Question about Mitsubishi VS-60805 60" Rear Projection Television
Green was working than it went out and one day it came back and worked for about a month and went back out and have not come back. What are some possible problems?
  • 10 more comments
  • sticks40 Dec 02, 2008
    I only have a Red, Blue, and Green Tubes.
    If I turn the Green screen knob under the screen it will glow with lines on the screen in green.
    I do not have a yellow tube.
  • sticks40 Dec 04, 2008
    the green crt is good
  • sticks40 Dec 10, 2008
    I tried cleaning did not work
    the green tube is good
  • sticks40 Dec 12, 2008
    The green came on and worked for 6 hours
    I know it has something to do with the PCB-RGB because when I switch the wires for red and green coming off the RGB board to the CRT board the green starts working and the red stops working. i can make the problem move from one CRT to another but I do not know for sure if it is the PCB-RGB board or the wiring from the PCB-RGB to the PCB-CRT.
  • sticks40 Dec 13, 2008
    Where can I buy a PCB-RGB board?
  • sticks40 Dec 17, 2008
    I am having a hard time find the RGB board.
  • sticks40 Dec 18, 2008
    http://www.mitsuparts.com/ do not carry the part.
  • sticks40 Dec 22, 2008
    Your solution was very helpful, the green transistor was dirty.
    Scholar:
  • 145 Answers
First check the power supply source of Your television. If it is OK then you will have to take your television to a qualified technician. Please don't try to service internal parts of your television. Since on one side you may loose out of warranty/Guarantee, additionally you may spoil it more than doing any good to it. There is always a risk of fatal electric shock. Please pay the money if you are satisfied with my answer. If not please get back, I'll be very happy to help you.
Posted on Dec 20, 2008
  • 395 Answers
Might need a new new convergence amp or convergence generator
Posted on Dec 18, 2008
  • 199 Answers
Another expert checked, replacement boards for the Mitsubishi V16 chassis NLA (no longer available). can you try component level repair?
i was made to understand that it will be better if you have service manual. does the RGB PCB board have Q2A23 transistor markings? If yes can you do out of circuit testing. normally would be 2 more similar parts. also check connection of GK connector (Signal board to RGB PCB), also RH, TH and others.
hope this helps.
  • 10,515 Answers
  • 10,594 Answers
Problem seems in CRT Connector of green tube or green RGB board.
I have suggestion, pull out green CRT board and spray WD-40 contact cleaner in holes of CRT Connector mounted on board and leave it for few hours.. then replug it with green CRT and try.
Posted on Dec 17, 2008
  • Shahid Electronics
    Shahid Electronics Dec 20, 2008
    Let me know did you performed cleaning of CRT base connector as suggested. Any feedback will be appreciated and will help me to check further.
  • 275 Answers
Go to this site: http://www.mitsuparts.com/ to find the part you need
  • 679 Answers
You need at least 1 color gun, I went thru a similar problem with a Sony. The problem is that unless you have the proper tools, installing a gun depending on the model, is from very difficult to impossible for the average person, and you could get really hurt badly because of the extremely high voltage, Let a pro do it. Mine cost more for the company to fix that it was worth, unless you have an extended waurantee, it may be not worth your wile to fix it, mine cost almost twice to fix as it cost new. Iwas fortunate because it was under an extended coverage, Also it was gone for 6 months. Unfortunatlly we live in a disposible society, and before you spend a few hundred (at least), you may be better off putting that twords a new tv. Peace, Gym
  • George Bill
    George Bill Dec 18, 2008
    It sounds like the gun was on the edge of going and finally went out. I believe in fixing anything that is fixable, but with these tv's, they have special tools and meters to measure the various voltages and sync those color guns. I know that the repair company that fixed mine spent several days untill they got it right.And they had the tools. As I mentioned you need to be careful because even unplugged the capacitors store high voltage, and you could get a real bad shock. Please at least call a few local tv repair guys and ask them what they think it is, I find that most folks will tell you if it's what you think or something else mine was still quite watchable and I thought it was just an adjustment, until the warranty people tested it and told me they had to replace both guns.
  • 1,183 Answers
you can order it for mitsubishi 1-800-553-7278
Posted on Dec 15, 2008
    President:
  • 1,952 Answers
5998.iso-parts.com/nsn/5998-99-687-1727 - 32k
Posted on Dec 14, 2008
  • 365 Answers
May be the circuit board is damaged or may have some loose connections.try to check it .thank you
  • JITHIN ANTONY Dec 17, 2008
    i think a capacitor is damaged .try to check it
  • 106 Answers
You probably have bad connections on the green crt board. You can determine this by removing the front speaker grille. Behind the grille, you will see a panel held on by philips head screws. Remove the screws and the panel and you will see the crt boards. The one in thre middle is the green. Now here is where you have to be careful because the tv needs to be ON and operating to do this test. Take something non-metallic (I have plastic screw drivers) and lightly tap on the crt board as well as the skinny glas neck of the crt. Tap LIGHTLY so as not to break the neck of the crt. Sometimes it is a matter of removing and reconnecting the crt board which fixes the problem
Posted on Dec 13, 2008
  • Mitsubishi Master
  • 19,396 Answers
When this happen, the fault is often due to the small board (sometimes called ballast) that powers the CRT. In your case it is the board that powers the green CRT.
It is also possible that you have a faulty CRT board.
The experiment you did replacing the connection on RGB board, lets think this is a defective RGB board.
This kind of experiments, like swapping contacts without following indications on service manual , can cause further damage to the tv.
To test the board follow thoroughly the indication on service manual.
Posted on Dec 12, 2008
    Genius:
  • 1,199 Answers
This sounds like a capaciter problem !and they may need replaced in the green lens (if this were a lens problem it would have not came back on! (Good news for you!
    Master:
  • 479 Answers
Its not the wiring .its the board
    Scholar:
  • 120 Answers
Oh, maybe it is a problem with the capacitator. The projector may be having the 'swollen capacitator' problem. Call up and authorised doctor and have it checked personally.
It may require the change of all the stuff inside. If you have the warranty and you haven't done anything wrong yourself, you can get it replaced free of cost from Mitsubishi.
If the capacitators are swollen even a bit, you should change them immediately to avoid any further damage.
Also, it may be a result of loose connections in the RGB picture section. It may even be a problem with the service provider ;)).
  • Mitsubishi Master
  • 5,138 Answers
Poor/bad solder connections .
Posted on Dec 10, 2008
  • 1 more comment
  • ladywinn
    ladywinn Dec 12, 2008
    It is very well possiable that the green tube, did short out, but to make sure this is whats wrong remove back see if all 3 tubes light up if only red and blue light up and not the green , Disconnected CRT board on green tube it could be the crt board.Look for bad componts on board,or just replace the crt board.
  • ladywinn
    I have new comment on your TV.
  • ladywinn
    ladywinn Dec 17, 2008
    WOW, I,ve never seen so many replys to a question ,YOUR CRT board to the Green Tube is bad .And This is a FIXYA reply.
    Genius:
  • 2,920 Answers
The green tube is shot and needs replaced
Posted on Dec 05, 2008
  • Ronnie Houston Dec 15, 2008
    your green tube is burnt out
  • 586 Answers
    As if the situation you told about, It look that this is due to carbon on the beam.Therefore,Two methods could be apply.First check C board and you will find there a small component having board mark
->I<-  written as "G" which is called GAP and if you see this two legs part it has a slight gap in the mid. Take a cloth or paperand clean it to clear dust or durt from it.Hopefully this will work.
Try it and reply me.
Thanks
Posted on Dec 04, 2008
    Sergeant:
  • 217 Answers
    Sergeant:
    Champion:
  • 283 Answers
Hi, please dont rate me if this could not fix your problem. Need to replace its tv lamp. Thank you.
  • 4,806 Answers
Its the green lamp inside the unit which has blown, you can usually replace these because the have a short shelf life, refer to your manual on how to replace it
kind regards
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Your query "What are some possible problems?", offhand possibilities are:
  • the small PCB at the rear of the lamp (most likely);
  • the lamp itself (likely);
  • power to the PCB coming from the secondary of the FBT (least likely).
This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Dec 02, 2008
  • 2 more comments
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
  • Louie  Role
    Just a thought, is the Mitsubishi using component video signal? If yes, possibly another cause is the green component either form the source side or the input processing board.
  • Louie  Role
    Louie Role Dec 13, 2008
    Hi again,
    • PCB-RGB board - try tapping on the board with an insulated rod. I am tempted to think that it is a cold solder/loose connection;
    • wring from the PCB-RGB to the PCB-CRT - The wiring could be checked/eliminated by a continuity check.
  • Louie  Role
    Louie Role Dec 14, 2008
  • 3,037 Answers
Sounds like the ICs need to be replaced. Whoever replaces them needs to know how to solder them back onto the board which requires some electronic experience. they should be STK-xxx where the xxx is a number. Make sure when you open the tv that you avoid all capacitors and touching anything that may still have power running through it. If you have questions while doing this, please let me know
  • Benjamin Patri
    Benjamin Patri Dec 04, 2008
    Have you looked into the convergence ICs, these are what you should be replacing. Let me know if you have questions relating to this as I will gladly help.
  • Benjamin Patri
    Benjamin Patri Dec 05, 2008
    Again, have you checked the ICs? These are the most likely culprit. There are two of them that would need to be replaced
    Genius:
  • 1,550 Answers
The green color is missing because the green picture tube is not lighting up. There are two possible causes for this:
  • The picture tube is bad and need to be replaced. This can be confirmed by a technician by opening up the TV and checking inside if the filament on that particular CRT is lit.
The other parts which you need to check are flyback transformer and high voltage splitter .
    Genius:
  • 1,269 Answers
Check the lamp specially the yellow one. It might be blown. Double check any cold solders and other neighboring parts that might be malfunctioning or burned.
    Top Expert:
  • Mitsubishi Master
  • 81,400 Answers
If the green crt was ok it would work, the circuit board that supplies it is defective, it will cost more to fix than TV is worth, the new LCD's are far superior, the prices are low, replace yours.
I bought Logitech wireless Performence mouse MX 08.30.2011. I charge battery 30-40min and indicator show that battery full( three green laps stiil green). But after I work two days my battery day. It is...
That is not close to normal and if I were you I would send it back and request a full refund, including your return shipping. Better yet, tell the vendor to send you a call tag so you are guaranteed you will not incur any additional loss on this item.
Sep 23, 2011 | Logitech MX 1000 Laser Cordless...
Screen went green
Sounds like its eather a bad screen or the plug underneath the cover is loose. (If your going to try to check the plug be careful not to break the case or any wires)
Sep 02, 2008 | Toshiba Satellite A105 Notebook
Mitsubishi VS 5047. Won't turn on. When the on switch is pushed it immediately turns itself off.
I had just put in about $500 worth of work into this TV to clean the color tubes of bacteria and other miscellaneous problems - They kept my TV for 3 months before bringing it back. It worked for 2 days and then everything went green, so they came back and took it for another 30 days before bringing it back.
This new problem could have been anything as simple as a tube to a circuitry problem. We decided to junk this Mitsubishi product. I have a 30 year old Curtis Mathis TV that I've never had any problems with (that's 3 times the age of the Mitsubishi).
We've opted for a new 50-inch Panasonic Plasma with the anti burn in technology. I will not buy another Mitsubishi product, or a rear projection TV of any brand after this experience.
Aug 17, 2008 | Televison & Video
Remotes no longer work
I had this exact same problem. After a week or so it started responding to the remote control again. Then after a couple of days it stopped responding. This problem came and went for about a month, then one day the entire TV went dead. When I powered it on, the green light appeared for 2 seconds followed by a sequence of 6 flashing red lights that repeated. I brought my set in to a repair shop and they replaced the power supply board. That fixed the problem and now the TV powers up and responds to the remote control again. Total charge was $250. That was very disappointing for a $1,500 TV that was only 18 months old. I'm going to let Philips know how disappointed I am in their product!
May 28, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Black out
Green isnt controled by the Convergence ICs that is controled by electrical settings programed into the service menu. You will no doubt need to troubleshoot your set. I work for a site that sells service manuals that are emailable and will provide free unlimited support to help you do the diagnosing and order any parts you need. If you would like me to post a link, let me know.
Mar 24, 2008 | Samsung PCL545R 54" Rear Projection...
Picture has green tint on startup
Jar-Head, bad news, the picture tube has a mild short in the green cathode, tech can come out and try to restore it but it`s usually a futile attempt on sony tubes, sorry to be the bearer of bad news, BMW Rider
Jan 14, 2008 | Sony KV-32S26 32" TV
Green screen vizio lcd
My 37" vizio I bought in Dec 2007 did this (green screen at start-up on all inputs). At first it went away by itself after you left the unit on for 15 minutes, but then 2 days later the whole thing DIED. Luckily Costco has a 90 day return policy on TVs.
Vizio tech support suggested this (before it died that is):
Please try to reset all setting and then to see if the problem is solved. 1. Press the Menu on your Remote Control;
2. choose Set up on the OSD;
3. then choose Reset All settings;
4. Press the Exit on your Remote Control to remove the OSD.
Nov 27, 2007 | Vizio L37 Television
Red Screen
try tapping lightly on the tub that matches your color problem.
do you see it come and go? if so then you have bad tubes.
you can try to rejuvenate them but is not recomended.
Jul 06, 2007 | Akai PT5598HD 55" Rear Projection...
Mitsubishi VS-60805 60" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
