Question about Office Depot Ativa DQ60M Shredder
Main drive gear is damaged on and Ativa shedder
Where can I find a parts dealer so I can repair the shredder?
Thank You!
Respectfully,
Nate
  • 333 Answers
If you main gear drive is broken you probably had a paper jam, so your shredder blade gear will break soon. By the time you purchase the part and pay for the shipping it would cost just about the same as gettin a new one. Then you will not have to wotty about anything esle breaking after you get this part because of the stress you put on the motor and other gears. I hope this helps you.
Posted on Nov 25, 2008
Shredder won't stop running
THERE MAY BE SOME PAPER SHREDS BLOCKING THE LASER LIGHT.
UNPLUG SHEDDER AND CLEAN CUTTER HEADS.
Sep 30, 2011 | Office Depot Ativa DQ60M Shredder
Fellowes Shedder p57c broken gear
I have the same issue with my p57c shredder as well. I am purchasing another shredder. I am willing to sell my good gears if your interested. garrettsmith1983@yahoo.com
May 18, 2010 | Fellowes 3011001 Shredder
Where can I find gears for the ativa Model DQ120Dn?
they don't make replacement parts. was designed to operate thru the warranty period then you buy another one. Fellows makes a better shredder.
Oct 29, 2009 | Office Depot Ativa DQ60M Shredder
Paper stuck in the Fellows Paper Shredder
  1. Remove Shredder from paper catcher bin
  2. Remove shredder cover from shredding mechanism assemble (approx. 6 screws on bottom of cover)
  3. Separate shredding mechanism from bottom cover (may have disconnect circuit board from assembly and other wiring from switches , sensors, etc,)
  4. Remove motor gear cover (approx. 4 screws)
  5. Separate shedder main drive gear from motor step up gear by pulling gear out
  6. Turn shredder mechanism up side down to access the cutting blades
  7. Use an adjustable wrench to turn the main drive gear to see stuck paper
  8. Use a needle noise pliers to remove paper shreds
  9. Repeat step 7 and 8 until all shreds are remove and cutting mechanism move smoothly
  10. Reassembly before testing shredder
  11. If you remove only some of the shreds, the motor may seize up and strip the plastic gears from step up gear.
Feb 09, 2009 | Fellowes DM8C Cross-Cut Shredder
Only one wheel rotates
I changed my mind and rid of shedder machine and bought new one. I don't want to bother to repair it.
Thank you for suggest me about ur problem fix up ..
Jan 18, 2009 | Office Equipment & Supplies
Can I purchase parts for my Ativa DQ60M shredder? I needa a few of the cutters and plastic spacers.
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Dec 10, 2008 | Office Depot Ativa DQ60M Shredder
XF50D motor won't turn shredder blades
There is no viable solution.  There are no replacement parts available.  The Office Depot shredder is a cheap low quality product made by a cheap company.  The FIXYA service agreement costs more than the product.  Bad choice to buy the product!
Dec 07, 2008 | Office Depot Ativa DQ60M Shredder
Ativa dx200d Shedder Plastic gear
Drill 3 or 4 holes along the path of where each gear tooth is missing. The holes should be sized to about 75% of the width of the tooth at its base. Drive appropriate sized screws into the holes. Clip off the tops of the screws to match the original tooth height. File the sides of the screws at an angle to match the original tooth sides. You are essentially replacing the missing gear tooth with three or four screws filed to match the tooth profile.
Jun 07, 2008 | Office Equipment & Supplies
Ativa SPL 1506X not working
I had the same problem. I took the machine apart and found out that the main gear running the rollers was defective. All of the cogs were broken or worn out, If you can find parts it can be fixed?
Nov 29, 2007 | Office Depot Ativa DQ60M Shredder
Office Depot Ativa  DQ60M Shredder Logo
731 people viewed this question
Top Office Depot Office Equipment & Supplies Experts
Anthony Karuku
quennie732
Stan Marciniak
Stan Marciniak
Level 1 Expert
Are you an Office Depot Office Equipment and Supply Expert? Answer questions, earn points and help others
