Question about Daewoo DSJ-4710CRA 47" Rear Projection HDTV-Ready Television
Convergence on daewoo DSJ4170CRA
How do I enter the service mode on the Daewoo Projection tv to do the convergence.
  • 198 Answers
SOURCE: Daewoo TV Question
there should be some buttons provided on the dash board of your tv... just enter the menu using those buttons n reset it back to the original settings
Posted on Feb 20, 2008
ginko
  • 19396 Answers
SOURCE: Service mode code
How to enter the service mode using the user remote control.
Turn the set on.
Direct the remote control to the reception window of TV.
Push buttons of remote control in sequence as follows.
→MUTE
→DISPLAY
→MUTE
Here you also get a service manual for a similar model.
Posted on Jan 06, 2009
SOURCE: I need daewoo dtc-29x5 service code mode through
how to do tv mode from monitar mode
Posted on Jun 09, 2011
  • 4 Answers
SOURCE: my daewoo DSJ-5510Cra 55 in. rear projection won't stay on
Have you figured out the problem yet?
Posted on Jan 02, 2012
gopakumarg43
  • 75767 Answers
SOURCE: service menu mode
You should first check the output voltages comes out from its main power regulator section; and to rectify the cause of this shut down first. Then only, there is any need to enter its service mode. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window. Service mode entry, adjust and exit procedure to many brand TVs are given in detail.
Posted on Oct 30, 2013
Use factory reset on a daewoo TV
You might have to enter its service mode to do this. If you wish to get more details about how to enter service mode to Daewoo TVs, check this site. Pull up older posts there.
Mar 24, 2013 | Daewoo DTQ-27U4SC 27" TV
"Perfect Focus" problem on Samsung HCN4727W
You have a bad sensor, a bad digital convergence board, or the new board is not working correctly. I would start by swaping out the convergence board or exchange it for another one. Good Luck
Nov 08, 2007 | Televison & Video
Service menu tv daewoo 3 menu
1 --> MUTE --> DISPLAY --> MUTE.
This is the normal method to enter service mode to Daewoo TVs. If you want to get more details, and more service mode entry proceedings, check this site named Electro-help. Try this link, and select it. There are service mode entry methods for so many brands of TVs.
Jul 06, 2012 | Daewoo DTQ-19V1FC 19" TV
PICTURE LOOKS BOWED OR SUNKEN IN
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows or 3D look like pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Oct 17, 2010 | Daewoo DSJ-4710CRA 47" Rear Projection...
Service code needed to complete convergence adjustments
I have the service convergence code: mute-1-8-3 (make sure your tv is on and set to antenna. if it doesn't work press S. Mode and make sure is says standard then re-enter code.
So, I have the code but I need the convergence chips. Where did you get the convergence chips?
Jan 26, 2009 | Samsung HCM653W 65" Rear Projection...
Daewoo projection tv...looking like 3-D
if the TV you are talking about is the DAEWOO DSJ-5510CRA.. u having a
convergence problem.. i hope this can help u in some way.
Oct 02, 2008 | Daewoo DSJ-5510CRA 55" Rear Projection...
Rear Projection Samsung w/ convergence out
I believe it is mute-1-8-3 to enter the service mode, HOWEVER, I have also read that until the convergence problem is repaired, i.e. - depending on the configuration, either 2 individual IC's located on the lower board with 'playing card' size heat sinks or a simple replacmenet convergence board, adjusting the convergence through the service mode is comparable to "ripping the transmission out of your car to fix a flat tire". I myself have not gone into the service mode since I am still waiting for the replacement IC's - I get to do a component level repair.
May 05, 2008 | Samsung PCL545R 54" Rear Projection...
Convergence problem
Well you need to get into your tv's service menu and service convergence mode. It's different for every tv. It means entering a code on the remote that opens up a secret menu for changing tv settings. Go to servicemanual.net and buy the service manual for your set, you'll be glad you did.
Mar 23, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Converge problem on a kp-65ws500 sony rear proyection tv
You can download a copy of the service manual that explains how to enter service mode and perform convergence of the red/blue/green guns, but unless you are comfortable doing something like this, you may be better off calling a good shop familiar with rear projection sets and getting a quote to have a convergence service performed.
Dec 16, 2007 | Sony KP-57WS500 57" Rear Projection...
Loss of convergence after powering off.
you must enter the service mode and align your convergence and save it to the epromm also activate the auto focus to activate the sensors , power on /mute-1-8-2- / press enter to save and before you exit activate the focus key on the remote ,very inportant to do the last step./g
Apr 29, 2007 | Samsung PCN5425R 54" Rear Projection...
Daewoo DSJ-4710CRA 47" Rear Projection HDTV-Ready Television Logo
49 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
