Question about Blaupunkt IDC-A09 5-Disc CD Changer
IDC A09 NOT RECOGNISED.
Hi, I removed the fuse from the back of the head unit. Waited 15 minutes. Put back the fuse and connected the changer. Waited about a minute while the changer buzzed etc then I turned on the radio. Radio still worked fine. I installed a cd in the cd changer and then pressed the SRC button on the head unit, the display said No tape. What is the next step.
Thanks. Stephen
SOURCE: cd-changer Blaupunkt IDC-A09
The solution is to disconnect the head unit and the cd changer from each other and from the car itself, leave it for ten minutes. reconnect and turn the ignition on but not the car itself, enter radio code if has one and all should work.
Posted on Jan 03, 2007
SOURCE: Blaupunkt IDC-A09 5-Disc CD Changer
Ive got the same problem ive got a 2000 fiat punto hgt comes with the nav headunit and the Blaupunkt IDC-A09 changer the buttons just flash on the changer but nothing else it says error no magazine on the headunit too ???
Posted on Jan 16, 2008
SOURCE: CD Changer Blaupunkt IDC A09
EBK zeewolde can get code out of serial number
coast 25 / 30 euro
i try to get code for cdc on my vistion radio cd
and try to use disconnect l / r output cdc and place mp3
signal to radio input when cdc turns
greets wilco1v @12move.nl
Posted on Sep 05, 2008
Eagleeyes
  • 199 Answers
SOURCE: Blaupunkt IDC-A09 NOT RECOGNISED?
try unplugging both the changer and the head unit, leave it for 10 to 15 mins then plug the head unit in 1st, then the changer.
let me know how you get on
Mark
www.blueice-electronics.co.uk
Posted on Nov 25, 2008
Warf135
  • 137 Answers
SOURCE: Peugeot 307 Blaupankt CD Changer IDC-A09
Hi, I know this is an old post, but I'll reply, so that other readers may get the benefit of my answer.
2004 was the year that Peugeot/Citroen changed from VAN bus to CAN bus wiring on their stereo's. If your car is before or early 2004 you will need the IDC-A09 blaupunkt in dash changer, which should just plug in and work straight away.
However, If your car is later 2004 onwards you will need the IDC-A04 Blaupunkt changer which will plug in and power up, but will not work properly untill you go to a peugeot dealer and they hook up some diagnostic software to tell the car a changer has been added. Both the IDC-A04 and A09 changers look identical.
I would say that you got the wrong changer, as the IDC-A09 changers in pre/early 2004 should just plug in and work.
Remember: Pre 2004 cars need IDC-A09 (plug and play) and Post 2004 cars need IDC-A04 changer (get pug dealer to reprogram cars computer)...its a costly mistake if you bought the wrong one!
Posted on Apr 05, 2010
I removed my PU 2471A head unit and Blaupunkt IDC-A09 changer from my Peugeot car as both had minor faults caused by my son putting objects into cd slots.Prior to this both units worked perfectly in...
The head unit needs reprogramming with planet to accept the CD changer....... a main dealer or any good local garage should be able to help you with the software needed.
May 27, 2017 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt IDC A09 not recognised
If the unit you replaced it with is exactly the same model as your old one and its the same head unit, then i would check the lead, try wiggling it and seef it recognises it, if not then someones sold you a dodgy cd changer from ebay
Mar 12, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt IDC A09
Hi, do you have the IDC A09 PSA or just the IDC A09?
Nov 23, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Mark
Oct 28, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
coast 25 / 30 euro
Aug 02, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt IDC-A09 5 Disc Changer
Hi try unpluging both the cd and the head unit from power for 30 mkins or more. this should reset the system. plug the head unit in 1st then the cd.
regards
Mark
Jul 23, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
IDC A09 installed in Fiat Punto
After incorrectly entering the code 3 times, the unit locks for 60 minutes. To clear it, leave it connected to the head unit and the radio switched on for an hour. After that, switch the radio off, disconnect and reconnect the cd changer, and enter the correct code.
Jun 18, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Not playing!!
hi the A09 has to be married to the head unit, unless your model is the A09 PSA.
Mark
Apr 02, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Cd-changer Blaupunkt IDC-A09
Sep 24, 2006 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt IDC-A09 5-Disc CD Changer Logo
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
