Question about Samsung DVD-V1000 DVD Player/VCR
Dvd v-2000 Where can i get a motor for the dvd player.i found a belt, with the motor running it is slowing down and then speeds up.thanks for any sites for parts. Edward
  • edward dunaj Jan 05, 2007
    I'm sorry,I only have the dvdv-2000.
    Thanks for your quick response!!
    Edward
    President:
  • 3,130 Answers
Is it a DVD-V1000, or a DVD-v2000, as you have both listed? Go to http://www.samsungparts.com/search/search.asp and enter the proper model number and find what you need.
Posted on Jan 05, 2007
Portable dvd player slows or stops
The pladder motor that spins the dvd disc is failing, or the 5volts to the motor is flutuating, usually the whole assembly is replaced and is expensive.
Jul 18, 2012 | Zenith DVP615 Portable DVD Player
Speeds up and slows down
Dear Sir:
Please adjust the sensor speed for the main motor. Of course I am recommending Very Strong to RUN the software calibration for easy diagnose and troubleshooting.
Otherwise see my personal TIPS, for diagnosee
Trouble.
sincerely. God bless you
ernesto cuadra
managua, nicaragua. c.a
Mar 06, 2012 | Nordic Track NordicTrack A2550 PRO...
My proform 590 treadmill has these problems ; belt slips when running or walking ,speed goes up and down does not stay constant and you can hear motor noise increasing and decreasing in motor what should...
simple(maybe). go to the rear of treadmill,get the allen wrench that came with it,run at med-slow speed and adjust the rear roller with allen wrench. 1 turn per side 2 or 3 time then walk on belt until wont slip. all the problem is belt tension. also. make sure if it need lubrication under board and belt(some are lubless others dont).
good luck to you.
Feb 08, 2011 | Treadmill Doctor Proform 590Qs Treadmill...
Thomas Pacconi Model TPC-MSE-800 turntable runs slugglish. 78 runs fine but 45 or 33 runs slow. I removed belt cleaned it and platter. I put a drop on oil still same problem. Do I need a new belt? This is...
Pjam,
Had the same problem & checked around on the net. Several people tried replacing the belt, but it had no effect. Spoke w/ several repair shops around the country and they concur with what I'd read on the net - bad motors. 3 or 4 repair/supply shops told me getting a motor would be impossible. Since I only listen to 33-1/3 LP's, I messed around w/ it a little and found a solution. Take the turntable out of the unit & you will find a small circuit board attached to the bottom. On that board is a small square blue fixture w/ a white circular "dial" in the middle (has grooves to accept a small straight blade or a phillips screw driver). This controls the voltage to the motor, which in turn controls the motor RPM's. If you set the selector switch to 78, you can experiment /w turning that white circular "dial" to slow the motor down. It isn't very hard to get the speed set properly. The down side is that you will only be able to play 33-1/3 LP's, but they are probably the most common anyways. I assume you could do the same to set the speed for a 45, rather than a 33-1/3. Down side is that you will only be able to play 1 size LP on the 78 speed setting, but it's an easy adjustment that can keep an otherwise in-op turntable functioning. Good luck!
Dec 16, 2010 | Seth Thomas Pacconi Turntable
The turntable is not revolving at the correct speed slowing the record down
Sounds to me like your belt is streched. Under the felt of the turning section, there should be two rather large holes. Insert your thumb and forefinger and pull the table off. You should also see where the existing belt is running. Insert new belt around the motor first and replace the table section. Now, through the two holes, manouver the belt onto the table section until it spins freely
May 16, 2010 | Crosley CR49-TW Tweed Traveler Turntable...
Singer 258
There is no speed adjust, but 1st you must know the source of the slow down. Remove the belt from the motor pulley and run it, if it goes fast try turning the hand wheel if it is stiff the machine needs clean and oil. If it turns freely you motor may be dirty or just slow. If dirty, sometimes you can without the blet attached run it at full speed for 10 to 15 minutes. It should get faster as you run it. If not motor is weak or slow needs replace. Just replacement motor as genuine probably no longer available.
Jan 15, 2010 | Euro-Pro 9105 Computerized Sewing Machine
Motor runs slow with belt off then will speed up frigidaire dryer
bad motor / holding button will burn it out. ths keeps it on start winding . try blowing the motor out ( delint motor and dryer . ) it will run cooler . motor sounds like it already bad and needs replacement. mm
Dec 03, 2009 | Frigidaire FER231A Electric Dryer
Dryer runs but slows down then speeds up
There are no brushes fitted in the motor in these dryers..
More likely to be a worn belt, or possibly faulty start capacitor.,\which is located adjacent to the motor..
Plz rate my solution.
Thanks.
Jan 03, 2009 | Hotpoint TDC32 Electric Dryer
Samsung DVD-V1000 DVD Player/VCR Logo
76 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
