Question about Copystar CS-1500 Copier
Copystar CS-1500 Copier Problem
We had just replaced the toner because it said it was low and once we did that the copier stopped copying things. There are no errors that come up it just prints out blanks. How do I fix this? Thank you so much
  • humey51 Dec 01, 2008
    DaveAyre,
    Thanks a ton for the help. We did remove the drum unit. What does reseating it mean? Just placing it back in position?
    New Friend:
    Problem Solver:
  • 19 Answers
Did you remove the drum unit when fitting the toner? Try reseating it.
Posted on Nov 29, 2008
  • Dave Ayre
    Dave Ayre Dec 02, 2008
    Yes..All contacts on assy. may not have been made.
Where can I get a drum for a copystar cs1510?
http://www.digitalsystemcopiers.com/Copystar_CS-1510specs.html
About Us How to Order
Warranty
Contact Us
Email
CopyStar CS-1510 Digital Copier
CopyStar CS-1510 Digital Copier Supply Prices Toner Type Cartridge: Price: $37 Yield:7000 Developer $54.00 per 100,000 copies Drum $107 per 100,000 copies
CopyStar CS-1510 Digital Copier Optional Equipment
Oct 22, 2011 | Office Equipment & Supplies
I have an error code C-7 980 on a Copystar 1500. What does that mean?
This is a drum related problem. The waste toner is full. Remove the drum unit, remove toner cartridge and unscrew 2 chrome screws on on the left side of the unit. empty the waste and screw back the screws. replace toner and put back in the machine
Oct 26, 2010 | Copystar CS-1500 Copier
Flashing c-7 then 990
the waste toner is full please try to empty the waste
Jul 07, 2010 | Copystar CS-1500 Copier
When copying a line prints on all copies
You likely have a scratch on your exposure drum. Try shaking your toner cartidge and blowing compressed air into all crevases. If this does not solve the problem you'll likely need to purchase a replacement exposure drum.
Dec 14, 2009 | Copystar CS-1500 Copier
C-7 990 error code just keeps showing up on copystar 1500 copier
Shake the process unit from side to side
and turn the power switch off and then on.
If the problem cannot be solved, replace
the process unit.
After replacing the process unit, turn the
power switch off and then on. If the problem
cannot be solved, replace the waste
toner sensor or the engine board
Aug 19, 2009 | Copystar CS-1500 Copier
COPYSTAR 1500
the waste tank is full, remove the drum carriage. on bith side remove screw( the one who is inside the hole) dump the waste toner
Jun 22, 2009 | Copystar CS-1500 Copier
Toner cartridge
while pressing the center of the cover pull out the cover then bring it upward,
Jan 14, 2009 | Copystar CS-1500 Copier
check the charge corona and discharge corona wire unit either broken wire or the contact no good! one more thing when you replace toner cartridge did you remove the seal?
Dec 09, 2008 | Office Equipment & Supplies
Copystar CS-1500 Copier Logo
122 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
