Question about Whirlpool LSR5132PQ Top Load Washer
WASHER Im tring to put a balance ring on myself and i dont know how to take off the cover of the washer to put it on please help.
    President:
  • 878 Answers
You have to remove the cabinet. Remove the screws on each end in back on the consol. The consol will then flip up. Remove the two snap springs holding the cabinet on. Unplug the lid switch. Now the whole cabinet will pull off. Check out the pics...Catriver...post back.
Posted on Jan 06, 2007
  • Ron Marek
    Ron Marek Jan 06, 2007
    another view
Balance ring
I don't think a coin could travel to that point-Icould be wrong but regardless its time to roll up the sleeves get some old towels to wipe up the mess and dig in and see whats going on in there-cheers Denny
Oct 24, 2013 | Frigidaire Washing Machines
Constant out of balance on washer
Check the inter tub ring you should hear water when you spin it by hand
if you dont hear water replace the spin tub balnce ring it must be cracked or has a hole in it and leaked out the fluid this is a counter balancer when it gows into the spin cycle
h Tech AL Wojo
Apr 01, 2013 | Maytag Bravos MTW6600T Top Load Washer
I replace the kenmore washer timer and i keep turning the knob .Now i dont what load im on cause im tring to reinstall knob
Before installing the new timer, make sure it is in the off position. Also make sure the washer in the off position. Then you should easily be able to tell.
Feb 11, 2011 | Kenmore 16812 Washer
What is the liquid in the top ring of washer
its called "Calcium-Chloride",its a type of salt water mixture put in these rings to dampen "OFF-Balance" loads in the washer,and the reason for this type of mixture is so people that store or operate the machine in below freezing temps do not have a solid off balance chunk of ice that wont balance the machine during operation or break the ring when it freezes
Jan 14, 2011 | Haier HLP23E Top Load Washer
Im tring to find instructions on how to install a harmonic balancer for a 01 chevy impala
If you have a manual, likely you are looking in the wrong place...that would be listed as part of any timing chain removal, front seal removal etc.
Balancer is removed by taking off any pulleys attached to it, removing the center bolt, then using a harmonic balancer puller (specific tool).
To put it back on, just put the new one on the crank snout, put back in the center bolt and washer and tighten it up. (anything that is in your way and preventing you from getting in there needs to be removed as well)
May 30, 2010 | 2001 Chevrolet Impala
Spinning is out of balance even when there are no clothes in the washer
Most has a balance ring built onto to the tub, make sure thr balance ring is not damaged, It is normal for the tub to shake in the spin cycle with nothing in washer
Dec 22, 2009 | Kenmore 22422 Top Load Washer
You can hear water still in the washer - not inside the tub where you put the clothes but inside the washer machine.
I believe you are referring to a GE top loading washer. GE uses a liquid filled balance ring around the top of the washer to help compensate for off balance load. The sound is perfectly normal.
Aug 28, 2008 | GE Washing Machines
Whirpool Washer, Loads become unbalaced in spin cycle.
it has a bad balance ring on the top of the basket no so hard but not that easy either
you have to remove the case to get to the balance ring
go to www.sears.com and go to parts and put in the full model number, under the parts tab in appliances and select view brakedown and it will explain it better with you seeing it
May 08, 2008 | Whirlpool LSR5132PQ Top Load Washer
Spin Shake ...
yes the water is supposed to be there, thats called the balance ring, some machine use cement others water. you say the washer is unbalanced even when empty, is there an indicator or is the machine itself physically off balance. if there is an indicator the off balance swich might have gone bad or you might need to adjust the leveling legs.
Jul 03, 2007 | Frigidaire CWS3600AS Top Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
41 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
