Question about Kitchen Ranges
Stove the pressure regulator is not working - Kitchen Ranges
  • 333 Answers
If you are sure that it is the regulator you should have it relaced by a qualified tech. You have to remember that you are working with natural gas I assume and that safety come first. You do not want to have a fire for a problem that could be avoided.
Posted on Nov 25, 2008
OVEN FLAME TOO HIGH ON A A GE CONVERTED TO LP
You should have a pressure regulator between your stove and your propane bottle. It's probably delivering too much propane at too high of a pressure to the stove.. If you don't have a regulator, THAT would be your problem. A regulator set to too high a pressure makes flame too high and flame may even try to blow itself out. I've remedied this by taking a small cover off the center of the regulator and adjusting a screw.. (Not all regulators can be adjusted.) If adjusting isn't possible, I'd suggest a new pressure regulator (for LPG). Note: A regulator for LPG is NOT set up the same as a regulator for natural gas.
Oct 28, 2013 | GE Profile JGSP44 Dual Fuel (Electric and...
We have a Frigidaire electronic ignition range about a decade old. The stove works fine. But lately we've noticed if we're using any stove elements the oven won't ignite and heat up. Conve
Sounds like the pressure regulator on the stove is going bad. The pressure regulator is located in the back. Your gas supply line should connect directly to it.
Dec 23, 2012 | Kitchen Ranges
Why does my coleman stove regulator leak gas from the hole on the top of the regulator
Its a safety feature of the regulator. The regulator is designed with a pressure release valve. This has happened to me twice: once with a carbon dioxide tank for my kegerator and once on my propane stove. In both cases I left the regulator (designed with a max pressure rating of X psi) attached to a full bottle in the sun. The heat caused the pressure to exceed the limit of the regulator and the release valve popped. A welding supply store may be able to reset/replace the mechanism but in my case I just bought a new regulator for about $15.
Aug 14, 2011 | Coleman 2 Burner Propane Stove 5430E700
The pressure regulator or is it gas regulator I'm nor sure. on my Americana gas stove has NAT. 4.0" LP 10.0" written on it. What does that mean?
Natural Gas pressure is to be regulated at 4.0 inches of mercury and Liquid Petrolium Cas at 10.0 inches of mercury pressure.
Mar 26, 2011 | GE Microwave Ovens
I have a whirlpool gas stove, professionally converted to propane and it"s cooktop doesn't cook hot enough when frying, it doesn't crisp the surface I don't think the burners are burning at the correct...
Have them come back and check the gas pressure... either the tank regulator or the stove regulator are running at too low of a gas pressure... for propane it should be at least 10" WC...
heatman101
Aug 31, 2010 | Whirlpool Kitchen Ranges
Gas stove, burners work, oven doesn't
Is the igniter in the oven is working? (it should glow orange) If not, then you may have a broken or defective igniter. If it is working, but the burners don't light, then the appliance regulator on this model may have a small shutoff lever that turns off the gas to the oven. It may have been inadvertently closed. Follow where the gasline hooks up to the back of the stove. There will be a silver regulator about 3" x 4" size that regulates the gas pressure. On the outside of it, is a small lever. Flip it and see if that solves the problem. If you need more assistance, leave another comment and we'll trouble shoot further. Douglas
May 26, 2010 | DCS RGS-305 Professional Gas Kitchen Range
A customer has a commercial propane gas stove,
Faulty thermostat, can be the only reason if the burners on the top are okay and don't fluctuate. That proves your regulator is fine. You could also check the line somewhere with a pressure gauge, or manometer.
Sounds like they need a new rep. Contact the company's service department. These guys have often come across the problem before, "oh yes, we had a batch of thermostats that had faults about 4 years ago. We didn't do a recall because it wasn't a safety issue". Meanwhile, the rep is only after sales and commission.
Aug 08, 2017 | American Range ARW36-6 Stainless Steel...
1994 Starcraft pop up. My gas line must be clogged. We trouble shot it and can only get a little flicker from the stove. Tested other tank and regulator. Would opening lines and blowing out with compressed...
My buddy just had the same problem, the only way he got more pressure was a new fuel supply which consisted of a small bottle near the stove. We never did find out what caused the fuel to stop. But he had no pressure at all. And it worked fine before. I would try blowing out the line, then try it without the regulator. The 20# bottle is not that powerful, just crack the valve to get it going, the regulator is set for about 3#, They make adj reg. Thye also have rubber lines with shut offs and reg on them. Hope this helps.
Mar 10, 2010 | Electronics - Others
No propane flow to grill using bulk bottle system.
the office that is open on the bottom of the burner sound like a spider has taken home to.. the hole.... This happened to mine. a small pipe cleaner or wire will break it up...try that. also did you feel the top of the tank regulator and see if it has froze. try turning the tank upside down and turn the unit on.... this may also help by forcing the spider debris out.
Jun 05, 2009 | Coleman Roadtrip Grill LXE 9949-750
My propane camping stove is burning with alot of soot.there seems to be an oily discharge in the line when i disconnect.the line runs directly to a 20 lb bottle bypassing the regulator as it is a high...
soot is incorrect gas / air mixture--too much gas
I am thinking that it is designed to run with screw on bottles ( low pressure ) yet you have connected it direct to a 20 lb bottle with out a regulator and have got adaptors to enable that
Not only do the regulators act as blow back extinguishers ( preventing a cannister explosion ) they control the gas pressure to obtain the correct air /gas mixture
try attaching a regulator to the top of the bottle , them a hose to the camping stove and your problems will be solved
Dec 02, 2017 | Sport & Outdoor - Others
Kitchen Ranges Logo
81 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
