Question about Hotpoint RVM1435 Microwave Oven
Shuts off after 2 seconds
Have a 3 year old hotpoint rvm1435 counter saver microwave oven. When you turn on it works for couple seconds then shuts down and you get a PF code on display. Any idea of problem. Thanks.
  • btrimpe Nov 28, 2008
    Very helpful. Thank you
  • Hotpoint Master
  • 9,098 Answers
Sadly, we hear of this over and over.
This is due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
Details are in their bulletin here. Even if your model is not on the list, the same problem can occur, requiring a kit.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
They may send you a replacement magnetron. GE Customer Service is here.
Posted on Nov 27, 2008
Counter saver plus 62702 kenmore
If you repair a door assy. you are required per DHHS rules to perform a leak test on and around the door after such repair.
Oct 07, 2013 | Hotpoint RVM1435 Microwave Oven
Hotpoint microwave only works a few seconds then shows all 8s in the display
Sounds like its time for a new microwave
You can probably buy a new one cheaper then fixing the old one
Most controls that display 888 something is shorted out on the controller.
Have you tried unplugging it for 5 minutes and plugging back in?
Aug 24, 2013 | Hotpoint RVM1435 Microwave Oven
My NN-T994SFR Panasonic Microwave shuts off after 1 second.
My unit shuts off after about 2 seconds. It seems like it tries to go, but it sounds like it stops working and then 1 or 2 more seconds run off and it shuts down. Then you hit start again and it lights up inside and then shuts down. It's only about 2 or 3 years old.Any solutions?
Mar 05, 2010 | Panasonic Microwave Ovens
I have a Hotpoint Counter Saver Plus Microwave model RVM1435wd. The turntable does not rotate. How can I fix it?
If your turntable is not going around you may have one of two problems: the coupler under the glass tray may be worn and in need of replacement or the turntable motor needs to be replaced. Hope this helps.
Jan 24, 2010 | Hotpoint RVM1435 Microwave Oven
Microwave not heating, but does count down minutes.
Press clear/reset button and hold 5 seconds. If this doesn't work unplug unit or shut off breaker for 10 seconds.
Sep 25, 2009 | Hotpoint RVM1435 Microwave Oven
Hotpoint Counter Saver Microwave not working
Please do not try to service. its dangerous to play with the internal parts of a Micro Wave. Most counter tops are pretty inexpensive buy a new one if the warranty is out.
Sincerely Steve
May 29, 2009 | Hotpoint RVM1435 Microwave Oven
Beep
This answer assumes yours is a Hotpoint RVM1435, as posted.
If not, please reply back with your correct brand and model.
Model RVM1435 does not have a feature to turn off the beeper.
You can download Hotpoint and GE owner's manuals here:
http://www.geappliances.com/service_and_support/literature/
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 07, 2007 | Hotpoint RVM1435 Microwave Oven
Microwave oven turns off
It could be an overheating magnetron. There is a thermostat inside (mounted to the side of the magnetron) which senses excessive heat and opens up, disconnecting the power to the oven. If that's the case, unplugging it and plugging it back in will not fix it. It will come back on by itself after it cools down. That's another indication that it might be a thermostat kicking out. You might try to further characterize the failure: - happens only when cooking on full power? - also happens when cooking on a low power level? - shuts down every time you use it? - only shuts down after XX amount of time cooking? Once you characterize it more, I can make further suggestions. It may also be a bad connection on the control panel.
Nov 03, 2006 | Hotpoint RVM1435 Microwave Oven
Hotpoint RVM1435 Microwave Oven Logo
327 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
