Question about Sharp UX B700 Plain Paper Inkjet Fax
Cant fax communication center says line is in use
  • Leroy Elliott
    Leroy Elliott May 11, 2010
    Are you sharing a phone line with any other device?
    Genius:
  • 2,120 Answers
Un plug the handset and try again.
Posted on Nov 30, 2008
My Konika Minolta B 211 cant fax, it says No communication but the line is ok. What could be the problem?
is the fax cable plugged into the "Line" connector not the "Tele". Call the line does it ring ? replace the fax cable, bad fax board, sure the line is analog not digital.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 07, 2015 | Minolta Office Equipment & Supplies
Why cant I send a fax
I share a informative links please visit and check it your error options.
Read More... Cannot send fax using all in one printer and Interpreting Error Codes in Fax Communication Error or Fax History... and If any more Help.. HP Printer Support
Thanks,
Sep 08, 2014 | Office Equipment & Supplies
Magicjack problems
Fax communication is the same as Voice Communication when using the MJ. It dials in the same way. If you do not FAX using your Printer Fax line into the MJ; you must use a FAX mailing program generally a part of word processing such as Office. You would need to do a setup in Word for example to call out via the Fax Number. If you use a FAX (Independent) machine, connect the line out cord from the Fax Machine into the MJ and dial out from the FAX device. Check to see if you have a Dial Tone? If Not, the MJ is not open and working.
Jan 04, 2014 | Computers & Internet
Communication error 43 message every time and with every number.Panasonic fax kx-fhd332
COMMUNICATION ERROR (Code: 43, 44) means that "A line problem occurred". There might be a problem with the phone jack where your fax machine is connected to. Try to connect the telephone line cord to a different jack and try again.
Mar 21, 2011 | Panasonic KX-FHD331 Plain Paper Thermal...
Have a MFC-440Cn and cant get it to fax. I am using my computer to connect it too and it scans and copies as it should but it does not fax. I get an error the says NG: poor line condition/out of memory
The only thing that could stop you from sending a fax or not get a dial tone, would be the connection to the phone lines.
Make sure the telephone wire is plugged into the line jack (not ext jack) and should go straight to the wall, without splitters or extensions.
If you still cannot send a fax, try another telephone wire and jack.
Jun 15, 2010 | Brother MultiFunction Center MFC-440CN...
Cannot fax to one number
PROBLEM IS NOT YOUR FAX 99%CHANCE IT IS THE PHONE LINE CONNECTION WHEN YOU DIALTHE SIGNAL IS GOING TO VARIOUS LOCATIONS LOOKING FOE FREE SPACE TO SEND TO RECEIVING FAX.BEFOR RESENDING TRY CALLING FROM PHONELAND LINE.COMMUNICATION ERRORS ARE THE BIGGEST FAX PROBLEMS IF THEY CANT COMMUNICATE 95%ERROR FREE THEY WILL DISCONNECT STATIC ON LINE IS THE CAUSE
May 19, 2010 | HP 1040 Plain Paper Inkjet Fax
Epson fax hooked to magic jack communication error
I had same problem when I used the dual jack. I had to change it. I had the dual jack which would make it easier to use when I was going to send a fax.
Good Luck
Feb 09, 2010 | Epson WorkForce 600 All-In-One InkJet...
Canot recieve fax
Try these settings ::>>
1.) Press Setup
2.) Select Fax Settings, then press OK
3.) Select Communication, then press OK
< under communication try these settings >
> DRD should be all
> ECM should be off
> V.34 should be off
> Rings to answer ( if you have an answering machine?
or a voice mail service either virtual or physical.,
check how many rings does it have before it picks up )
set your printers rings to answer about 2 rings higher than these devices.
> Auto answer on the control Panel of the printer should be on / enabled
Note ::>> If still cannot receive a fax? try to disconnect your voice mail or
answering machine to the line to Isolate Issue whether printer cannot receive
a fax or the said devices is having an issue with the printers fax
receiving capability.
Mar 28, 2009 | Epson Stylus CX9400 Photo Printer
Fax machine communication error 43 on kx-f750
communication error 43 is error of telephone line.there is some distarstion in telephone line.some noise in line .due to this it is facing problem.just clear ur line .or check with an other line.by mian jee
Dec 02, 2008 | Office Equipment & Supplies
Communication error
the problem is most likely not the machine, once it has established communication it should be fine.
if there is a break in the line for whatever reason then, it will give you the error.
try to fax to a different fax, does it still do it? plug a phone in that outlet and call a freind, chat awhile, is there any static or anything unusual with the line?
Dec 13, 2007 | Brother IntelliFax-2820 Laser Fax
Sharp UX B700 Plain Paper Inkjet Fax Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
