Question about Sony Playstation 3 (PS3) Console
PS3 having problems
Powers on but when viewing the main screen or any game looks like flickering christmas lights all over the screen
  • pudge200202 Nov 25, 2008
    tried it and still have same problems
  • Anonymous Dec 15, 2008
    I had the same 'flickering Christmas lights' problem with random flickering of the entire screen along with a 'static pop' noise from the TV speakers (similar effect on an older TV when switching on a vacuum on the same electrical circuit). The problem started for no reason. I tried the component cables instead of the HDMI, and everything was fine. I tried another set of HDMI cables on a different input, with the same result. The problem disappeared after a few hours, just after I read this post. This problem is not due to wires or the TV. It could be electromagnetic interference.
  • 903 Answers
Try resetting the display (although I don't know if this will help you but worth a shot), press and hold down the power button on the front of the machine until you hear 2 beeps.
Also make sure that all your leads are pushed in fully and you have nothing within range that can distort your picture. (for example if my son uses his remote control car my screen goes flickered, if my neighbour turns on their mower same garbled screen again)
I hope this helps
Posted on Nov 25, 2008
  • Debs
    Debs Nov 25, 2008
    have you tried the ps3 on a different tv to eliminate a possible tv fault?
  • Debs
    Debs Nov 25, 2008
    if you are using a hdmi cable, then sometimes these can go wrong especially cheaper version, you may need to try another one. Faulty or cheap hdmi leads can cause flickering
The PS3 system powers on for a few seconds, will go through the normal process and get to the main screen. After roughly 10 seconds it beeps three times and powers off, with the red light on the front...
i had the same problem and it was fixed hwen i took apart the playstation and cleaned it there was some dust inside and i guess that fixed the problem for me good luck!
May 25, 2011 | Sony Playstation 3 (PS3) Console
Flickering in the main PS3 screen with 1080p resolution
1080 i is what you run going to higher resulution causes that your provider is 1080i or 1080p
May 02, 2010 | Sony Playstation 3 (PS3) Console
I have a playstation 3 it powers up to main screen stays on for 2 mins then cuts out n the light flashes red can u help
The problem is most likely in the powersupply of your PS3. Not something very easy to fix yourself. I recommend you have it serviced by sony.
Apr 19, 2010 | Sony Playstation 3 (PS3) Console
Bottom screen on ds lite flickers
check the cable first it might not be in the ribbon connecter properly, if everything looks ok chances are youll need to replace the screen.
Jan 17, 2010 | Nintendo DS Lite Console
PS3 Flickers on and off on the screen
Is could be your TV and not the PS3. When the resolution of the screen changes, you TV will flicker to adjust to the new resolution. My TV flickers in a similar way when playing games of lower resolution than my HDTV.
Jul 13, 2009 | Sony Playstation 3 (PS3) Console
My playstation 3 powers on but i get no audio or video
If harddrive light flashes on the PS3, you might not have the wires in the right place on your tv. Settings on the PS3 might not be set to the right cable. Tv might not be on the right input to view the PS3. If harddrive light dousn't flash your got bigger problems. Harddrive light is the amber colored light on the left side.
Mar 14, 2009 | Sony Playstation 3 (PS3) Console
Powers on but nothing happens
It happened to me too. When you plug in your av cables and are ready to play, follow these steps. With your PS3 off (Red light on), Press and hold the power button on your console. (Do not use the controller to turn it on.) Keep holding the button until you hear a second beep. (it takes about 2 to 3 seconds.) You will notice your screen flickers, then your PS3 will show up on the tv. All you did was reset the PS3 display settings. You can always go back to HDMI or AV cables. Have Fun.
Mar 07, 2009 | Sony Playstation 3 (PS3) Console
MY PS3 40G WOUNT LOAD ANY GAMES OR DVD'S
Call sony tomorrow morning from 10am and demand a replacement, mine died last xmas and now my replacement has also packed in this evening
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
Console powers off a few seconds into a game or movie
if the ps3 shuts down on its own it is due to overheating. It is necessary to disassemble the unit and apply AS5 compound and shim the heatsinks to ensure proper contact between the heat sink and the processors. I can do this for $55 or you can send to SONY if under warranty. If not under warranty they will fix for 150+tax call 1800345SONY
Nov 13, 2008 | Sony Playstation 3 (PS3) Console
Sony ps3
when you switch the ps3 on if you hold down the power button for more than 4 seconds it runs the display setup. and sets the ps3 to run in the best possible option
Dec 25, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
98 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
