Question about Water Heaters
Parkray Cumbria efficiency problem
Hi, we recently replaced our trianco tr45 burner with a parkray 99 (both smokeless fuel). The old burner used to make the house fabulously warm and heat the water so hot we had to run it off to stop the pipes banging when it boiled, the new burner seems much safer (boiling water was scary lol) but doesnt seem to heat the water or the house anywhere near as well.
We have the correct number of radiators for the model (3 less than max) but when we get the fire banked up high and turn on the pump it doesnt heat the radiators as well as the old one did (no air bubbles but just not as hot as they were) and it seems to take ages to heat them up.
When we turn the pump off to heat the water for a bath properly (as instructed in the manual) the radiators go stone cold in about 5 minutes, so the house gets cold, and with the pump on the water wont go above luke warm really. With the old burner we never needed to turn the pump off because the water was always hot anyway.
Should this be happening?
We seem to have a choice of nearly hot water or a nearly warm house.... seems we cant have both. Are we doing something wrong?
The heat seems to all stay in the burner, not much transferring to the water.
(We have a header tank and a hot water cylinder, 70's ex council house, trianco was in from then)
Please help! I'm using a tonne of coal and not getting very warm!
  • 1 more comment
  • Anonymous Dec 04, 2008
    Pump has one in and one out, and it is simply either switched on or off. We wait for the fire to get going really well (which takes an age for some reason, and much more coal than the trianco used) then switch on the pump. The heat just doesnt seem to be getting to the water in the back boiler, which makes no sense as it is essentially just a cast iron box!
    We have a ceramic lined flue (as no brick chimneys here) which is exactly as it was with the last burner, infact everything is exactly as it was because the old burner had exactly the same system, two pipes on left side two on right, we simply had the burner swapped when the old one burst.
    The water isnt even heating enough to make the pipes behind the burner properly hot, u can hold them even when the fire is going well.
    We have a separate emersion system thankfully, but we shouldn't have to use that to get the water properly hot when the fire has been lit for days!
    Where is all the heat going?
  • Anonymous Mar 21, 2014
    My eclipse will not heat above 37C & gradually drops in temperature if I remain in it for longer than 10 minutes; an issue also reported by others. It is at least 5 years old and the motor is very noisy, so I have removed it to give it a service or replace it, if necessary. I understand that waste heat from the motor is used to heat the water in this model which will always be a limiting factor.
    Q1 - Is there any way of improving the heating performance?
    Q2 - Surely a more efficient motor will generate less heat & so make the problem worse?
    Q3 - Has anyone plumbed a solar hot water element into the circuit (nothing found on youtube)?
  • Anonymous Mar 27, 2014
    geyser worked fine until first replacement of gas cylinder. now will only heat water to luke warm state. think gas line might be blocked as rest seems fine.
    Novelist:
  • 167 Answers
Some circulation pumps have a 3 phase mixing valve (cold,warm,hot) to regulate the water pressure in the building; no way to know unless you trace the plumbing. Basically, the hot water temperature could be lost because the circ-pump is cooling it with the cold water supplied to it. This is used to balance the pressure (aka Pressure Balancing Circ-Pump), so heater is really working overtime to heat the water. If the pump has two in and one out that's more than likely your problem; but you should consult a "old-school" plumber in your area.
Posted on Nov 28, 2008
Noritz water heater error code 99
MAke sure your flu is not making any 90degree turns. Use 45degree turns only. Error 99 is a combustion error. Usually referring to a blocked/obstructed flu. That said, a flu wit a lot of 90degree turns can act like restrictions to tankless heaters. If the flu i straight and clear, then you have a burner problem. Somethign you want Noritz to deal with.
Jan 04, 2018 | Noritz Water Heaters
Parkray room heater - seems to be burning more coal than ever before,constantly boiling the water which then has to be run off.
Solid fuel room heaters with a back boiler can have fairly complex air and damping controls. Driving older types was just as complex as driving a car, though slower, with the boiler damper, flue damper and air control.
In time manaufacturers wanted to widen the appeal of the products and began to refine the designs and make some of the functions automatic or semi-automatic.
I suggest you revisit the instruction manual and if you can't make the fire slumber, or damp it down so it sleeps for the night or close down the hot water, it is probably something inside has seized or broken.
Using excess fuel and constantly boiling the water is a sure sign too much combustion air is reaching the coals. If the coals glow brightly from the fire base excess air is entering the ash space or getting in below the fire basket. If the base is cooler and the top of the fire is hotter the air is being drawn across the fire. This is difficult to avoid if the design uses an air curtain to keep flame and soot away from the door glasses but it could mean an internal air passage needs clearing.
It could be time to take the heater apart for a thorough clean, inspection, replace gaskets and any corroded or broken parts including the clay liners.
Jul 13, 2016 | Water Water Heaters
Trianco boiler
Take of front cover and check joint as nessary and tighten up nuts or replace rubber o rings
Sep 13, 2013 | Water Heaters
Bosch 125fx heater barely heats water
1) Recommend replacing tankless with ordinary tank-type gas water heater.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
http://hometips.me/Mar/Which-is-best-gas-water-heater.pdf
2) Tankless cannot be exposed to more than 11 grains hardness in water or unit will fail within 2-5 years. Water softener is required.
http://hometips.me/Tls/Battelle_Water-softening-research.pdf
3) Descaling tankless water heater each year will not restore functionality, or restore efficiency of tankless, nor restore full efficiency to tank-type gas water heater.
4) Bradford White side-by-side testing research comparing their tankless with their tank-type shows that tankless will save $1-8 per month on energy bill vrs ordianry tank-type ....but conclude that tankless 'fall far short of payback' due to maintenance, repair, installation and replacement costs.
Study compared full cost, and not just monthly energy bill, since All costs are energy.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 16, 2013 | Water Heaters
I recently had to replace the thermostat in a 1 year old Whirlpool propane water heater. Since then the water heater burners ignite about every hour and run for 20 minutes even when no water is being used....
Hello HI GAS USAGE indicates a LEAK in the hot water supply piping.Is there buried pipes anyware,that could develop a pinhole leak you ca'nt see?Is any faucets dripping at all?That is exxesive run time for a heater in standby mode the new thermo is doing its job.Feel the supply pipe is it always hot?
Aug 27, 2010 | Whirlpool Water Heaters
I am istalling a parkray cumbria 111 inset multi fuel boiler stove which has 4 atacmens (2at each side) and im unsure of whic pipes connect 2 which. i orginally had a gas fre in and have removed that and...
the two largest conn go too cylinder hot wate and the other two too heating if wet system via a pump on the return (bottom conn top is the flow) if all the conn are same size two from one too water other two for heating
Oct 08, 2009 | Water Heaters
Noisy water heater blower
It may just need a new pump coupling. Fairly inexpensive. I don't think you need to replace the whole burner.
Feb 14, 2009 | Fasco Bradford White Hot Water Heater...
Is an oil burner efficient for a detached 2 car garage w 1 BR apt
the best oil burner to use would be of the condensing combination type as this would be abt 96%efficient and only heat water as you needed it probably saving you abt 30% on your oil bill
Nov 12, 2008 | Water RHEEM 40 Gallon FVR PROP PWR Heater...
How to Replace Water Heater
Before you rush out to buy a new one, you'll want to find out which type of water heater is most efficient. Your decision will be heavily predicated upon whether your home is set up to run an electric or a gas water heater. One general piece of advice is valid regardless: Don't assume you need to buy the same size water heater as you currently own. It is possible that you can install a smaller water heater if, in recent years, you have replaced other household appliances, such as dishwashers and washing machines. Newer products often include power and water saving features, and thus, you might be able to buy a smaller water heater that will cost less money and use less energy. Whether your requirements dictate gas or electric, learning which models are most economical is fairly straightforward. Federal regulations require that water heaters display Energy Guide labels. These labels include the Energy Factor (EF) that measures the overall efficiency of a model; the higher the number, the more efficient it is. The labels also will have a First Hour Rating (FHR) that indicates how many gallons of water that model will produce during a peak usage hour. Additionally, you can get energy savings information and rankings on some of the most popular brands of water heaters through consumer organizations and reports. A word about on-demand water heaters: On-demand water heaters, also called tankless water heaters, or spontaneous water heaters, can be fueled by either gas or electricity. This design is much more efficient than standard models. An on-demand water heater is smaller and does not keep a reservoir of heated water on hand for anticipated use. Instead, as soon as you turn on the faucet, the fuel source fires up and the hot water is delivered. This type of water heater requires some refitting during installation in order to provide powered venting and possibly a larger gas line, so it is best to hire a professional to do the job. On-demand water heaters are especially practical for small apartments or single-person households. Larger households will require multiple units. Once you have installed your new, energy efficient water heater there are even more ways to increase its efficiency. Remember to purchase insulation blankets, lower your thermostat, add an overnight shutoff timer, install heat traps, insulate your pipes, and be diligent about regular maintenance. If you take these steps, you can rest assured that you will have the most efficient type of water heater available.
Aug 27, 2008 | Emerson InSinkErator W-152 Point-Of-Use...
Water Heaters Logo
786 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
