Question about PfaFF Creative 7570
I can't get my new computer to communicate with my Pfaff 7570.
I am currently using a PC with Windows 98 to run my PE design software. I want to use a laptop that has Windows XP, but when I connect it, my machine gives me a error that says I have no communication. Do you know what I need to do to correct the problem?
Thanks
Edwina Ulmer
  • Kim Fillmore
    Kim Fillmore May 11, 2010
    Hi Edwina,
    The problem may be with the program & cable you are using to send the designs to the machine, i.e. PCDesigner or Pfaff File Assistant & whether you are using a serial cable (with adapter) or a USB cable. If you could respond with this information, we may be able to help you (lots of years between us working directly for Pfaff).
    Hope to hear back from you soon,
    Kim & Linnette
    www.sewingexpressions.com
  • 3 Answers
SOURCE: no communication between pfaff 7570 and computer
It sounds like you have it configured properly if you have the little machine and computer appearing on the display screen. I had this problem too in the beginning, file assistant doesn't use the files for the 7570 its only for some of the newer machines, use Vip customize to send the design to the machine from the file drop down menu. Hope this helps.
Posted on Mar 05, 2009
SOURCE: 7570 connection
I have Windows Vista; I also had a similar problem; found out that I could only use the usb port on my computer exclusively for sewing as the driver software seems to conflict;
Also, having said that, go to Pfaff.com & download the free driver upgrade and see if that will get you started good luck deb
Posted on Jul 01, 2009
  • 5 Answers
SOURCE: connect PfaFF Creative 7570 to a PC
The software you need to connect the Pfaff 7570 to the PC and to create your designs is called PC-Designer version 2.2 from Pfaff. You may be able to find a used copy. The software should come with a dongle (special cable) for connecting the machine to the PC. Make sure you have this piece because it will not work with an ordinary cable. Depending on what type of port you have on the PC to connect to, you may also need an adapter since the dongle has an old style connector on the end going to the PC. If you are going to create your own designs, you will also need a storage card which inserts into the machine that you send the designs to. Pfaff makes one, called the creative card. I have also used a generic card meant for the pfaff; the generic card is less expensive and has a greater capacity. You can find many designs online either free or for sale to send from PC to Pfaff as well.
Posted on Dec 15, 2009
SOURCE: I have (pfaff 7570) pc designer software on floppy
You will need to purchase an external floppy drive. There is no download available for software.
Posted on Jun 01, 2010
  • 632 Answers
SOURCE: I have lost the cable cord to connect the machine
Try ebay
Posted on Jun 19, 2010
I have a Pfaff 7570 with Windows 7 professional. Windows 7 has a special program that allows you to use programs with windows XP. I have everything installed properly but can not get any communication...
I can't tell you much or offer any advice but I can tell you with absolute certainty the Windows 7 compatibility programme has never worked for me.
I have stuff I used to use with XP and either it works with 7 or it doesn't and if it doesn't the compatibility programme makes not a jot of difference.
Nov 11, 2017 | PfaFF Creative 7570
I have a 7570 phaff sewing machine and a new windows 7 PC What will I use to transfer my patterns to the machine
Hi franlove
I had the same problem when I upgraded to a laptop with Windows XP. I needed to buy a Keyspan, which connects via the USB on the computer to the machine via the pc connector that comes with the Pfaff 7570. However I had many problems after that, and found that the Keyspan transfer rate had to be slowed down to 2400. Of course 3D is the most recent Pfaff software that the Pfaff 7570 will work with. Anything older is OK.
Hope this helps. I will look up the steps that I went through to slow the transfer speed from the Keyspan if you need me too.
Good Luck
margielydia
Dec 29, 2010 | PfaFF Creative 7570
Connect PfaFF Creative 7570 to a PC
Nov 27, 2009 | PfaFF Creative 7570
Need PC Designer for for 750 windows xp/where?
If you purchased the software after April 1st,2006 then you will be entitled to a free upgrade. If not you might have to purchase the software. Here is a link to the PFAFF software download page. http://www.pfaff.com/global/11283.html
Nov 13, 2009 | PfaFF Creative 7570
7570 connection
Jun 24, 2009 | PfaFF Creative 7570
No communication with the machine.
contact the manufacturer your new system may not be compatible if it is windows 10 .probably a driver problem
Apr 30, 2017 | PfaFF Creative 7570
Pfaff 7570 program
I have somewhere that installation diskette (with the old SW version). If I'm not mistaken it was not included with the sewing machine but sold separately with the embrodery arm that we bought together with it some 10 years ago. Email me to azach@kci-medical.com if you need more help.
Jan 08, 2009 | PfaFF Creative 7570
Pfaff 7570 connection to new XP laptop
In this FAQ list (from PFAFF web) you find 100 times the same question and answer:
H402 My new computer does not have any serial COM ports, so how does it communicate with my Pfaff creative 7570?
You will need to obtain a USB Serial Adapter, which adds a serial port to your computer by plugging it into a USB port. Suitable adapters can be obtained from Belkin [http://www.belkin.com] and Keyspan [http://www.keyspan.com].
The following USB Serial Adapters are known to work with the Pfaff creative 7570:
• Belkin F5U103
• Keyspan USA-19QW
Please note that the Belkin F5U109 is listed as working with the Pfaff creative 2140/2144 (FAQ #H405), but it does not work the Pfaff creative 7570.
Jan 06, 2009 | PfaFF Creative 7570
No communication between pfaff 7570 and computer
Jan 02, 2009 | PfaFF Creative 7570
Sewing Machines Logo
56 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
