Question about Logitech Harmony 890 LCD Remote Control
Changes 2 channels at a time
When i press the channel button (once) it moves TWO channels. (Geeksquad set it up & swears nothing is wrong.) They failed to leave a manual, so I am left in the dark to figure this gadget out.
  • gafisher Dec 23, 2008
    I have the same problem with a Harmony 659. The volume press also changes volume by 2 increments, not one.
  • w14kiwi Dec 27, 2008
    I have the same problem with my Harmony 525.
  • 2,335 Answers
I can help you with your Logitech Harmony 890 remote control.
The Logitech Harmony 890 remote control is programmed through the
Harmony Windows Setup Software.
I recommend resetting it up with your components to get rid of the two channel problem.
Once installed, you will simply run the program and select the devices you would like to control from menus. This program finds the right codes for you and loads them into your remote control.
You can get a copy of the Harmony 890 Manual by clicking here.
I hope that helps.
_____________________________________________
Harmony 890 Manual Download
Logitech Harmony Firmware Update
Harmony Win Software Download
Harmony MAC Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
Posted on May 05, 2010
My haier le32f2220 has A channel list box that pops up and I can't change channels. All remote buttons do nothing. Changed batteries twice. Anyone have this issue?
·Pull the batteries out from the remote control, and leave it out until step-4
·Press and release each and every button, one at a time on the remote control, until every button has been pressed and released at least once.
If the remote control have slide switches; move the switch to each position, then repeat the button pushing as in step-2. {When you've done, be sure to put the slide switch in the correct position to operate the unit the remote came with.}
·Put the batteries back.
·Try the remote.
http://remotesearch.blogspot.com/
Apr 24, 2015 | Haier Televison & Video
How do I Change the frequency on a Rkio Nike TWo way radio
Hi Gary - I copied this from the RIO NIKE manual:
mode button
Press MODE to select the setting you want to change.
The normal display is replaced by the adjustable setting.
Use the + and - buttons to adjust the settings.
These are the settings you can change.
1. Main Channel (1-14)
2. Sub Channel (1-38)
3. Channel Scan (ON/OFF)
4. Sub Channel Scan (ON/OFF)
5. Button Confirmation Tone and Roger Beep ON/OFF)
6. Vox (OFF, ON LO, ON HI) (psc[communicate wxonly)
When you have proceeded through all adjustable settings, the normal display will reappear. Or, press TALK at any time to return to the normal display.
select main channel
There are 14 main channels.
To select main channels:
1. Press MODE until CHAN is displayed.
2. Press + and - keys to select the main channel.
select sub channel:
Each main channel has 38 sub channels, sometimes called
CTCSS channels. Select one of these sub channels to transmit
on a channel that is free from traffic.
To select sub channels:
1. Press MODE until SUB CHAN is displayed
2. Press + and - keys to select the sub channel.
Note :If you select channel "0," you will be able to receive transmissions from all the sub channels of the main channel you selected.
Download manual:
Jan 27, 2014 | Rio Nike PSC Communicate (14 Channels)...
Where is the auto convergence button
Hello
From it menu option, suf through and come to automatic convergence display option and press Ok button on the remote control.
The List & Labels part of the setup lets you edit your channel list and choose or create a
personal six-character label for each channel.
Note: Changing List and Labels can be time consuming. You can change these at a later time by accessing the
Setup menu.
1. Press the left or right arrow to scroll through the available channels and choose the
channel you want to edit.
2. Press the down arrow to highlight the In channel list option. Press the left or right arrow
button to add (the box is checked) or remove (the box is unchecked) the channel from the
list.
3. Press the down arrow to highlight the Channel label option. Press the left or right arrow
button to scroll through the available list of 25 most common labels. The last option in
the list allows you to create your own six-character label for the channel (the first letter of
the label is highlighted).
4. Press the 1 or 2 number button to change the first letter of the label.
5. Press the right arrow to highlight the second letter, then press the 1 or 2 number button
to change the second letter, etc...
6. When you are finished creating your label, press OK. For model D34W20, your TV tunes to
the last channel available in your channel list. For models D40W20 and D52W20 only, the
Auto Convergence menu appears next.
Auto Convergence (for models D40W20 and D52W20 only)
Your TV's picture tubes might have been disturbed during delivery or after you moved the TV,
causing the color in your TV to be out of alignment. The colors adjust by starting auto
convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu appears. The
cross in the middle of the screen should be yellow. If it is not, use the arrow buttons to
move the red cross to overlap the green cross. Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle of the screen. If
it is not, use the arrow buttons to move the blue cross to overlap the green cross. Press OK
(the TV tunes to the last available channel in the channel list).
Ok
Mar 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Need intructions how to program remote control on vip722k second receiver
Press and hold down the SETUP button located on the remote. Wait until the INDICATOR light turns on. It will blink once the button is pushed, however once you see the indicator light stay one, release the button. Click the button to the DEVICE you wish to program. If it is a TV, then click the TV button. If it is the cable box, then click CBL button. After doing so, the indicator should still stay on. Press the DOWN CHANNEL button several times until you see the RECEIVER yo wish to program respond. Example: If it is a TV, then you will notice the CHANNEL change once the remote locates the correct settings for that receiver. If you see the receiver respond and you are pushing the down channel button but nothing is working, it means you passed the internal settings of the remote to the receiver. Try pushing the CHANNEL UP button slowly. It may be able to relocate the the proper settings. Once you see the channel change again, press ENTER to program the remote. If this fails, retry the same steps. In some cases you may miss the correct internal settings.
Nov 23, 2010 | DISH Network IR Remote Control
Unable to to get cable channels in modulator. Set to cable, channels 73/75 but "connection" grayed out. Cable signal strong. Able to read Digital channels on Local set up with same i/p.
mfbmeb,
The connection button is not utilized from the "Modulator Setup" screen. When changing the channel for TV 2, you can arrow over to either air or cable and pressing select. This will select that option and change the channel to either 60 for air or 73 for cable. Once this selection is made then you would move to the "Done" button and press select. You will return to the "Installation" menu, then cancel out till you are back to the TV screen. I hope this helps.
Ray Calo
DISH Network
Dec 16, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Samsung LE32R7 will not retune since switchover
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again
Sep 30, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Thanks but i need more help
Don't be panic.
Check the batteries of your remotes control. FIRST
Be sure to aim the control to the sensor of your tv.
Usually you have one remote for your tv and the other to control the cable box or digital box.
You have to set the RMC10 again using the code of your tv Silvania (like the first time)
Then set your tv on channel 3
Another thing, be sure that you are hitting the right buttons.
The control doesn't work if you hit on the top any key instead of cable
What i mean?
The remote has on the top 4 key usually (tv, cable, vcr, aux, etc).
You must hit first cable to set the control to cable
1, Manually turn on the device(TV, VCR, etc.) to be controlled.
2. Press and hold the code search button until the red indicator stays on, then release the code search button.
3. Press and quickly release the desired mode button (TV, VCR, ect.). The red indicator blinks off once.
4. Press the Channel up button repeatedly(up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press channel down button to backtrack through the library until device changes channel. Pressing Channel up changes direction forward again.
5. Press and release Mute to install code.
Don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Let me know how it is going!
Oct 18, 2008 | Electronics - Others
Talk about frequency change
To change channel & code press talk and monitor while turning radio on. Radio will speak current channel. Release both talk and monitor. Press talk to change to next channel or press monitor to keep current channel. Press monitor when desired channel is selected, radio will speak current code. Press talk to change to next code or press monitor to keep current code. Press talk to change code as desired then press monitor when done. Will speak channel and code selected. Set all units in same manner to communicate.
Oct 15, 2008 | Motorola Talkabout T5800 (22 Channels)...
Westinghouse LTV-19W6 TV Won't change channels
An email from Westinghouse that fixed the problem for me.
Thank you for your inquiry.
We apologize for any inconvenience in waiting for our response, but below is what I can suggest to move forward.
It appears all you need to do is run a channel scan on the unit. Once you have run a channel scan, you will be able to scroll through the channels using the channel up and down buttons.
If you have any further questions, you may contact us through email, or by calling us toll-free at 1-866-287-5555, between 9am and 9pm Eastern Standard Time, Monday through Saturday. One of our technicians will
assist you.
Aug 05, 2008 | Westinghouse LTV-19w6 Television
Logitech Harmony 890 LCD Remote Control Logo
382 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
cwradio73
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
