Question about Fisher Paykel EcoSmart GWL15
DRAIN PROBLEM Washer will go to rinse cycle and not drain or rinse. Machine will just hum.
  • senselass Dec 09, 2008
    washer is full of water from a load and will not drain to progress to rinse cycle.
    gross!
  • wolfe2 Dec 11, 2008
    I have the same problem right now, the machine will not drain! And the water is increadibly dirty looking.
    Has anyone found a solution?
  • 145 Answers
Here's some things to check: The electric water pump on those machines can be stopped by objects that get under the machine- The pump has a "fan" on it, and I have seen numerous times where a sheet of fabric softener like "BOUNCE" will get sucked into the pump's fan and "strangle" it.
Follow these instructions: Starting with the machine OFF, take one finger and depress the water temperature adjustment button for DECREASE (arrow points DOWN) and hold it down, and while holding it down, turn the machine on by pressing the power button.
If you did it right, you should hear two quick BEEPS. Now release the buttons. This sets the machine in "technician mode"
Now press the REGULAR button (the cycle selector button for a REGULAR wash cycle)
You should hear the water pump start and the water should be going out the drain hose. If you hear a slight "HUM" then the water pump is jammed with either an object inside the tub or the aforementioned sheet of bounce or whatever. If you hear the pump start but the water seems to be recirculating back into the tub, then something is either caught in the machine's DIVERTER VALVE or the valve is physically broken. In rare instances, the machine control has a short and is powering up the diverter valve all the time rather than only when it is supposed to...
If this helps, please rate my answer!
Posted on Dec 12, 2008
Whirlpool AWM 5080 stops during cycles
Sound like could be faulty pump however you need to make sure no
Could be pump at fault 1st you need to make sure no coin stuck in there ...
Mar 31, 2010 | Whirlpool AWM6100 Front Load Washer
The wash cycle clicks on and a small amount of water enters the drum, as normal, but then there is just a humming noise and the drum does not move. When I put it on the rinse and spin cycle (there is...
I removed the bottom panel under the door and drained the the tub. There is a white filter housing that unscrews, but you need to have towels handy to catch the water that comes out. The machine appeared to work after that but it would'nt drain and it turns out that the humming noise was coming from the drain pump connected to the filter. I ordered a new drain pump assembly, which should be easy to replace since it is located at the front of the washing machine.
Jan 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Machine wont drain
check for faulty water pump or a blockage to the water pump see if you can here a hum when it is time for the machine to drain
NEVER OPEN MACHINE CASE WHILST STILL CONNECTED TO MAIN POWER SUPPLY
Jan 18, 2010 | Tecnik TKL9260 Front Load Washer
Washer will not start washing cycle. Machine hums like the dryer
Check the drain for clog. If the drain is dirty, the washer won't fill, rinse, or drain.
May 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer wont drain or spin
It sounmds like there is a clog in the pump. If the washer won't drain, it will never spin. Remove the front panel by sliding a putty knife between the top and the front panel. The pump is located on the right side as you face the machine. Unplug the machine and be prepared to catch the onslaught of water as you remove the hoses. The pump may be clogged as you will see once you rmove the hoses. If so, clean it out and test. If the pump is bound and will not move it may need to be replaced.
Apr 17, 2009 | Hotpoint VBXR1090D Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer will hum and will not drain water out!
You will have to either look under the machine or take the back off.
You will see the big motor which does the washing.
You will also see a small motor which drains the machine.
Disconnect the power supply and remove the pipes from the small motor.
It could be blocked up from congealed washing powder.
Or something may have blocked the pipe from the drum to the drain motor.
If it all looks ok and still doesn`t work, then the motor has siezed.
Very easy to replace
good luck
Jan 25, 2009 | GE WBSR3140DW Top Load Washer
GE Top Load washing machine not draining
  • to me it sound as if waterpump is not working
Apr 09, 2008 | GE WDSR2080D Top Load Washer
Stalled Motor
quite possibly the drain pump which would cause it to stick in rinse cycle. the humming noise you heard is probably the drain pump powered up but jammed. likely cause is a foreign object stuck in the pump impellor - main culprit is bits of bra wire. take the pump to pieces and extract whatever is jamming it.
May 12, 2007 | Kenmore 24852 Top Load Washer
Fisher Paykel EcoSmart GWL15 Logo
236 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
