Question about Sony Network Walkman NW-A3000 MP3 Player
Screen displays only 'white noise'
When on, the only thing which will display on the screen is what can only be described as a still 'white noise'image such as you would get on a tv with no signal. The screen lights up and goes dark, the player plays music etc as it should, although the screen seems locked onto this scrambled image. Reseting the unit makes no difference. Any suggestions what might have happened of how to solve the problem please?
  • pilitio Apr 06, 2008
    same problem...
  • Anonymous Nov 14, 2008
    same :(
Same here mate
Posted on May 05, 2008
Why is My screen white when I power it up and won't change?
There's nothing switching the display. the back of the screen is usually a bank of white LEDs behind a diffuser or a white florescent flat tube. That is what you are seeing. In front of this is a layer with each pixel point represented by a blue red and green LCD cell.
When current is applied the structure of the LCD becomes amorphous and the light shining from behind lights up the pixel through a polarising screen.
If you can see the white backlight then some thing may have gone drastically wrong with the display. that's unusual because normally the display is all 'off' when the display is at rest (no current). So either your display/ video output is in serious trouble or it's another issue that I can't answer because there's not enough info.
You may need to take it to a repair technician to assess the situation in person.
Mar 17, 2015 | Sony VAIO Computers & Internet
White spot on screen
Sounds like you are describing stuck/dead pixel.
There is no fix, it is a Pixel gone out in display panel, good chance it is just stuck and will right itself but sadly sometimes they dont and the only fix is to replace the entire display panel
Manufactures warrant such defects different depending on amount of dead pixels on screen is considered faulty, ie 3 pixels grouped or 5 separate ones .
Jan 12, 2008 | Samsung HL-P6163W 61" TV
Patchy on screen and can't read
Video issues like you describe can only be two things in hardware either a Video card, or display. Patchy display is typically a bad display that has been dropped or damaged. On the software side a new driver or update can cause image problems but typically it will be no display vs. patchy display.
Feb 26, 2014 | Lenovo Computers & Internet
White screen problem on my motorolla w376g tracfone
It seem you have damaged part of screen where you hit the scale.
Do one thing try to disassemble screen and the re assemble screen and then check. It seem you have physically damaged your screen.
Better to use glass on your screen.
here are some secret code for motorola mobile.
here is display code for motorola
*#402# press ok you can adjust display contrast brightness etc.
Jul 22, 2017 | Cell Phones
My acer 4315aspire laptop problem is .1st i on a laptop and my laptop screen is completely white.then i restart my laptop so screen is good during a work screen is again white.so plz help me my problem...
hi.
your problem is there are 4 possibilities.
1 - LCD problem
2 - problem with LCD cable
3 - inverter problems.
4. display card problem
to identify the problem, you have to do troubleshooting.
1 - The first thing you should connect the external display
(monitor) on buieldin display
If display appear in a normal on an external display, this means that there is no problem on display card.
2 - If you have identified the problem not the display card, you have to do further troubleshooting process by opening the cover lcd screen on your laptop, and perform troubleshooting of hardware one by one in the list.
1 - LCD screen
2 - Inverter
3 - LCD Cable
after you do all of these processes will know your results.
Normally the problem is the lcd screen.
Regards
Apr 29, 2011 | Computers & Internet
My N72 is not showing any display... just a simple white colour screen
Did your phone drop on the flow? Is it just showing white and still works ?or Display white screen and not working?
For a phone to display a white, does questions need to be answered..
If it fell on the flow it's usually a screen fault and it needs to be replaced.
If it didn't fall down, but displays white screen and nothing function,it a software faulty needs a memory restoring..
If just showing white screen and you still can make calls with it, then it's screen fault needs to replace..
Feb 11, 2010 | Nokia N70 Cellular Phone
The screen stays white and displays nothing
get a new one or call nintendo and tgell them
Feb 07, 2010 | Nintendo DSi White Console
Nokia K750i
If the new screen is white and old screen displays 20% of the display then you can check by flashing the software , in most the cases white screen is the software problem.....
Aug 17, 2008 | LG M4410 Cellular Phone
Nokia 7610i shows white screen
just re format your fon for highest version
Aug 22, 2007 | Nokia 7610 Handheld
Sony Network Walkman NW-A3000 MP3 Player Logo
207 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
