Question about Mitsubishi WS-55807 TV
The front panel power button won't work and i don't have the original remote for my mitsubishi hd 1080
No remote and front control panel won't work
    Top Expert:
  • Mitsubishi Master
  • 76,099 Answers
Check and replace the microswitch soldered diretly to front panel circuit board. You have to open the TV. Get more details from the below referred site, and by click open the ads by the side and bottom of each posts.
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
Posted on May 27, 2012
2 Suggested Answers
SOURCE:
jingjao
  • 252 Answers
SOURCE: mitsubishi hd 1080 tv humming and blurred words/ bight colors
check the capasitor near the plyback value 250 volts and also the B+ capasitor
Posted on Oct 01, 2008
Sony DVP-S7000 DVD player does not respond to front panel buttons or the remote control
The only possible solution and it is a long shot, unplug unit from wall receptical, now press and hold power for 60 seconds, this will drain any residual voltage and reset the microprocessor in hopes it will work. If this fails I recommend the sony technician.
Jul 17, 2012 | Sony DVP-S7000 DVD Player
Can't get the tv to switch from cable to antenna mode using a RadioShack remote or the buttons on tv
It sounds that the front panel controls are locked with your tV. You have to unlock it first, if you want to change its input selections. If you cannot select the inputs by using the remote control [I thing you are using a universal remote control], setup the remote control with an other setup code. All codes to remote control won't work with some functions. You have to search and select, which code give maximum functionality with your TV.
Jul 06, 2012 | Zenith SY2569X TV
Pioneer PD M502 won't recognise Remote controller
this Pioneer PD-M502 have no remote sensor.mean this model was not designed to work by remote control.
Jul 01, 2012 | Audio Players & Recorders
Can a tv lose the ability to read codes from a universal remote cause i tried three different un. remotes and my tv doesent react to them.. thnx
If the infrared sensor inside the TV is faulty, TV won't respond to any remote controls. You can make it sure by looking into TVs standby light. If standby light on TVs front panel blinks once, when you press a key in the remtote control, make sure that the sensor inside is working properly, and the code you are trying to enter is non once for your Brand TV, If there is no blinks as such stated above, make sure that the infrared sensor inside your TV is faulty. If you want more details about codes, setup proceedings, repairing a remote & checking it, just visit this site. Th site name is "Electro-help".. Just search for it by type in 'electronicshelponline' in your browsers' search page. It is a blogspot site, in English language.
Jun 22, 2012 | RCA Televison & Video
Hi i am trying to change the screen size on av2 and 3 but it wont work the aspect button
Check the remote control for its infrared emission from infrared LED at its front. Do not assume that the remote control is OK, as the indicator LED on it lights up. It is only an indication that the remote control circuit accepts the keystrokes.
Just visit this site [Eectro-help]. You will get all details about how to check a remote control. All details are given there. Pull up older posts there. Search for it either by Yahoo or Google.
Make sure that the remote control is correct in all respect first. I assumes that the remote control you possess now is the original remote control of the set. Not a universal one. If it is a universal one, this type of fault can occur, because all universal remote controls won't respond to some functions.
May 09, 2012 | Panasonic N2qayb000184 Remote Control
My RCA tv won't work without a remote, and I can't seem to reset since I don't have a menu button
Hello
If your TV has no menu button on its front panel, there is no other way than buying a universal or original remote control to this set.
Mar 04, 2012 | RCA Televison & Video
Apart from the on-off button none of the panel or remote controls are working on my Toshiba 20wl56b t.v
I think problem is from the control board. The board works with the TV buttons and that's where the remote sensor is. If the board is defective or dead, the buttons won't work and the remote won't work as well.
I hope the above is clear.
Good luck.
Jan 05, 2012 | Toshiba 37WLC48 LCD Television
My remote won't work and I used to be able to change the channel on the TV but even that dosn't work. I checked the cords. Changed the batteries;
Hello
First check its battery contacts for any rust or dirt accumulated on it. If so, contacts of battery will not touch properly, and the unit will fail to work. The second reason for malfunction is due to the infrared sensor inside your tV. If it is faulty, the set won't respond to infrared signal generated by the remote control. If so, eventhough remote control works properly, the set won't work with it.
Remote sensor comes just behind the infrared window at the bottom front panel of your TV. It is a replacable part and not so costly too. It is a three terninal component will look brownish black in colour. It will looke like this.
gopakumarg43_77.jpgThe procedure to check the remote control for its perfect working is described at a tip I've given and published by Fixya on Google. Type "gopakumarg43" on google search box, and get into my profiles. There you can see 'Tips and How To's" line, click on it. You can read it there. OK.
Sep 23, 2011 | Philips Magnavox 20MT133S 20" TV
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
Remote won't work. Tried new batteries, reprogramming, etc. Universal Remote doesn't work either. LG #42PC5DC
To confirmed if the remote control is working fine, aim the remote control sensor(IR emitter) directly to your cellphone camera. While pressing any button key on the remote control, you can see the flash of an infrared emitted by the remote control if it is working fine.
If you've confirmed that the remote control emitted an infrared but still the tv won't communicate with it, this is an indication of faulty IR sensor board of the TV. Check if there's an obstruction from the IR receiver in front. Keep away all of it, clean the plastic window of the IR receiver with soft clean cloth.
If the symptoms still persist, you have to replace the IR sensor board. Check the actual part no. of the board before ordering.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 22, 2011 | LG Televison & Video
Mitsubishi WS-55807 TV Logo
41 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
