Well I have a gigabyte motherboard, it works fine with the integrated gfx, but when I insert my gfx card to install it, it beeps a long beeping noise.
    Problem Solver:
  • 13 Answers
Make sure the BIOS is set to boot to your gfx card, either PCI-E AGP or PCI, and not your onboard. The long beeping noise is referred to as a POST code. It will usually have a repeating pattern. Check your motherboard manual or visit gigabyte's website to see what the code is referring to. And you never know the card might be bad ESD happens when you least expect it. Try it in a friends PC.
Posted on Nov 25, 2008
3 log beeps on power on
Gigabyte doesn't list 3 long beeps as an error code, so I'm not sure if you're actually getting 3 short beeps or maybe 1 long and 2 short or... But, for reference, Gigabyte's error code list is as follows (depending on whether you have an AWARD BIOS or an AMI):
(AWARD BIOS)
1 short beep: System normal
2 short beep: CMOS Error
1 long beep and 1 short beep: Memory error
1 long beep and 2 short beep: Graphic card error
1 long beep and 3 short beep: AGP error
1 long beep and 9 short beep: Memory Error
Continuous long beep: Memory not correctly installed
Continuous short beep: Power supply unit failed
(AMI BIOS)
1 short beep: Memory Error
2 short beep: Memory parity check error.
3 short beep: Basic memory 64K address check error
4 short beep: Real Time Clock malfunction .
5 short beep: CPU error
6 short beep: Keyboard error
7 short beep: CPU interruption error
8 short beep: Graphic card error
9 short beep: Memory error
10 short beep: CMOS error
11 short beep: CPU cache memory malfunction
It might not be a lot of help, but it's somewhere to start... and at least this way you'll know what to be listening for.
Nov 30, 2013 | Gigabyte Computers & Internet
1st question== my friend gave me a p4vmm2 v8.1 mobo but when i turned it on it making a long one beep sound simultaneously inside ! there is no ram inserted! Is that the problem?????????? 2nd...
that's a functional motherboard you got there. The beep that you hear is an error beep for not reading a ram. Yes, you will insert a ram that is compatible with your motherboard. No you can't use that without a video card. If you've got a spare video card put it on your motherboard
Aug 02, 2011 | EliteGroup P4VMM2 V8.1 Motherboard
Just installed a gigabyte GA-7VT600 motherboard and on power up it got to bios screen and froze up. Now after trying to reboot I have no video of anykind. The pc sounds like it's running through boot...
Try taking the video card out and replacing it back...making sure that it is properly seated...if you can obtain another video card...try replacing the video card...this will rule out the motherboard if it works.
Dec 27, 2010 | Gigabyte GA-7VT600 1394 Motherboard
Please help me to determine the problem of my PC, it has no output or display on the monitor, the processor fan is spinning when pluged and then will turn off after a minute, the power supply is ok because...
you may have to find a manual for your motherboard, which could be difficult if you dont know what kind it is. somewhere on the mnotherboard is a connection for a speaker. the motherboard speaker, which is probbably noit installed, is supposed to give out "beep codes" when you have fatal or serious errors related to booting. if you can get ahold of a cheap little speaker and figgure out how to hook it up to the motherboard, you will get a series of beeps,. once you have the beeps, you need to go to the motherboard manufacturer's website to decipher the beep code.
without the beep code, i can still confidently say-
the problem is prolly your video card or ram, and you ve already checked the ram. if you have an integrated video card, you might be able to disable the integrated card in bios and install a new video card, or you may have to get a new motherboard.
Oct 12, 2010 | Computers & Internet
After working fine for about a month, screen suddenly froze with a few artifact lines. restarted computer with nothing on screen and continuous series of long beeps coming from case. This should mean a...
best thing to do is to get an RMA of your motherboard because even if you still want to use the a dedicated video card the side port video memory of your motherboard is still faulty..and for you to avoid other future problems with the motherboard
Sep 17, 2010 | Gigabyte GA-MA785GM-US2H Motherboard
My computer beeps but it beeps like a robotic sound..
exchange the memory in different slottt. clean the memory slotss and clean the memory with pensil eraser only the gold pinss., then insert them back in, if u can take the fan off and cpu check if its burned or anything then insert it back..
Feb 22, 2010 | Gigabyte GA-K8VM800M Motherboard
Amibios post code on a gigabyte board, 8 beeps 2 beeps 1 beep on GA-6rx board, no video output, have changed cpu, memory, video card, keyboard, hd etc, still no boot----help!
Hope this helps ... from the Ami BIOS website ....
8.2 POST BIOS Beep Codes
Number of Beeps
Description
1 Memory refresh timer error.
3 Base memory read/write test error
6 Keyboard controller BAT command failed
7 General exception error (processor exception interrupt error)
8 Display memory error (system video adapter)
8.2.1 Troubleshooting POST BIOS Beep Codes
Number of Beeps
Troubleshooting Action
1, 3 Reseat the memory, or replace with known good modules.
6, 7 Fatal error indicating a serious problem with the system. Consult your system manufacturer. Before declaring the motherboard beyond all hope, eliminate the possibility of interference by a malfunctioning add-in card. Remove all expansion cards except the video adapter.
• If beep codes are generated when all other expansion cards are absent, consult your system manufacturer’s technical support.
• If beep codes are not generated when all other expansion cards are absent, one of the add-in cards is causing the malfunction. Insert the cards back into the system one at a time until the problem happens again. This will reveal the malfunctioning card.
8 If the system video adapter is an add-in card, replace or reseat the video adapter. If the video adapter is an integrated part of the system board, the board may be faulty.
Copyright 2008
Sep 26, 2009 | Gigabyte Computers & Internet
Want to use dual monitors with sapphire x1550
no. if the integrated gfx are automatically disabled when you insert an add-on vidoe card,. then the internal gfx does not support dual monitor mode.
Mar 07, 2009 | Computers & Internet
I got beeps on my pc
1 Long beep and 2 Short is Graphics related.
Change GFX card if PCI/AGP
or if onboard install a GFX card and see what happens (with RAM and CPU reinstalled)
if it still bleeps with new card then remove power from PSU, remove BIOS batt and wait 10 mins (or do the bios jumper trick)
(still with new card installed)
just a thought... its always best to remove Data cables from board aswell as power from the devices (hdd,odd etc)
let me know how you get on...
Matt
Dec 08, 2008 | ASUS P5S800-VM Motherboard
Computers & Internet Logo
71 people viewed this question
Alun Cox
David Payne
David Payne
