Bosch 24 in. SHE56C05UC Stainless Steel Built-in Dishwasher Logo
A
Anonymous Posted on May 26, 2012
Bosch dishwasher she33p02uc
Rack clip
1 Related Answer
Ian
  • 51 Answers
  • Posted on Jul 24, 2007
SOURCE: Upper Rack
Contact Bosch and ask if there are any other rack configurations for this model. From memory I think there might be 1. I also remember that they made an insert to go into this particular top draw...check on that also Regards
Top rack on bosch dishwasher will not close properly and door won't close because of this. How do you mount the top rack properly?
You need to make shore the wheels are on the track properly. Check how the rack bellow sits.
Also check at the back make shore nothing has been broken or blocking the wheels from going in all the way.
Regards Craig
2helpful
The top spray arm of my Bosch SHE6AP05UC seems to have fallen off during a cycle and I cannot reattach it. It doesn't seem to snap or clip in like it looks.
Hello, welcome to FixYa.
If you align the spray arm to the section of the upper rack which it fastens to, as shown here...
Then place it against the holder and turn, it should grab the holder, unless something else has broken...but it should be that simple, i.e.
This is the official explanation from Bosch below...
Hopefully that will help you move forward and answer you question. Let me know if you need any further assistance, otherwise good luck.
Thanks for visiting FixYa.
Regards,
Macmarkus :)
How do I get more of those small plastic "clips" and fit onto the sliding rack?
http://www.bosch-home.com/us/psearch.html?q=clips
hello, this is mike. I think this is what you are looking for. If this is not the "exact" item, you should be able to find it on this site.
thanks
Hello there, I have a Bosch Logixx dishwasher which I purchased just over 2 years ago. My upper dishwasher tray is not fitting properly into the hose pipe holes on the inside of the back wall of the...
Hello Deepak,
You can definitely fix this yourself, but I'm not entirely sure from your description which part is "dropping off". It may be a simple fix where something needs to be clipped back into place or you may need to replace something. Please can you take a look at the images below and identify which part you are having trouble with.
Below is the back of the upper spray arm which clips on to the upper rack. It has a grey plastic cover behind which is a large white plastic washer / gasket. The washer simply slots in to the back of the spray arm and the grey cover clips in over the top.
Your description suggests the grey plastic cover and/or the white washer are dropping off. If the grey plastic cover is missing, it may have fallen into the bottom of the washer under the lower rack, in which case you should be able to find it and clip it back on. If it's missing or wont clip back on, you will need to replace the upper spray arm as the cover and washer are not available separately.
This is the water delivery tube which clips to the back wall of the washing compartment. There is a metal clip which secures the tube to the wall. The open hole and one of the spigots slot in to the two holes in the back of the upper spray arm above. The spigot used depends on which height setting the upper rack is on.
Basically, everything simply clips together. If nothing is broken, you should be able to fix this at no cost by simply clipping the offending part back into place.
Hope this helps. If you need further assistance or help locating replacement parts, please let me know what needs to be replaced. Nearly all Bosch parts are available and in stock direct from Bosch.
Regards,
BElectric
2helpful
Wheels keep falling off on lower rack, clips all
the clips come with new wheels, they should cost about $4 for four, I would replace all wheels on the lower rack
Are there replacement racks for the bosh SHE43M that are NOT "platinum" which are silicone coated (slippery) and the rack slants downward toward the sides so glasses and cups slide and bump into each othe...
i dont have an answer... i simpkly have a similar problem. just bought and installed Bosch SHE45M06UC dishwasher - and nothing seems to fit in the racks. Can one get other bottom racks of a different design?
Bosh dishwasher shu3322uc/22
check for leaks where the the top rack plugs into the rear. it might not be sealing. If your unit has the ability to change the top rack height check in the other position and see if it works. In my Samsung (Bosch in disguise) model The tube to the top rack plugs into one of two holes in the rear, depending which rack position I use. Something covers the hole not in use. Bosch uses two seperate pumps for washing and draining. So I don't think the pump could go partially bad. (This happens in other brands when the solenoid gets stuck between pump out and recirculate)
Upper Rack
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
