your hand on the door can cause it to trigger as if the door were opened. some get progressively worse. One fix is to add a little bit of length to the plastic that contacts the switch, either a layer of tape or a drop of epoxy, etc. This may help (or may not if the switch itself is flaky). Another fix discussed bypassing the switch altogether, obviously not for the faint of heart (or cameras in warrantee).
May 07, 2006 | Olympus Stylus Verve / ?-mini Digital...
Olympus FE-140 Digital Camera Logo
582 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
