Question about GE Profile Harmony DPGT750EC Electric Dryer
Dryers drum is not spining
Hi my ge dryer drum is not spining but a sound is coming of from the dryer
  • evil666kitty Nov 28, 2008
    The dryer starts but drum will not spin. This happens sporadically and the dryer is less than 1 month old
They sent out a GE tech and mine had a huge dent in the bottom back side which had rubbed off a lot of that rubber 'belt'. Lowe's is replacing the dryer.
Did you know that the Harmony washer is a magnetron? The GE tech said it has a giant magnet in it that spins causing the electricity generated to spin it. Love my washer!
Posted on Dec 11, 2008
I was having a similar problem but my dryer was about 5 years old. There are a couple of rubbery, sticky belts that wrap around the dryer drum. One of mine had come off the drum and was balled up, wedged between the drum and the dryer wall. It wanted to spin, but this "belt" was keeping it from doing so. I'm not sure why or how it happened, but I removed the portion that was gummed up and now it works fine.
My dryer motor comes on (you can hear a humming noise) but the drum does not turn.
GE dryer won't start. Makes buzzing noise... - YouTube
? 0:39
www.youtube.com/watch?v=W_og12QJqm8
May 8, 2010 - Uploaded by maxicheong Anyone seen this before? When i tried to turn on the dryer, i get ahumming / buzzing sound and the drum ...
Oct 08, 2015 | GE WE12M22 Dryer
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
HELLO I HAVE A GE DRYER ONLY SEVERAL MONTHS OLD . IT HAS A NOISE IN IT SOUNDS LIKE SOMETHING RUBBING ON THE DRUM . IT SEEMS TO COME AND GO . MOVED CLOTHES AND IT GOES AWAY FOR AWILE
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 09, 2011 | GE DVLR223 Dryers
GE DPSR483EA Electric Dryer was making a scraping sound when operating, now a felt like belt has come out on the inside of the dryer. what do i do? Kris Long
The problem is something got between the drum and the felt seal between the drum and the front of the machine. You will have to pull the front off and find out what caused the felt to come out and then put the felt back in place and put the front back on.
Mar 18, 2010 | GE DPSR483EA Electric Dryer
GE profile electric dryer, sounds like something is stuck in drum
Heating problem is most likely caused by one strand of your heating element is burned out. Heating element will have to be replaced if that's the case. Noise you are hearing is most likely coming from worn front and / or back bearing. Dryer has to be completely disassembled for either repair.
Aug 28, 2017 | GE Profile Harmony DPGT750EC Electric...
Dryer won't start spining the drum
The belt is the likely culprit, you have to look inside to see if it is the belt
May 03, 2009 | GE DWSR405EBWW Electric Dryer
MY GE DRYER SOUNDS LIKE THE DRUM IS GETTING CAUGHT ON SOMETHING
the drum is supported in the front by two drum slides.You need to check them for visual damage
Jan 05, 2009 | GE DVLR223 Dryers
GE DRYER STOP RUNNING
sounds as if the belt has snaped and the drum has droped stopping you moving the drum
Dec 05, 2007 | GE Profile Harmony DPGT750EC Electric...
Tuble dryer not spining
sounds like your drum belt broke
Dec 01, 2007 | Hotpoint NWXR473EV Dryer
ASSISTANCE WITH MY GE-DBXR463EB1WW
two possibilities come to mind. one) the drum bearing is shot! second) the drum rides on two felt and plastic "bearings" at the front of the dryer. these felts might be completely worn causing the drum to flop around.
Aug 21, 2007 | GE DVL223GB Gas Dryer
GE Profile Harmony DPGT750EC Electric Dryer Logo
171 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
