Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Print access door will not close
I opened the printer access to look at ink cartridge and now it will not close for me it is just stuck in the opened position
    Scholar:
  • 174 Answers
Hi..
See if something is stopping it to close...or call kodak:585-781-6231
Posted on Nov 25, 2008
Print head jam
Check the LCD on your printer control panel or the status monitor on your computer for an error message. If there is an error message, follow the instructions to clear it.
If there is no error message, or if the problem continues:
  1. Open the access door.
  2. Disconnect the power adapter from the back of the printer.
  3. CAUTION: Do not use force on the printhead carriage to move it. Gently move the printhead carriage from side to side to see that it moves freely and there are no obstructions.
  4. Remove any obstructions that may prevent the printhead carriage and ink cartridges from moving to the center position.
  5. Close the access door.
  6. Connect the power adapter to the printer.
  7. Remove the ink cartridges from the printhead.
  8. Verify that the labels on the ink cartridges are intact, and that the cartridges are not damaged.
  9. firmly until you hear it click into position.
  10. Insert the color ink cartridge into the printhead, then press down firmly until you hear it click into position.
  11. Close the printer access door.
  12. Press OK to clear the error.
  13. Make a print.
May 06, 2014 | Kodak Office Hero 6.1
Hp f30 has new ink cartidge and paper but ink button still flashing and not printing alignment page.
Here are some steps that can help you resolve the problem.
Close the cartridge access door securely, if cartridge access door is open even slightly, the print cartridge light will blink.
1. Open the cartridge access door, once carriage moves to the center of the printer.
2. Check inside the printer and make sure that there are no obstructions that are preventing the cartridge access door from closing , if there's any obstruction remove it.
3. Close the cartridge access door completely.
Do the Print Self Test
Press and hold the Cancel button, and then press the Start Copy Color button
Release both buttons at the same time
If the issue persists, Make sure that the cartridges are installed
2. Wait until the carriage is idle and silent
3. Check the cartridge slots in the carriage to make sure that the cartridges are installed.
4. Try to reinstall it again.
5. Lightly press down on a cartridge to release it, and then pull the cartridge toward you out of its slot.
6. Check the nozzles on the cartridges to see if the protective tape is still attached
Note: Do not touch the copper-colored contacts or ink nozzles
7. Hold the cartridge by its sides
8. Slide the cartridge into its designated slot at a slightly upward angle.
9. Press the cartridge inward until it snaps into place
10.Close the cartridge access door
If still the problem persist contact HP for the service.
I hope this will be able to help you.
Thank you for choosing Fixya
Mar 10, 2011 | HP DeskJet F380 All-In-One Printer
My printer is showing an E sign, and flashing lights next to the ink symbols, but I have changed both cartridges
Issue : One or both Check Print Cartridge lights are blinking. On light Resume light Check Print Cartridge light Paper Type lights On Off Blinking Off Figure 7: Check Print Cartridge light is blinkingc01058982.gif Cause 1
The print cartridge access door is open.
Solution 1
Make sure that the print cartridge access door is completely closed.
Figure 8: Close the print cartridge access doorc00858057.jpg Cause 2
The print cartridges are missing or not seated correctly.
Solution 2
  1. Open the print cartridge access door. Allow the carriage to move to the center of the product.
  2. Make sure that both print cartridges are installed. If one is missing, obtain a compatible print cartridge and install it in the slot. To check the cartridge compatibility for your product, go to HP SureSupply . To identify your cartridge type in a language other than English, click the language link that appears near the globe icon in the top right corner of your browser.
  3. Run a finger along the top of the print cartridges. If any are sticking up, gently press the print cartridge down and forward into the slot until it clicks into place.
  4. Close the print cartridge access door. If a new print cartridge is installed, the product automatically aligns the print cartridges.
  5. Try the print job again.
Cause 3
The plastic tape was not removed from the print cartridge.
Solution 3
  2. Gently press down on each print cartridge to release it and then slide each print cartridge away from the product, out of its slot.
  3. Turn the print cartridge over so that the ink nozzles are facing up and make sure that the plastic tape has been completely removed from the print cartridge. Remove any plastic tape that remains. CAUTION: Do not touch the ink nozzles or the copper-colored electrical contacts on the print cartridge.
  4. Slide each print cartridge into its slot and then gently press the cartridge down and forward until it clicks into place.
  5. Close the print cartridge access door and try the print job again.
Cause 4
The print cartridge is not intended for use in this HP All-in-One.
Solution 4
  3. Make a note of the number on the print cartridge label.
  4. To check the cartridge compatibility for your product, go to HP SureSupply . To identify your cartridge type in a language other than English, click the language link that appears near the globe icon in the top right corner of your browser.
  5. Make sure that each print cartridge is compatible with the product. If both are compatible, reinstall the print cartridges, close the print cartridge access door, and continue with the next solution. If the print cartridges are not compatible with the product, replace them with genuine HP print cartridges that are compatible with the product.
Cause 5
The print cartridges might be defective.
Solution 5
Replace the print cartridges with genuine HP print cartridges that are compatible with the product.
NOTE: The printer might be packaged with only a tri-color print cartridge.
If all of these steps have been completed and the lights continue to blink, continue to the Service the
Jul 21, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
Printer stopped printing; amber teardrop is flashing; no paper jam; cartridges should not be empty. Shouldn't there be a notice of low ink before it just stops printing? Or, the printed pages be faint? All...
The top access door on the printer might be open, or there might be something wrong with the print cartridge.
  1. Check to make sure that the top access door is firmly closed.
  2. If the light continues to blink, open the top access door. When the top access door opens, the print carriage moves so the yellow arrow on top of the print carriage points to a drawing of a cartridge inside the cover. Each drawing describes a symptom.
Jan 09, 2010 | HP DeskJet 5550 InkJet Printer
I have a kodak 5500 aio printer. I replaced the
Try the following:
1. Open the printer access door.
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kadak Easy Share 5300 printer. Screen reads "Please wait"-stuck
Try this one
Take out the inks and printhead
Leave the cartridge door open, then unplug the power cord from the back of the printer while the access door is open
Close the cartridge door once the cord is unplugged
Reconnect the powercord, turn on the printer, then your printer will look for your printhead "Printhead missing or not installed correctly..."
Then put everything back. make sure it will snap in to place. Then print a calibration page, then scan it. This is just over writing the error message.
Thanks Josh - Kodak Tech Support
Aug 12, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Blinking orange light on hp 932c
Solution
  1. Check to ensure that the top access door is firmly closed.
  2. If the light continues to blink, open the top access door. When the top access door is opened, the print cradle moves so the yellow arrow on top of the cradle points to a drawing of a cartridge. Each drawing describes a symptom.
Solution two:
  1. Turn the printer off. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet.
  2. Wait 30 seconds. Plug in the power cord to the wall outlet. Plug in the power cord to the back of the printer.
  3. Turn the printer on.
Solution three:
The print cartridge carriage is stuck.
Solution
1. Open the top access door on the printer.
2. Remove the ink cartridges.
3. Turn the printer off, then on again.
4. Replace the ink cartridges.
5. Close the top access door.
Solution Four:
Issue
The 2-Sided Printing Module is installed incorrectly, not at all, or the back access door is unlocked or open.
Solution
1. Turn the knob on the rear access door of the printer counter-clockwise, and remove the door.
2. Insert the module into the back of the printer.
3. If the lights remain on, remove the 2-Sided Printing Module by pressing in the buttons on the ends of the unit.
4. Re-install the 2-Sided Printing Module by pushing the unit back into the printer without pressing the buttons, until it snaps firmly into place.
Jun 17, 2009 | HP DeskJet 932c InkJet Printer
HP C7280 Printer not priting wirelessly.
Solution Replace the indicated ink cartridge(s), or press OK on the control panel to continue. HP recommends the use of genuine HP ink cartridges. Genuine HP ink cartridges are designed and tested with HP printers to help produce great results, time after time.
NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage due to the use of non-HP ink will not be covered under warranty. Follow these steps to replace the depleted HP ink cartridge(s). Step one: Replace the indicated cartridge(s)
  1. Make sure the HP All-in-One is turned on.
    NOTE: The Attention light blinks when the product is turned on.
  2. Open the access door by lifting from the front center of the HP All-in-One, until the door locks into place. Figure 1: Opening the access door c01079714.jpg
  3. Squeeze the bottom of the latch below the ink cartridge to replace, and then lift the latch.
    • To replace the black ink cartridge, lift the latch on the far left.
    • To replace one of the five color ink cartridges, such as yellow, light cyan (blue), cyan, light magenta (pink), or magenta, lift the appropriate latch in the center area.
    Figure 2: Lifting the latch c01079715.jpg 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
  4. Pull the ink cartridge towards you out of its slot to remove it. Figure 3: Removing the ink cartridge c01079716.jpg
  5. Remove the new ink cartridge from its packaging.
  6. Holding the new ink cartridge by the handle, push the ink cartridge into the empty slot. Match the color and pattern of the ink cartridge to the color and pattern on the print carriage. Figure 4: Inserting the new cartridge c01079717.jpg
  8. Close the access door. Figure 5: Closing the access door c01079719.jpg
Step two: Align the new ink cartridge(s)
  1. Make sure paper is loaded in the input tray, and then press the OK button. The HP All-in-One prints the alignment page, aligns the printhead, and initializes the ink cartridges. This takes approximately 5 minutes. CAUTION: Do not disconnect or turn off the HP All-in-One during this time. You may hear the HP All-in-One making noises.
  2. Check the display for status, and then press the OK button. Recycle or discard the alignment page.
Cause The original HP ink in the indicated ink cartridge(s) has been depleted.
May 24, 2009 | HP Photosmart C7280 Laser Printer
5300 kodak eazyshare printer
Well, here is the proper way of fixing or troubleshooting that paper jam error in your printer
Open the printer access door and remove both of the ink cartridge, then remove also the printhead, after that close the printer access door, without those parts. Then it will show a message in the printer screen, "Printhead is missing or has come loose" or "Printhead Not Detected" Install the printhead, just the printhead without the ink cartridges. After that close the printer access door. Then it will show you a message"Ink cartridges is not installed,install ink cartridges". then open again the printer access door, then install the black ink cartridge without the color ink cartridge. then close the printer access door, then message must be " Color ink cartridge is not installed, install color ink cartridge" then install the color ink cartridge." the message must be,"New printhead is detected calibration require, load paper and press start"
Thats the way of overiding the paper jam error message of your kodak all in one printer
hope this will help you guys
by: E.brown
Happy Printing(", )
Kodak AIO tech support 1-800-421-6699
Jun 04, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Flashing lights
That flashing pattern is consistent with a stuck carriage. Here is a copy/paste from HP concerning the 5000 series and your flashing lights.
Issue
Solution
3. Close the cartridge flaps after removing the ink cartridges.
4. Turn the printer off, then on again.
5. Replace the ink cartridges.
6. Close the top access door. Issue
The Resume light continues to blink after the cartridges are released.
OR
The carriage is stuck or makes a grinding noise.
Solution
1. Lift the top cover to the printer.
2. Turn the printer off and then on again.
3. Unplug the power cord from the back of the printer when the grinding noise starts. Unplug the power cord from the wall outlet.
4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct).
5. Take out the cartridges and close the top cover.
6. Reconnect the power cord to the back of the printer. Plug the power cord to the wall outlet.
7. Open the top cover, reinstall the cartridges, and then close the top cover.
Oct 23, 2007 | HP DeskJet 5550 InkJet Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
